Beyond MegaRange: Extending 7-speed Cassette Range?
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
You know, the OP never gave his bike or front chainring setup. What is the application? Some kind of specialty bike or hand crank? 23 posts engineering a solution for which there may be a different problem. Maybe a triple up front would do the trick?
Passista
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Quoted: 866 Post(s)
Liked 720 Times
What is the practical limit for low gears? I haven't too much experience about it, but I found 22/28 enough for all hills, mostly because lower than that would've been too slow to keep upright.
-- The 'practical limits' of gearing for a bicycle and 'Practical' is in the mind of the needer; Probably a 10-42T 11-speed cogset with a 14/60T quad chainring crankset, although I am not at all sure what one would do with it or how one would really shift it. Can Google on SRAM and Mountain Tamer for a thread to pull on those.
-- Now as to what folks feel they need or even perhaps really do need for some bit of riding they do or might want to do (or maybe for tree climbing???) who knows. But I doubt that any extreme capability that could be assembled would not find a friend in need somewhere.
/K
Practical limit for low gears on a 2 wheel bike is so low you fall over ..
or lose all the momentum starting up, in half a crank rotation.
I have a Mountain Tamer Quad , 16t, if any one wants to try , Ill Sell It..
a Tadpole trike it can be quite low, to tow heavy loads slowly up a hill ..
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
RUSA #7498
Originally Posted by noglider
Given that casual bikes have none of the need of racing bikes for fine gear changes, but do benefit greatly from both simplicity and big gearing range, I was investigating the possibility of achieving approximately the range of a 21-speed triple with a single chainring.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Big jumps between gears at the higher end of the range are painful, whether you're a racer or just a regular guy trying to maintain a 20 mph cruise in variable conditions. If 20 mph is a speed you would only hit in bursts or downhill, them you don't need the big chainring on a triple.
Tried a 16 : 28 in a mtb, that is a gear more suitable to recumbent trikes , being so Low, 0.57:1..
Liked 2,563 Times
There are a lot more options for wide-range cassettes (like 11-34) in 8-speed and up -- to make this dream work, you may need to upgrade...
RUSA #7498
Passista
Quoted: 866 Post(s)
Liked 720 Times
SRAM XX1 11 speed-single chainring uses 10-12-14-16-18-21-24-28-32-36-42 and a 28, 30, 32, 34, 36 or 38 chainring. With the 28, development is 1.4 - 5.9m (17.5 -73.6 G.I.), with the 38 1.9 to 8.0m (23.8-99.9 G.I.).
Quoted: 392 Post(s)
Liked 49 Times
Put the Schlumpf planetary crank on my Brompton. the cranks are not connected to the chainring,
but instead power passes through a planetary gear. So Its one chain ring but acts like 2 ,
as if say; a 50t. 20t combination
the gear in low is a 2,5:1 reduction gear.. Then, the cranks turn faster than the chainring.
No Cable or levers, Tap a shuttle button running between center caps, with your heel, to shift. .
the reduction gear allows a 3 speed hub to be used twice, for 6 distinctly different gears...
offered in 110 and 130 chainring types. then , Sturmey Archer hubs can climb the Swiss Alpine roads.
Bikes: SGM Charles Jerry 26er
Quoted: 14 Post(s)
Thats something new for me. So you can use a 48-36-22 without any proboems with the FD? Ive read somewhere from Shimano that you the max gear difference is 10-12T, for example 40-32-22 or 48-36-26. If that's possible, I'll try working that out.
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
I know this is a super old thread, but for those who are tracking stuff like this, Rivendell is selling cassettes made by S-ride that meet the description. 11-36, 13-34, and 13-42...all 7-speed. I think these are relatively new in terms of availability, so many may not know about them.
https://www.rivbike.com/products/cassettes-7
Shimano derailleur specs are reputedly fairly conservative. A 20-22T max difference is common spec for newer Shimano triple FDs as I recall, so a 26T difference may well be do-able if the proverbial stars align.
I've never pushed a FD beyond spec, so I can't address that from personal experience. But I have used a Shimano RD a bit past its specs without issues.
