Projecting how I'll fare in the mountains
Quoted: 176 Post(s)
Liked 57 Times
I've never biked in the mountains, but I'm in Asheville, NC, this weekend. Went out on a 25-mile ride today, but somebody forgot to tell me the route had a gravel road, so I had to abort the original route after about 5 miles and free-lance for a while to get in some work.
So, I've found a replacement, a 33-mile route that climbs 2700 feet. Around where I live, a 33-mile ride typically would climb about 1,100 feet, and I can complete it in about 2 hours, maybe 17 mph if I'm feeling good and conditions (wind, temperature) are not unfriendly.
Given that info, how long would you guess it would take me to do the mountain route? (I realize that 'mountain' is relative, so I hope that climb doesn't offend those in the Rockies, or more serious Appalachian climbers.)
Looks like rain tomorrow, so I probably won't be able to test it, but I get over here from time to time, so hopefully it's in my future.
Quoted: 850 Post(s)
Liked 344 Times
It depends a lot on how steep the climbs are, how technical the descents are, and how much traffic you hit. Ie - how much you brake.
Flatter rides I average somewhere around 18 but I've averaged around 12 for some hilly rides. I'd say 14mph is probably a good worst case estimate.
Likes For smashndash:
Quoted: 1814 Post(s)
Liked 923 Times
You're not 'in the mountains' below ~4,000' IMO, where altitude starts to be a factor.
'Hilly' is a better term, which starts at 100'/mile, again IMO.
smashndash's numbers look good.
Likes For woodcraft:
Quoted: 6178 Post(s)
Liked 4,796 Times
Check the rides people make public on RWGPS, Strava, MapMyRide, Garmin Connect and other sites around you. If you find some that ride the same routes you currently do as well as the routes you want to do, then you can make comparisons to you based on your stats.
Those sites will also let you look at the route profile and see where the steeper grades are. But don't go by the graph as the x and y scale are way out of kilter from each other. Hover your pointer over the section you are interested in to see the grade slope it is.
Likes For Iride01:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
3 hours? A little more?
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Quoted: 6945 Post(s)
Liked 10,945 Times
Likes For Koyote:
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
Coming from flatlandia (coastal SE Virginia) and riding in and around Asheville didn't give any major issues. Just make sure your gearing is appropriate.
Now, going somewhere with far greater elevation? That was a kick in the lungs. Going out to SD around Rushmore was a shock. The difference in the availability of oxygen at ~6200' was very eye-opening. And then riding in Yellowstone up to ~8500'? Lots of ouch was had those days.
Quoted: 1455 Post(s)
Liked 1,477 Times
Similar question - Has anyone here rode Vail Pass from Breckenridge?
I live in Chicago and am planning to visit in August and want to do a little riding while I'm there. The Vail Pass route looks cool to me because it's entirely on a trail so I don't have to worry about motorists. It's 41 miles with 2300ft of climbing, which on its own doesn't sound too intense, but the summit is 10,600ft.
Am I crazy to think that I can do a ride like this 2-3 days after I land? For context, a typical 40 mile ride in the Chicago area will have around 300ft of elevation gain (most of that is overpasses/bridges). I'm a reasonably fit cyclist, but the only significant climbing I do is on Zwift.
Quoted: 1851 Post(s)
Liked 678 Times
It depends on the route.
2700 feet over 33 miles really isn't that much climbing. It really depends on how steep the climbs are, and in Asheville, they can be very steep or fairly mild.
climber has-been
Quoted: 3417 Post(s)
Liked 3,546 Times
You'll be slower at that elevation (we all are). But if you're not suffering from any AMS symptoms (headache, etc.), and you don't overexert yourself, you ought to be just fine. If you're feeling out of breath, take a break.
Get lots of sleep, drink plenty of water, and avoid alcohol.
Ride, Rest, Repeat. ROUVY: terrymorse
Quoted: 892 Post(s)
Liked 2,053 Times
Grade and gearing make all the difference. Three hours unless you're over geared, in which case all bets are off.
Quoted: 18404 Post(s)
Liked 15,496 Times
Liked 1,477 Times
And the next day you can ride up to Hooiser Pass (11,542'). Only about 2,000' of climbing from the center of Breckenridge but higher than Vail Pass. Start early before traffic. Get a photo next to the pass sign. It's a staple for those who ride ACA's Trans America route. I rode part of that route during a self contained tour from Seattle to Cortez, CO.
Liked 15,496 Times
I started out from the HI Hostel in town with a Mennonite couple I had met on he road and been travelling with off and on for about a week. We started at dawn because they had an 80+ mile day ahead of them. They were riding a Bike Friday tandem pulling the suitcases it packs into as a trailer. Incredibly strong couple. I fell off the back about 4/5 of the way up but managed to claw my way back by the summit. Somewhere at home I have the photo they took of me in front of the pass sign. We descended together to Fairplay then went our separate ways. They continued east towards Pueblo and I turned south to go over Trout Creek Pass.
