Where to buy a prebuilt 27" dynamo hub wheel?
Old 07-09-21, 02:45 PM
USSZim
I absolutely love dynamo hubs and want to put them on my vintage bikes that are running 27" wheels, but I can only find prebuilt 700c wheels. Does anyone know of any places selling prebuilt 27s?
USSZim is offline
Old 07-09-21, 02:56 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
https://www.prowheelbuilder.com/rims/shopby/27in.html
Prowheelbuilder.com carries 2 27" rims they can build with dynamo hubs.
tyrion is offline
Old 07-09-21, 03:21 PM
CliffordK
CliffordK's Avatar
Quoted: 18371 Post(s)
Liked 4,507 Times in 3,350 Posts
You can always build your own (or find a local shop to do it).
The SON hubs would look nice on a vintage ride.
Shutter Precision makes a SON clone.
Velo Orange sells a good vintage looking double walled 27" rim.
CliffordK is offline
Old 07-09-21, 03:36 PM
USSZim
Yeah, the local shop quoted me $120 to do a wheel rebuild, I was trying to see if there was a more economical way to do it short of me doing to the build
USSZim is offline
Old 07-09-21, 04:12 PM
nlerner
Quoted: 3807 Post(s)
Liked 6,676 Times in 2,607 Posts
Is that just for the labor if you supply the parts or are parts included?
nlerner is offline
Old 07-09-21, 06:55 PM
Dylansbob
2k miles from the midwest
Dylansbob's Avatar
Quoted: 525 Post(s)
Liked 931 Times in 446 Posts
Soma had dirt cheap (like $21) dynamos for sale recently. Get yourself a decent Alex rim and spokes and be done for under $100.
Dylansbob is offline
Old 07-09-21, 11:00 PM
USSZim
I'd need to check again, but when I called and asked about a wheel rebuild they made it sound like it was $120 for the labor
Woah! Got a link?
EDIT: Nvm, found it: https://www.somafabshop.com/shop/cat...ubs-dynamo-792
USSZim is offline
Old 07-10-21, 02:52 AM
Lazyass
Quoted: 2432 Post(s)
Liked 638 Times in 395 Posts
Like someone said, go to Pro Wheel Builder and click on their "custom wheel program". You can select each individual part and they'll give you a total price and weight. You can send them hubs and rims if they don't carry what you want and they'll lace them up for you as well.
Lazyass is offline
Old 07-10-21, 05:58 AM
tcs
Palmer
tcs's Avatar
Quoted: 1661 Post(s)
Liked 1,814 Times in 1,054 Posts
Vintage bike, NOS vintage 27" rim, NOS vintage Dynohub™️:
tcs is offline
Old 07-10-21, 07:03 AM
Doug Fattic
framebuilder
Quoted: 615 Post(s)
Liked 1,914 Times in 655 Posts
Standard shop labor is $60 an hour and my guess is that they figured it would take them a couple of hours to build. I've built hundreds of wheels (maybe thousands) but i don't do it every day so when I do and get all organized to build one (including clearing off some space and getting all the tools out), it probably takes me a couple of hours. Little details can add up like figuring out spoke length and dipping the threads in prep and wiping off just the right amount and then letting them dry.
You might consider doing the labor intensive parts of the build yourself and then let an experienced shop worker do the final truing. Almost anyone can do the wheel lacing if they can follow directions (although it is easy to get spokes in the wrong holes). It is necessary to put a little grease in the rim hole and spoke prep on the spoke threads first. The next step is to take all the slack out of the spokes (usually this means tightening the end of the nipple until it is right at the end of the spoke threads). Then you can take it to someone experienced to finish it off
Doug Fattic is offline
Old 07-10-21, 10:27 AM
ironwood
Bikes: 1984 Bridgestone 400 1985Univega nouevo sport 650b conversion 1993b'stone RBT 1985 Schwinn Tempo
Quoted: 542 Post(s)
Liked 152 Times in 100 Posts
Why not get a 700C wheel? You would only have to lower the brake pads 4mm . Otherwise try building it yourself, it isn't that hard.
ironwood is offline
Old 07-10-21, 01:01 PM
bark_eater
Quoted: 753 Post(s)
Liked 737 Times in 422 Posts
I hadn't looked at the Pro Wheel Builder site before. Unless your reusing rims and spokes, I don't think you could do it your self cheaper.
bark_eater is offline
Old 07-10-21, 10:43 PM
USSZim
Same, that is looking like a good option right now
USSZim is offline
Old 07-11-21, 07:32 AM
RustyJames
Quoted: 566 Post(s)
Liked 1,047 Times in 542 Posts
Given how overwhelmed bike shops are, $120 seems quite reasonable. Work with the builder using recommended spokes etc., which he/she will likely be selling, and pay them for their skill. If you tackle the job yourself and it doesn’t go well that $120 plus parts will seem VERY reasonable. YMMV
RustyJames is offline
