What's worst than a seized seatpost?
Bikes: 1994 Cadex CFR3, 2006 Scott CR1 SL, Rossin aero, Bertrand GB 2000, Spec Allez Pro
Quoted: 134 Post(s)
Liked 68 Times
Having your LBS to work on it and ...
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
Did they charge you to do that?
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
Bikes: 2020 Lynskey GR300, 1987 Diamondback Ascent, 1991 Skykomish Marble Point, 1994 Specialized Stumpjumper FSR, 1996 Specialized Stumpjumper M2 FS, 1992 GT Karakoram
Quoted: 69 Post(s)
Liked 226 Times
Quoted: 134 Post(s)
Liked 68 Times
No they didn't! Great people actually. Just sucks for the frame..
Edumacator
Quoted: 2434 Post(s)
Liked 3,109 Times
Wow. That is truly stink-eriffic
Quoted: 576 Post(s)
Liked 1,001 Times
Sometimes there are no winners
Quoted: 2362 Post(s)
Liked 1,749 Times
Photo is from an outside site associated with spy-gle, that probably requires an account / login. Doesn't show up from an anonymous device/browser. Such issues go away when one uses the BF-hosted gallery system
Quoted: 957 Post(s)
Liked 1,619 Times
Rats
Quoted: 964 Post(s)
Liked 1,451 Times
Oh man, they must have really done a number on it. Those Canada Pugs are usually tough as nails!
mycocyclist
Quoted: 910 Post(s)
Liked 811 Times
Perhaps Mercifully...
...I see nothing.
(My answer was going to be "...a stuck seatpost, stem, and bottom bracket." (Each of which I managed to free over a two week period.) Haste makes waste.)
Likes For jonny7:
Liked 1,749 Times
OUCH! That won't buff out.
Quoted: 331 Post(s)
Liked 332 Times
The reason you don't use a gas torch to burn out the post or expand the seat tube is you want to preserve the paint If you're going to use enough force to break the frame you obviously don't care about the paint work. So what gives? A wet towel will restrict paint damage down to six inches from the post clamp no matter how much you cook it.
Quoted: 177 Post(s)
Liked 114 Times
It really wasn't much of a joint anyway. Looks like it was just butted and brazed, with no lug and very little filler material. I'd forgive the shop for the poor outcome. On the other hand, it would be easy to rebraze it.
My C&V Bikes:
My C&V Bikes:
Edumacator
Liked 3,109 Times
Is that one of those internally "inexternal" brazed guys? Or just a fillet braze?
Quoted: 4722 Post(s)
Liked 3,036 Times
Quoted: 1105 Post(s)
Liked 1,326 Times
For most frames the main usefulness of lugged construction is economy. The tubes can be cut with no or little regard to angle and mitres, and the lug takes (some/most/all) of the actual stress at the joint - the metal there doesn't have the thickness of lug+tube,
Brazing works because the bronze alloy forms a solid solution with the surface of the base metal. Within limits, the closer the fit, the stronger the bond. Lugs are often a fairly sloppy fit, sometimes deliberately so.
The quality of brazed joints is undeniably variable, especially considering the market at which Peugeot was aiming.
So because they had the resources and production capability to make accurately mitred joints with tubing to their own specs they had something to work with.
Edumacator
Liked 3,109 Times
So that could be a reasonably easy fix without the lug to worry about?
Quoted: 964 Post(s)
Liked 1,451 Times
I dunno - those stays look tig welded. Canada-made Pugs I've seen are from after the "internally brazed" era, and are tigged. But we can't see an intact joint on the bike to know for sure.
That said, based on the one picture and a small amount of optimism that the rest of the joint is cracked similarly, any framebuilder or really anyone competent with a torch could make quick work of fillet brazing that back together.
Quoted: 134 Post(s)
Liked 68 Times
How would one determine the nature of the joint? And the feasibility of the reparation?
