Show us your gravel/cross bike...
#5301
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
tFUnK What top tube bag/case is that? Please send link.
#5303
WV is not flat..
I am getting ready to start a build using this 2007 Redline Conquest Pro frame. It's been educational watching this thread for some great ideas. I am curious about everyone's thoughts on a short travel front shock instead of a rigid fork. Any pros or cons?
Likes For brandenjs:
#5304
Habitual User
Quoted: 4926 Post(s)
Liked 8,052 Times
Cons: Heavy
Are there short travel front 700c forks with v-brake/canti mounts? Or would you go to a cable disc brake on the front?
#5305
Liked 1,463 Times
#5306
WV is not flat..
#5307
WV is not flat..
I will probably stick with the cantis if I can. Disc would be nice, but no mounts for the rear. I've just never seen one set up with a shock, but as long as it is one similar to one on a Trek 7700 or something like that with shorter travel seems like it would be comfy.
#5308
Liked 1,463 Times
#5309
Habitual User
Liked 8,052 Times
Another option for front-end comfort is a Redshift suspension stem.
#5310
Quoted: 425 Post(s)
Liked 452 Times
I've entertained the thought of putting a short travel 26er suspension fork on a cross frame. With a 26x2.1" up front and a 700x38 in the rear, it should balance out well.
Likes For tFUnK:
#5311
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
My thoughts for others- if you are concerned the surface will be too uncomfortable, and/or if you are unable to use your arms and legs as suspension during the rare times when a road is too rought to sit(like washboard), then perhaps a suspension fork is a good idea.
Are there rim brake short travel suspension forks that are good quality? I really dont know- seems like thats a specific use case that wouldnt have been popular pre-disc, but thats a total guess.
Also to consider- what offset will the fork have vs what offset do you want for steering and feel?
Likes For Noonievut:
#5313
WV is not flat..
My thoughts for myself- zero interest in a heavy fork that has very little travel and is constantly compressing when I stand to climb. I dont need that type of suspension to ride gravel roads and dont want to deal with the downsides.
#5314
Quoted: 1391 Post(s)
Liked 1,852 Times
also prefer rigid forks - recommend suspension for off road use only
when I look at vintage MTB’s - I basically look for models with the original rigid fork
having said that - I have a hybrid with a Headshok and a gravel bike with a Lefty suspension fork (grin) ... double recommend against them - but there are times when I appreciate them
again - recommend rigid - but one suspension fork for 26” vintage MTB that you might consider is a Rock Shox Judy SL ... ? if you can find one in great condition (?)
I have a Judy SL on one bike - it still works (unlike forks on some of our other bikes including early Manitou elastomer forks)
one friend we currently ride with will ride a MTB with smooth tires and a Judy SL when we ride fire roads etc
Judy SL is relatively light at around 1220 g ; some of the vintage rigid steel forks weigh approx 1000 g so the weight penalty is relatively minimal (weight of the rigid fork + suspension stem weight will often be greater than the weight of a Judy SL)
Likes For t2p:
#5315
This could be an option... And a fairly cheap one at that.
Bontrager SPA Hybrid Suspension Bike Fork
#5316
Liked 1,852 Times
#5317
Quoted: 425 Post(s)
Liked 452 Times
Likes For bOsscO:
#5321
Bikes: 2021 Salsa Warbird, (Specially Love my) 2021 Salsa Cutthroat, 2012 Surly LHT, 2015 Surly Cross-Check, 2008 Giant OCR A1, 2005 Leader 735R, 2005 Gary Fisher Montare, 1991 Nishiki Pueblo,
Quoted: 84 Post(s)
Liked 56 Times
Not the best pic, but isn't this a beauty? I'm thinking maybe replace the handle bar tape with some shade of blue color and a brown saddle, what do you guys think? Also; does anyone know where i could find grx hood covers in brown color to match the new brown color saddle it'll be getting soon? Thanks 🙏
Last edited by Eds0123; 03-28-23 at 03:57 PM. Reason: making it more readable and punctuation
#5322
Habitual User
Liked 8,052 Times
Bike pic tip: Take your pic of the drivetrain side. It's more interesting
#5323
Quoted: 84 Post(s)
Liked 56 Times
what does everybody think of blue bar tape for this frame please? Thank You
and started by saying " not the best pic" but FYI frame is Salsa warbird, Shimano GRX 800, Tubeless 42 mm tires, etc.
#5324
Habitual User
Liked 8,052 Times
Correct, Always drive side pic, eliminate valve stem from the pic, Align the rim label with true label, etc,
Do what you think looks good. It's your bike. If it was my bike, and I wanted blue bar tape, I would try to echo that color somewhere else on the bike, like the seatpost clamp. As for brown GRX lever hoods, I'm doubtful anyone makes them, but would guess that Aliexpress or eBay are probably the most likely places.
#5325
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
Correct, Always drive side pic, eliminate valve stem from the pic, Align the rim label with tire label, etc,
