Tight crown seal on Cane Creek Headset
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I just got a frame that came with a CC40 lower headset (for a tapered fork). I'll be waiting on the fork for a while.
I was checking the bearings for smoothness and proper mating with the cups and I notice that the rubber seal on the crown race drags really hard on the lower bearing.There is no metal on metal friction, just a lot of rubber friction. Like really tight seals (which I guess is what this is)
Is this normal? Is it something that goes away with use?
I've have other CC headsets with the same design of crown race with the rubber seal (all were for 1-1/8" straight steerers) and all those turned pretty freely, just the slightest seal drag.
Thanks
Thanks
Quoted: 4201 Post(s)
Liked 3,857 Times
Have you pulled the lower bearing's seal? Is the grease in good shape?
When new, seals have more range of tight fit than the internal bearings do. So, this might be within normal specs. Generally, once installed and the bike assembled tight seals are not noticed during the ride. Andy
AndrewRStewart
AndrewRStewart
Advanced Slacker
Liked 2,537 Times
t the issue is the drag of the seal on the crown race against the bearing. Cane Creek headsets have a crown race with an integrated seal.
Quoted: 2026 Post(s)
Liked 1,096 Times
I have Cane Creek 40 headsets on two bikes and, yes the seal on the crown race does drag noticeably on the edge of the lower cup. However, you will never notice it while riding and it does serve to keep dirt and water out of the bearings, I consider it a feature, not a bug.
Advanced Slacker
Liked 2,537 Times
