Suspension seatpost for captain?
Has anyone run a suspension seatpost with a stoker stem attached? I recently switched over to a riser stoker stem, which opens up this possibility. I struggle much more with saddle sores on the tandem than I do on my other bikes setup with the same geometry/saddles. I believe this is because of how stiff it is (08' alloy C'dale road tandem), or perhaps because it is more difficult to consistently get out of the saddle. I'm experimenting with saddles, but thought a suspension seatpost may be helpful as well. My wife and I typically do 50-100 mile rides on a mix of pavement and gravel.
I'd love know what your experiences have been and if there are other solutions captains have found for saddle sores on long touring/bikepacking rides?
Bikes: '80 Medici Tourismo, '82 Merckx, '85 Peugeot PSN10, '86 Ironman, '89 Trek 520, '96 Steelman, '96 Torelli CX, '97 Friday Two'sDay, '02 CoMo Speedster, '09 Giant Reign, '10 Canfield, '13 Turner DHR, '16 Chase BMX
Quoted: 40 Post(s)
Liked 256 Times
What size tires and psi are you running? We run 38mm at 55/60 psi and it provides a very comfortable ride smoothing out many of the bumps to the point that I got rid of my suspension post. Also a leather saddle will naturally have some "suspension" built in because of the design.
We are also running 38mm, but closer to 80psi due to our rider weight and all of the gear we typically travel with. Going to try a leather saddle as well, but I am skeptical (albeit hopeful) that the saddle alone will solve my issue considering i have already tested several different saddles.
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
Good Luck
Likes For IPassGas:
Quoted: 2494 Post(s)
Liked 738 Times
If saddle sores are the question, a suspension post is not the answer. Saddle sores are caused by abrasion, not impact. They are also usually mildly infected. Padded shorts and chamois butter should do a lot to alleviate saddle sores. Saddle butter is mildly antiseptic. Neosporin seems like a good idea on its face but I wonder about the possibility of culturing an antibiotic resistant strain of something nasty with long term use. For a specific tour, why not, as a routine regimen, probably not. All suspension posts will steal energy from your pedaling effort. Few of us have any watts to spare (waste) heating up the elastomer of a suspension post.
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
Not that I think lower pressure will resolve saddle sores, but lower tire pressure will make your ride better. I'm running 55 psi on 38c tires and don't feel any need for higher pressure and certainly don't bottom out.
just another gosling
Quoted: 3887 Post(s)
Liked 1,938 Times
That's usually caused by the team not standing enough. Try standing for 1' every 10' by the clock. Most teams don't stand as much as they do on their singles. A mluvite tak česky?
The captain is suspended beautifully by tandem frame design, no need for a suspension post anyway.
Results matter
Results matter
