Cable standoffs on a coupled tandem
In constructing a custom steel framed tandem with S&S couplers to ease transport,
we found that off-the-shelf cable guides (brake, shift) did not permit the necessary cable splitters to clear the S&S frame couplers.
Don't other builders using S&S couplers have this problem?
Here is our solution.
Kudos to Jay Borden of Roulez Cycle, Lynn MA. Our framebuilder, problemsolver, and machinist extrodinaire.
cable splitter ends hung up on the S&S coupler
machining cable guide standoffs from 0.5" steel plate, using hole saws to machine inside and outside radius.
test fitting the standoffs. cable guide tacked to each. The original brazed guides on left of photo were removed.
final build showing the cable guide system on bottom tube.
Quoted: 4197 Post(s)
Liked 3,849 Times
Here's how I handled it. In this frame's case the cable coupler was to be ahead of the S&S coupler and the clearance issue was with the cable housing passing by the S&S to the rear caliper. I made a short stand off from a 1/4" tube. I have done this "stop on a stand off" thing many times, the most recently to route a brake cable about the BB shell and provide a barrel adjuster at the top of the down tube, both times to not interfere with the two gear cables. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Randomhead
Liked 3,693 Times
It wouldn't have helped the OP, but I thought Paragon used to sell stops that would clear an S&S. I went looking for them recently and didn't find them. There are some Asian sourced stops with standoffs, but I don't think anyone in the U.S. carries them any more.
