RIP Super Record Front Derailleur...
Old 09-12-18, 06:01 PM
malcala622
malcala622's Avatar
Quoted: 1199 Post(s)
Liked 1,354 Times in 716 Posts
I spent some time today with the Giro build figuring out what to do next...what bar tape to use...what tires to buy...what color housing to choose.
As I fiddled with the front derailleur and noticing some grime and dirt on it I started cleaning and removing the limit screws. That was until i heard something snap. The limit screw broke off with half the screw still inside.
Another bonehead move I took it apart but couldn't get a clear path use needle nose pliers to attempt extracting the screw.
Well now its 20 minutes later and the screw is out but the threads are stripped and im pretty sure ive committed homocide. No longer does the derailleur have threads to hold new limit screws.
A question i have is if the front cage, bolts, screws and cage are of some value to others.
A moment of silence please........
Thank you.
malcala622 is offline
Old 09-12-18, 06:49 PM
Old Yeller
Old Yeller's Avatar
Bikes: 1987 Trek 1500, 1989 Pinarello Montello, 1998 Trek 7000 MTB
Quoted: 7 Post(s)
Liked 5 Times in 5 Posts
Yes, a handy person could chase the threads and replace the screw or drill out
Yes, a handy person could chase the threads and replace the screw or drill out and use a larger screw. The body is somewhat sacrificial because the cage and arms come off without drilling out rivets so that’s still useable. These bikes are simple, don’t over complicate it. Need a good set of tools and well stocked hardware store near by or old school bike shop.
Old Yeller is offline
Old 09-12-18, 07:04 PM
malcala622
malcala622's Avatar
It does seem like it does all come apart easily but getting the threads redone or chased seems a bit pricey.
I always find it easier to replace a broken part than attempt to fix.
Nearest vintage bike shop is pretty far off and pricey to begin with. I may just buy another.
Old 09-12-18, 07:44 PM
TiHabanero
Quoted: 1744 Post(s)
Liked 1,370 Times in 719 Posts
I fix things. That is what I do as it is fun. You may not like fixing stuff so buy a replacement. They are cheap to be had.
TiHabanero is offline
Old 09-12-18, 08:40 PM
Fahrenheit531
52psi
Fahrenheit531's Avatar
Quoted: 790 Post(s)
Liked 802 Times in 391 Posts
FWIW, you're not the only person around here that occasionally learns by breaking. Trust me on this.
Fahrenheit531 is offline
Old 09-12-18, 09:02 PM
Drillium Dude
Drillium Dude's Avatar
Quoted: 2588 Post(s)
Liked 4,824 Times in 1,709 Posts
Thank you.
Don't throw the baby out with the bathwater. Is it a clamp-on or braze-on fitting? I has sparez
DD
Drillium Dude is offline
Old 09-12-18, 09:11 PM
malcala622
malcala622's Avatar
Im completely comfortable posting on here when I break something and know very well im not alone. I knew when i tried extracting the broken piece of screw there was a chance of me breaking it even more
Old 09-12-18, 09:12 PM
malcala622
malcala622's Avatar
DD
Clamp on but I'm not fixing the derailleur. Just picking another one up tomorrow.
Old 09-13-18, 08:19 AM
Grand Bois
Grand Bois's Avatar
Quoted: 443 Post(s)
Liked 27 Times in 25 Posts
Is it really Super Record?
Grand Bois is offline
Old 09-13-18, 08:27 AM
malcala622
malcala622's Avatar
Originally Posted by Grand Bois
Is it rally Super Record?
Nope
Old 09-13-18, 08:29 AM
Chombi1
Chombi1's Avatar
Quoted: 1639 Post(s)
Liked 829 Times in 538 Posts
Don't the SR FDs have TI bits on them? Thise could be worth something....
Chombi1 is offline
Old 09-13-18, 09:11 AM
randyjawa
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,751 Times in 938 Posts
Glad to know that there are others. I still manage to create a boo boo or two, even after all these years. Should have seen the Shimano 600 cable adjusting screws I removed from my son's Empire Professional, the other day. Stripped both and then went to the small parts stash (if you don't have a small parts stash, start one - they seem to grow all by themselves, over the years, and prove to be incredibly useful) for replacements. Got lucky and the Pro is good to go...
Good advice accompanies this thought - always ensure that the threads are greased, more so when one is alloy and the other steel. Anyway, my boy's bike and it is not bad for a city junker, in my opinion...
randyjawa is offline
Old 09-13-18, 11:12 AM
Grand Bois
Grand Bois's Avatar
Quoted: 443 Post(s)
Nope.
Old 09-14-18, 03:19 AM
Johno59
Quoted: 331 Post(s)
Liked 332 Times in 185 Posts
It's only aluminium
Nope.
Use a lock nut and bolt of the same thread to set the hanger travel stop. If not enough space go for a different TPI thread or even imperial/Raleigh thread and cut a new thread in the Al body as you go to the sweet spot. It just means get the adjustment correct the first time you wrench it home.
Johno59 is offline
Old 09-14-18, 07:55 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3587 Post(s)
Liked 3,400 Times in 1,934 Posts
No, the only difference between the Record and Super Record front derailluers is that the arms of the Super Record were anodized black.
The Super Record rear derailleur does have titanium upper and lower pivot bolts and a slightly different pulley cage than the Nuovo Record.
JohnDThompson is offline
Old 09-14-18, 08:30 AM
Grand Bois
Grand Bois's Avatar
Quoted: 443 Post(s)
Is that supposed to be a response to my post?
Old 09-14-18, 12:53 PM
Johno59
Quoted: 331 Post(s)
Yes. You have a stripped M 3 mm thread in Aluminium. A 1/8 imperial bolt should track down tight. If not a imperial tap will. Failing that a nut on both sides of the stripped housing will secure a M3 bolt at the correct depth for correct chain positioning.
What have you got to lose.
Johno59 is offline
Old 09-14-18, 01:10 PM
malcala622
malcala622's Avatar
I have a stripped thread not grand bois
Old 09-14-18, 02:15 PM
Reynolds
Passista
Reynolds's Avatar
Quoted: 866 Post(s)
Liked 721 Times in 396 Posts
You can buy a tap for less than $10. It's not that hard to redo the threads.
Reynolds is offline
Old 09-14-18, 02:18 PM
artclone
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times in 9 Posts
Nope
Yes, that's SR.
artclone is offline
Old 09-14-18, 02:19 PM
artclone
Quoted: 294 Post(s)
Nope
Pretty sure the SR adjusting screws are titanium.
Edit: Nope. Same steel part number, 774
artclone is offline
malcala622
malcala622's Avatar
Going thru all my options and suggestions its easiest to just get another derailleur. Its not just the threads that needs chasing but the opening has widened.
Old 09-14-18, 02:23 PM
malcala622
malcala622's Avatar
Originally Posted by artclone
Yes, that's SR.
Yes I'm well aware this is an SR FD
Old 09-14-18, 02:32 PM
malcala622
malcala622's Avatar
Oh good.
Not sure why you said "nope" then.
I said NOPE because Grand Bois originally asked if this was the derailleur called the Campagnolo Rally
Old 09-14-18, 02:43 PM
malcala622
malcala622's Avatar
Not sure why you have this rude attitude, but if you look now at Grand Bois' post you'll see what I saw, which explains what happened here.
Grand Bois must have corrected "rally" to "really" after you replied but before I read this thread.
In the future maybe assume people are being helpful, not stupid.
No rude attitude. Cant understand how you read my reply in that type of tone.
I didnt see his correction.
