Tire Pressure increases 5 lbs in one ride
#76
FWIW: the link in question does seem to work - just not with a secure HTTPS connection. What follows should be the nonsecure (unencrypted) version of the link. However, this site (bikeforums) often seems to convert nonsecure links in comments to the secure version. If the displayed link below begins with "https", cut and paste the link into your browser's URL input area, then delete the "s" from "https" to get the nonsecure version of the link. (Depending on your specific browser and setup, you may or may not get a security warning and/or have to configure your browser to allow nonsecure HTTP connections.)
https://www.smitherequip.com/lit/SE1iPDF1.pdf
I have no "dog in this fight". However, I've noticed previously that some browsers don't handle older versions of HTTPS and/or TLS very well. Unfortunately, and some websites still user older versions of HTTPS and/or TLS, or use nonsecure (HTTP) links. This can sometimes cause people to believe links are invalid/don't work when they are in fact still working links.
In particular, the Firefox browser does not handle older HTTPS and/or TLS very elegantly. I use Firefox and run into this situation on occasion. I suspect that other browsers may handle older versions of HTTPS and/or TLS similarly.
#77
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Agreed that measurement error is the biggest unknown, and most likely explanation.
But we do not even HAVE a measurement of temperature, either before or after the ride.
This comes up a lot in the "heat from braking blows tire off rim" threads.
So - temperature MIGHT explain it, but if you want to be sure, you have to run a real experiment multiple times and measure everything... not just rely on intuition and a couple data points.
#78
Bikes: Fred cycles
Quoted: 34 Post(s)
Liked 18 Times
I come at it differently. Observing that a pressure rise was measured, and that there is no added air during the ride, we are forced to conclude by mass conservation that something is driving pressure up. The idealization (the Ideal Gas law) should apply, within a few percent, for air at the 4-9 bar pressure range. Above about 2 bar, engineers generally apply a compressibility factor, z, so that the law is PV = z nRT. For air in this range, z is nearly 1 and can be ignored. Specifically for air at 300K (23C) and 10 bar z = 0.9974. So, effectively, PV = nRT. Assuming that the tire does not expand much we are left with P = (nR/V) T. The (nR/V) term can be assumed constant as a starting point. Pressure is then related to the absolute temperature proportionally. So if the inital pressure is 100psi, and we end up with 105psi, we might expect the absolute temperature to rise about 5%. Is this reasonable? Assuming we start at 20°C, or 293°K, we'd get to 307.7°K, or 35°C, or 94.4°F. That seems an entirely reasonable temperature for a tire after a ride on hot pavement. In fact, I suspect that this calcuated temperature rise is low, and that the tire does stretch a bit as pressure rises.
PS -- about 'moles', something that surprised me when I learned it, but maybe shouldn't have, is using different values for Avogadro's Number allows work in different mass units. The number 6.02 x 10^23 is the one learned in intro courses, but engineers might use 6.02 x 10^26 when working in kilograms, 'kg-mols'. Or a different number if working in some other odd units like pounds.
#79
Quoted: 3505 Post(s)
Liked 2,924 Times
#80
Quoted: 2604 Post(s)
Liked 1,927 Times
Remember to subtract the 14.7 psi for sea level pressure to convert absolute pressure back to gauge pressure.
It's higher than I like, which is why I use wider tires so I don't need to pump them up to 100 psi. If I were riding 23-25 tires, I'd probably need the 100 psi to prevent snakebite flats.
#81
Liked 2,924 Times
I was kidding...I think duffer1960's numbers are off about 100 pounds...
#82
Quoted: 2333 Post(s)
Liked 2,097 Times
I started today's ride with tires at 68F. Ambient temperatures during the 90 minute ride ranges from 77-80F. My tires were 117-120F at the end of the ride. Tar was melting on the chip seal for us non-analytical types.
#84
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
The discussion, by the way, isn’t about the Ideal Gas Law but Avogadro’s Law which states
equal volumes of all gases, at the same temperature and pressure, have the same number of molecules.
My statement is not incorrect.
Dead link... is that a joke?
From the text of the PDF
High Precision Absolute Pressure Gauges
Series 1500 Gauges pressure elements are capsules up to and including the 50 psia range: 100 psia and above use Bourdon tubes. In the former, pres- sure is applied to the case and is referenced against the evacuated capsule. In the latter, pressure is applied to a Bourdon tube, which is referenced against an evacuated Bourdon.
Available in 14 standard ranges…
You just made up that statistic, right? I understand exaggerating for effect, but something like 3% of US Citizens have STEM degrees, and we're talking about a high school science concept.
This is incorrect and you know it. A mole is a number of items; just like a dozen, or a score, or a gross. A mole is an Avogadro's number of something. One mole is not one particle - you are off by 23 orders of magnitude. We both understand this and you're still trying to cover up your misstatement.
Well you seem to have concluded that I don't know what I'm talking about. Science people understand what you meant with your sloppy narrative. You and I are not arguing science though, we're arguing language. For reference, I have to explain technical concepts to non-technical people, in peer-reviewed reports - so my attention to correct usage of terminology and proper sentence construction is a skill I've been polishing for a long time.
Stuart Black
Stuart Black
