Recommended 650b conversion set up
Quoted: 5 Post(s)
hi - i'm looking to convert a vintage steel road bike into a more comfy bigger tired city bike for my friend. weight matters since we have a lot of stairs and am hoping for ~23 pounds with the new wheels and a rear rack on it - around 53 or 54cm bike size. a few questions;
a. what's the best 650b tubeless compatible wheelset for a reasonable price (between $200 and $350?)
b. what are some especially good slick ~45mm 650b tires for dealing with the broken glass parts of brooklyn?
c. any suggestions on the best bike for this - have been looking on craigslist and ebay for trek 613, 400 - miyata 712, etc? since i'm also hoping to put riser bars on, wondering if i should just buy a frame and then a bike shop to build it up for me - or i could get a full bike and just change it in bits.
hope you're well and thanks for any suggestions.
Quoted: 64 Post(s)
Liked 5 Times
It's another $100 out of your price range, but the pacenti brevet wheelset is pretty light and tubeless ready. If you've got some hubs (and can find the brevet rims in stock) you can build up the wheels for a lot less.
There's a ton of glass in my area and I'm yet to get a flat on compass tires. I have a lot of miles on them with the rears very bald. The gravel kings are supposed to be pretty good and they're a bit less money.
Don't have any recommendations for frames, but I can tell you the mid 80s univega gran rally and miyata 912 will fit 38mm, but not 42 without crimping the chainstays.
bOsscO
Bikes: 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 293 Post(s)
Liked 353 Times
I'm not sure if the Trek 613, 400, or Miyata 712, 912 came stock with 650b or 700c wheels. Probably good to start with a bike that's built for 650b otherwise you'll need to consider different brake calipers too.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Good luck finding vintage steel that will take 650bx45. It's a rare one that can take 42s. A complete bike down to 24lbs with a rear rack? What's it weigh now? Probably going to take a lot of weigh-weening to get to that point. Don't forget to make sure to choose rims with a braking surface as you won't find any disc brake mounts. So hmmm, rim brakes and tubeless, that should narrow it down to about 3 rims currently on the market. That Pacenti is probably the only one you'll find as a pre-built wheelset.
Why don't you just get a nice, late model alloy gravel bike.? Probably get the weight you want, wheels and clearances you want.
Quoted: 752 Post(s)
Liked 733 Times
Sounds like your trying to build a mountain bike.
Quoted: 5877 Post(s)
Liked 3,445 Times
Quoted: 5 Post(s)
true - i'm riding a trek 970 mountain bike and if i find one like it for her, that would be fine - but i think the road bike conversion might save 2-3 pounds or so.
the pace breveti wheelset is out of stock for at least 10 weeks, thanks for that suggestion though.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4670 Post(s)
Liked 5,769 Times
If you look carefully and are patient, lightweight MTB frames can be had, but you'll need a lighter fork to have a chance of getting the weight down where you're looking to be. Really 2-3 lbs extra isn't much extra to carry. I used to carry a Fisher MTB tandem up 3 flights of apartment stairs in San Francisco BITD.
Liked 3,445 Times
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
My conversion only fits 38mm tires, and that with careful attention to wheel true and frame alignment.
Likes For ThermionicScott:
Quoted: 964 Post(s)
Liked 1,450 Times
Likes For scarlson:
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
Google will be your friend too if you find a neat frame that looks like it could use a conversion. I like the late 70s/early 80s Treks but of course didn't actually convert mine (yet?), instead my LeMond is sporting 650x38b (for now at least). Quite a few people fit nominal 42s (actual around 40) on the Treks of that period. Search far and wide though and be prepared for some disappointment. gugie has a lot of knowledge in this area - especially if you like Raleighs...
Liked 5,769 Times
32 hole are somewhat available (SOMA - Weymouth, Rene Herse - Pacenti), 36 hole anything seems to be very difficult to find.
Liked 2,560 Times
In stock, you mean? They are definitely being made.
Quoted: 3788 Post(s)
Liked 6,574 Times
These days it seems you need to roll your own (or have your LBS build the wheels for you), i.e., source 650B rim-brake rims (dwindling options!) and QR hubs and spokes, separately.
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
To repeat what @Dylansbob wrote, it's damn near impossible to find a road frame that will fit something fatter than a 650b x 42mm tire without major modifications. Add to that your weight and budget requirement, I think you're looking for a unicorn.
Liked 3,445 Times
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 162 Post(s)
Liked 337 Times
Google will be your friend too if you find a neat frame that looks like it could use a conversion. I like the late 70s/early 80s Treks but of course didn't actually convert mine (yet?), instead my LeMond is sporting 650x38b (for now at least). Quite a few people fit nominal 42s (actual around 40) on the Treks of that period. Search far and wide though and be prepared for some disappointment. [...]
I'm running Pari-Motos on my Trek 710 — 42 in the front and 38 in the rear with no modifications. Both come in about 3mm below their stated size on the Cycles Toussaint 650b wheelset. I'd originally planned to switch to the Gravel King SS or slicks, but a bike shop told me the Pacenti's had the same tread pattern (as the slick), so I figured it was silly to switch. I've been very happy with the Pari-Motos. In the future, I'll probably go with whichever I can find cheaper.
Liked 2,560 Times
Quoted: 161 Post(s)
Liked 267 Times
