Pet peeves
Old 10-11-22, 03:58 PM
  #51
smd4
Quoted: 3482 Post(s)
Liked 2,903 Times in 1,764 Posts
Originally Posted by FBinNY
That's a flawed syllogism. Dictionaries generally don't include phrases. Tension meter describes the device accurately in the same way as "volt meter" would to an electric
So both are right, but I'll venture that Tension Meter would be clearer than Tensiometer to the uninitiated.
FWIW - "tensiometer" can also mean a device to measure blood pressure, on in another context. something to measure soil moisture content.
Now you’ve done it. I’ve had to add to my pet peeves list.
smd4 is offline
Old 10-11-22, 04:08 PM
  #52
pdlamb
Quoted: 2589 Post(s)
Liked 1,920 Times in 1,204 Posts
Originally Posted by UnCruel
Is it really a road racing bike if it has a bell on it? I think, by definition, the bicycle becomes something else once you put a bell on it, regardless of what it may have started out as.
Not quite racing, but I used to participate in a spirited after-work ride. One of my favorite stunts was to get behind someone who didn't pull off soon enough, and then pass them on the hill at the end of the flat run. If I timed it right, I'd start ringing the bell halfway up and get a disbelieving look over his shoulder.
Fun times!
pdlamb is online now
Old 10-11-22, 04:09 PM
  #53
grumpus
grumpus's Avatar
Quoted: 470 Post(s)
Liked 423 Times in 323 Posts
Originally Posted by SJX426
I know this is a controversy due to the common usage not being specific of the definition, cog vs sprocket. The definitions indicate a sprocket is a subset of cogs with the specific feature of the teeth engaging into a component like a chain and not another cog.
A cog is a tooth on a gearwheel called a cogwheel. A cogwheel engages with another cogwheel. A sprocket is a chainwheel, it engages with a chain. Every time someone refers to sprockets as cogs a kitten dies.
grumpus is offline
Likes For grumpus:
Old 10-11-22, 04:24 PM
  #54
79pmooney
79pmooney's Avatar
Quoted: 4783 Post(s)
Liked 3,904 Times in 2,539 Posts
Webster New Collegiate, 1953. 1) Cog: a tooth on the rim of a wheel; hence , a gear tooth. 2) A person functioning as part of a process or organization.
Sounds to me like any sprocket for chain qualifies. (Yes, I know I can kill small cats with my chainwhip/cog wrench but I like to think they survive my routine gearing changes just fine.)
79pmooney is online now
Old 10-11-22, 04:44 PM
  #55
FBinNY
Quoted: 5756 Post(s)
Liked 2,526 Times in 1,396 Posts
Hey! I've finally made the cut.
FB
Chain-L site
FBinNY is offline
Likes For FBinNY:
Old 10-11-22, 04:50 PM
  #56
FBinNY
Yes. and no. Yes because everyone knows what it's about.
But, No because by the definition YOU cited, the cog is (hey Google, not corgis) is one of the teeth on the sprocket.
FB
Chain-L site
FBinNY is offline
Old 10-11-22, 05:36 PM
  #57
Hondo6
Bikes: Yes
Quoted: 549 Post(s)
Liked 665 Times in 462 Posts
Except one is recognized in a dictionary as the correct name of the device, and the other is a made-up term.
You might want to read up on compound nouns. "Tension meter" is an example of same. So is "swimming pool" or "swimming hole". Or "bottom bracket" and "brake lever", for that matter.
And no, many (if not most) dictionaries of the English language don't exhaustively list all known compound nouns. I daresay that even the Oxford English Dictionary, with over 270k entries, doesn't have all of them listed and defined.
Hondo6 is offline
Old 10-11-22, 05:51 PM
  #58
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 942 Post(s)
Liked 656 Times in 370 Posts
Well it rolls off the tongue a little easier than the proper name sphygmomanometer .
Dan Burkhart is offline
Old 10-12-22, 02:10 AM
  #59
sean.hwy
sean.hwy's Avatar
Quoted: 426 Post(s)
Liked 274 Times in 201 Posts
Originally Posted by squirtdad
another pet peeve cheap alternative chain lube and grease threads, like people are going broke getting a tube of Phil's or a bottle of Chain-L (or whatever else your favorite is )
guilty
something about $1000 an ounce for $30 chain vs say automatic transmission fluid meant to work on 10k transmission and it somehow only cost $1 an ounce.
that's some crazy marketing wizardry
for now I am just using muc off from the LBS
sean.hwy is offline
Old 10-12-22, 04:17 AM
  #60
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 875 Post(s)
Liked 2,297 Times in 1,109 Posts
It bothers me more than it should when people use Campy instead of just typing Campagnolo.
Chuck M is offline
Likes For Chuck M:
Old 10-12-22, 04:22 AM
  #61
DorkDisk
Quoted: 576 Post(s)
Liked 1,000 Times in 488 Posts
"Campag" gets me. There is n "g" sound in "Campagnolo". "Campa" is right
DorkDisk is offline
Old 10-12-22, 04:49 AM
  #62
smd4
When I was first getting into bikes in the mid-80s, l’d go check out bike books from the college library. Many (most?) were written during the 1970s bike boom. “Campy” was apparently a common nickname back then, and I’ve used it. I will agree that “Campag” for me sounds like shifting a bike chain coated in sand.
smd4 is offline
Old 10-12-22, 05:12 AM
  #63
dedhed
SE Wis
dedhed's Avatar
Quoted: 2739 Post(s)
Liked 3,381 Times in 2,046 Posts
Priced ATF lately? Recently changed fluid in a couple 4L60E and got sticker shock. But still not even anywhere near $1/oz
dedhed is offline
Old 10-12-22, 05:15 AM
  #64
SJX426
SJX426's Avatar
Quoted: 1606 Post(s)
Liked 2,211 Times in 1,102 Posts
Is your real name Chuck or Charles?
SJX426 is offline
Likes For SJX426:
Old 10-12-22, 05:33 AM
  #65
daveed
daveed's Avatar
Bikes: Soma Double Cross, ‘79 Centurian Mixte, generic mountain bikes (Nasbar frames)
Quoted: 22 Post(s)
Liked 4 Times in 3 Posts
Did the OP’s run-on sentence bug you?
“It probably doesn't matter much regarding brake or gear cables since the job gets done either way, however it muddies the thinking in things like wheel alignment or building.”
daveed is offline
Likes For daveed:
Old 10-12-22, 07:12 AM
  #66
L134
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 174 Times in 106 Posts
When small bits fall to the floor and roll off to parts unknown.
L134 is offline
Old 10-12-22, 07:19 AM
  #67
RB1-luvr
I don't know.
RB1-luvr's Avatar
Quoted: 312 Post(s)
Liked 848 Times in 443 Posts
^^ that's funny and true. I found two ball bearings on garage floor last night. So I probably have two hubs with the wrong ball count.
RB1-luvr is offline
Old 10-12-22, 07:51 AM
  #68
70sSanO
70sSanO's Avatar
Quoted: 1942 Post(s)
Liked 2,162 Times in 1,321 Posts
You should check out hockey forums. No one can spell half the players names so almost everyone is identified in some abbreviated form.
Heck, even the players use them for each other.
John
70sSanO is offline
Old 10-12-22, 09:30 AM
  #69
sean.hwy
sean.hwy's Avatar
Quoted: 426 Post(s)
I just did my v6 rav4 a few months ago. I bought mt ATV from rockauto. It was not that bad.
$36 / 160 oz = 23 cents an oz roughly
sean.hwy is offline
Old 10-12-22, 09:58 AM
  #70
squirtdad
squirtdad's Avatar
Quoted: 2336 Post(s)
Liked 2,804 Times in 1,532 Posts
guilty
hmmm some how the math is not working on the $1000 an oz
Rock and roll gold $8 for 4 oz so $2 an oz for purpose designed product
Chain-L $12 for 4 oz so $3 an oz for purpose designed product
at the hi end
Silca super secret at $45 for 8oz so $5.64 or so an oz
squirtdad is offline
Likes For squirtdad:
Old 10-12-22, 10:17 AM
  #71
sean.hwy
sean.hwy's Avatar
Quoted: 426 Post(s)
at the hi end
when I did the real math ATF comes out to 23 cents an oz vs your cheapest $2 oz for rock and roll gold. That's 9 times more expensive for $30 chain that only last 100 to 150 miles vs 23 cents an oz for auto trans that cost 10k, run at high heat and high pressure and is good for 100k miles.
Seems like the chemical eng that designed auto oil and auto trans fluid should design bicycle chain lube :-)
sean.hwy is offline
Old 10-12-22, 11:18 AM
  #72
Troul
Troul's Avatar
Liked 2,936 Times in 1,900 Posts
I try to keep that in mind when responding to questions from folks that seem not to know.
If I did that, that could result in a lot of work on my end.
-Oh Hey!
Troul is offline
Old 10-12-22, 11:20 AM
  #73
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1938 Post(s)
Liked 1,460 Times in 1,011 Posts
The article linked below states that "cog" is a broader term that covers a "sprocket."
Space-age engineering: How the Jetsons undermined the understanding of an entire (gear) industry (motioncontroltips.com)
SoSmellyAir is offline
Old 10-12-22, 11:23 AM
  #74
SoSmellyAir
Smells good and glows with the included LED keychain.
Likes For SoSmellyAir:
Old 10-12-22, 12:03 PM
  #75
grumpus
grumpus's Avatar
Quoted: 470 Post(s)
"Thus, a gear is a cog … but not all cogs are gears."
That's backwards - a cog is a tooth on a cog wheel, a cog wheel is a gear wheel, a sprocket is a gear wheel, but a sprocket is not a cog wheel and sprocket teeth are not cogs because cogs engage with cogs not chains.
grumpus is offline
