rim joint not opposite valve hole
Quoted: 1106 Post(s)
Liked 1,326 Times
Just noticed on a pair of rims - Weinmann 27x 1 1/4" - that the welded joint is not opposite the valve hole; they're both 36 hole rims; one has 16 spokes from joint to hole, one has 9.
Dammit.
Now I have to go look at all the other rims too.
Dammit.
Likes For oneclick:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
I wish you hadn't posted that.
Likes For non-fixie:
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,469 Times
What an unsettling development.
next you’re going to tell me that when you look through the valve hole of the built-up wheel you see the back of your head!
Brent
Brent
Likes For obrentharris:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Didn't you know they balanced them at the factory?
(if anyone is reading this ten years from now, that is a joke and I'm no authority on forty now, fifty at your reading year old wheels)
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 2588 Post(s)
Liked 4,824 Times
Must....resist....checking......
DD
DD
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
So, let's say you worked in the Weinmann factory some years ago and you're just back from lunch on a Friday and you think, "Time to mess with a few heads in the future. I wonder how long it'll take until someone notices this."
Likes For mdarnton:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
With the rarity of rim supply nowadays, I'd be happy to get one with the number of holes divisable by 4...
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
Isn’t the title of the thread backwards? I mean, once you say, “the valve hole isn’t opposite the rim joint,” it doesn’t sound so bad, does it?
Liked 2,446 Times
Letting @oneclick know he's not alone with this rim thing, I dug out my only-est Weinmann-rimmed bike to check out this non-diametrical inconsistency. This little bike is a Condor made in Switzerland and is a ladies' 3-speed with 700C alloy rims, the non-dimpled Weinmann 210. The OP did not provide a pic or model of his own rims but they could well be the same model in 27". Lots of bikes wore these back then.
With the tires deflated I went around the circumference of each rim until I found the ground part that should indicate the finished joint weld. Did not bother to remove the tire, tube and rim strip for better pix but trust me, my thumb is adjacent to the joint and you can see that the valve stem on each wheel it not exactly opposite. This must be a thing but I ain't gonna lose sleep over it.
Liked 1,326 Times
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,391 Times
Liked 2,446 Times
At this point someone will probably suggest you cut one open for a good cross-section photo.
