Mikado Cyclotoureur
Mikado Cyclotoureur
Is this bike worth $270 CAD to do long distance touring.
Bikes comes with all the accessories lol.Cannondale front bag
• Rear aluminum luggage rack
• Bottle holder
• Zefal HP pump
• Bike stand
• Straps for feet
• Reflectors
It has 27 inch wheels, which I think will need to be changed if I do touring on it and has 12 speed and is 22.75 inches. I obviously do not neither accessories. Owner is getting old and bike has mostly in the basement last 20 years except few rides and tune up. I have seen other Mikado Cyclotoureur but with 3x drivetrain. I found another place selling the frame and fork https://recycliste.ca/en/bikes/used/...lotoureur.html for $250. I think I am getting a good deal but not sure if the parts are any good
• Bottle holder
• Zefal HP pump
• Bike stand
• Straps for feet
• Reflectors
Quoted: 4722 Post(s)
Liked 3,036 Times
I wouldn't be doing grand Touring on this bicycle. The gearing isn't wide enough.
Likes For T-Mar:
Bikes: N+1
Quoted: 227 Post(s)
Liked 645 Times
It looks like the brake pads are all the way down in the slot -- you might have an issue with fitting 700c wheels -- get a measurement on reach and be sure a Tektro long reach will fit before buying. I'd also replace that crankset and bottom bracket with a triple for touring -- or at least replace the crankset with a compact double to get a bit lower gearing. The bike is not bad -- it's a nice sport touring bike -- but not ideal for loaded touring. Once you start adding costs of changing wheels and cranksets you might be better off passing on this and looking for a slighly newr 700c tourer, ideally with cantilever brakes and a triple, plus perhaps braze-ons for a front lowrider rack.
Likes For ClydeClydeson:
Quoted: 581 Post(s)
Liked 921 Times
Also, 27" wheels are fine if you have tires, and there are still a few decent 27" tires available. Another option, if you are dead set on swapping to 700c wheels, is to find some brakes with slightly longer reach. Modern dual-pivot caliper brakes are far superior to Weinmann centre pulls.
Liked 3,036 Times
Good eyes! Blowing up the photo shows what appears to mounting holes for a granny chainring. Still, I think the Velo Sport Alpin that I pointed out in the OP's other thread is a better value, even though it's $100 CDN more expensive, It has triple crankset w/granny, cantilever brakes, dual bottle bosses, and comes equipped with front rack, rear rack and fenders. Both use the same frame material and were almost certainly manufactured by the same company.
Quoted: 1081 Post(s)
Liked 681 Times
In addition to what's been mentioned, if you want to turn this into a touring bike you'll probably want wider gears in the back, and that's a short-cage derailluer. So that will need to be changed as well. Frankly this bike doesn't look like a good candidate - too many changes need to be done to turn it into what you want.
