Is there an advantage to hookless rims?
Old 06-09-22, 12:35 PM
vespasianus
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times in 219 Posts
Originally Posted by Psimet2001
You just touched on why they "work" over there= 15 psi. The issue isn't about burping on road it's quite literally about tires being blown off the rim. Its the other end of the spectrum.
The most troubling thing for me is that the parts of the industry that will talk about it openly just use in house rules of 150% of target pressure. That's a 1.5 safety factor. That's the LOWEST safety factor I have ever run into in my engineering life. Especially in a consumer product. The worst part is that not everyone even agrees on going that "high". Hushed anecdotes say some OE's have been fine with 1.2-1.3. Think about that: If they are rating a particular tire and rim combo to 70 psi then that means they have experienced blow off at 84 psi. Keep in mind that even all these years after we went to "wider" 23mm rims (13 years ago) we are still having an impossible time convincing people not to ride pressures in the 115 psi range for road. Old habits die hard. This is an absolute recipe for more than a handful of deaths. Also...84psi? how accurate is your crappy pump that you've used for 15 years? I've run across new *redacted* pump gauges that are as much as 15-20 psi off at lower pressures.
For road use, you will get no argument from me. My new carbon rims are hooked and I won't ride hookless on gravel or road.
vespasianus is offline
Old 06-09-22, 12:49 PM
himespau
himespau's Avatar
Quoted: 4217 Post(s)
Liked 2,940 Times in 1,800 Posts
I STILL run into recalled Shimano canti brakes that were recalled in the 80's 90's because the plastic spring retainer would crack. Still. Had a set walk in last week. It's been 40 years.
I think I have a set of those in the parts bin. Didn't know they were recalled, but remember being surprised that someone thought it was a good idea to make a crucial part that took repeated rubbing from the end of a spring out of brittle plastic. Might have chucked them when I could no longer get them adjusted right.
himespau is offline
Old 06-09-22, 12:55 PM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times in 560 Posts
They no longer cover replacement but they used to send out the replacement parts for years/decades. They now don't cover any of it. If you have them you're on the hook for a set of cheap canti's that work great as replacements.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Old 06-09-22, 01:01 PM
Trakhak
Trakhak's Avatar
Quoted: 2468 Post(s)
Liked 2,942 Times in 1,671 Posts
Originally Posted by WhyFi
H+Son sell quite a few hard anodized rims. The last set of rim brake wheels that I built up were Archetypes. Good rims. I mean, the brake track looked a bit ass after the first wet, gritty ride, but they were nice.
The larger issue is that the hard anodizing all but guaranteed that the rims would eventually begin cracking at the spoke holes. I went through quite a few MP4 Mavic rims with that problem back in the day.
Poorer braking than silver anodized rims, too. Campy brakes, a.k.a. "speed modulators," were already enough of a while-knuckle experience in panic stops without the added reduction in braking power from hard anodizing.
Trakhak is offline
Old 06-09-22, 01:23 PM
seypat
Quoted: 3233 Post(s)
Liked 2,511 Times in 1,510 Posts
Dangit - now I am revved up. We are about to record a new episode of the podcast so I am sure I will touch on this and rant slightly. *shameless podcast plug* give us a listen at Road Is Dead.
I'm gonna have to give it a listen.
seypat is offline
Old 06-09-22, 01:42 PM
himespau
himespau's Avatar
Other than a set of super flexy Scott Drop-In bars (that I kind of regret getting rid of now), I don't really ever throw anything from my parts bin away even if I know I'll never use it again. Still have some old plastic friction stem shifters that I kept for God knows what reason. At least knowing there's no more way of fixing them means I might actually throw out those canti brakes the next time I see them when rummaging through one of my tubs.
Actually thought of you a couple nights back because I was racing on Zwift and saw someone with a [PSImet] team tag in my race and was thinking that I didn't remember having raced against one of your riders before. Also had been remembering what you thought about the integrity of Zwift racing.
himespau is offline
Old 06-09-22, 02:03 PM
Racing Dan
Racing Dan's Avatar
Quoted: 1335 Post(s)
Liked 318 Times in 216 Posts
Well ...
Removing the hook = removing one layer of protection from the tyre blowing off of the rim. And ZERO benefits. Why bother?
Racing Dan is offline
Old 06-09-22, 02:13 PM
tomato coupe
Quoted: 3933 Post(s)
Liked 7,254 Times in 2,934 Posts
Originally Posted by Racing Dan
Well ...
It's already been stated a few times -- there is a manufacturing benefit.
tomato coupe is offline
Old 06-09-22, 02:16 PM
GhostRider62
Quoted: 2332 Post(s)
Liked 2,097 Times in 1,314 Posts
Only benefit that I could find is increased internal width for a given external fixed width making for an allegedly plusher ride.
The lack of sufficient safety margin for blowoffs is why I recently bought hooked rims.
GhostRider62 is offline
Old 06-09-22, 02:19 PM
himespau
himespau's Avatar
Someone once told me it was that it made it slightly easier to get tires on the rims.
himespau is offline
Old 06-09-22, 02:20 PM
Racing Dan
Racing Dan's Avatar
Compromising safety just so ppl can have cheap(er) carbon rims, is not a benefit. Its a liability. By that logic customers might as well buy no name carbon wheels from freabay. Me. Id much rather have a semi no name china wheel than a hook less road wheel from any manufacturer.
Old 06-09-22, 02:50 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10943 Post(s)
Liked 7,469 Times in 4,179 Posts
I think the other poster was implying that they think there is no benefit to the consumer.
The consumer doesnt pay less for hookless, even though manufacturing is faster/easier/less waste.
mstateglfr is online now
Old 06-09-22, 03:06 PM
force10
Quoted: 122 Post(s)
Liked 53 Times in 43 Posts
Subscribed.
force10 is offline
Old 06-09-22, 03:07 PM
force10
Quoted: 122 Post(s)
It's worthwhile to point out that old bikeforums member who "grew up" to become the editor of VeloNews and now Cycling Tips and runs the cycling Tips podcast and Nerd Alert podcast basically came to the same epiphany the other day and took to twitter about it.
Link?
force10 is offline
Old 06-09-22, 03:12 PM
79pmooney
79pmooney's Avatar
Quoted: 4782 Post(s)
Liked 3,899 Times in 2,536 Posts
Wow! I started this to learn of the advantages of those rims. So, maybe a touch stronger, a touch lighter. And definitely cheaper to make. Less waste. Fatter stockholder portfolios. I'm supposed to risk my skin and bones for those advantages?
79pmooney is online now
Old 06-09-22, 03:17 PM
WhyFi
WhyFi's Avatar
Quoted: 20791 Post(s)
Liked 9,436 Times in 4,663 Posts
Lol. Yeah, right.
WhyFi is offline
Likes For WhyFi:
Old 06-09-22, 03:18 PM
Psimet2001
I eat carbide.
Psimet2001's Avatar
<snip> I'm supposed to risk my skin and bones for those advantages?
Apparently...yes.
This is truly really like the whole bottom bracket fiasco. A misguided endeavor based in manufacturing savings and trying to solve for bad quality by just eliminating a feature.
Old 06-09-22, 03:30 PM
Koyote
Quoted: 6926 Post(s)
Liked 10,925 Times in 4,666 Posts
No. There is no benefit for the rider. All real benefits are on the manufacturing side. They are less expensive to mold and there is less scrap. The tradeoffs on the rider side of absolutely little to no control of the tires and their ability to reliably stay on the rims in road applications is borderline criminally negligent in my opinion. My opinion is meaningless though.
It's not meaningless to many of us around here.
Koyote is offline
Likes For Koyote:
Old 06-09-22, 03:32 PM
prj71
Quoted: 2970 Post(s)
Liked 1,177 Times in 768 Posts
prj71 is offline
Old 06-09-22, 03:42 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
If you truly love the stockholders, you will.
tyrion is offline
Likes For tyrion:
Old 06-09-22, 03:45 PM
prj71
Guys,
I recently did a 71 mile gravel race over some pretty rough roads on hookless rims. I didn't die.
I'll just point out that motorcyle wheels, ATV wheels and automobile wheels are all hookless.
prj71 is offline
Old 06-09-22, 03:49 PM
WhyFi
WhyFi's Avatar
Originally Posted by prj71
Guys,
​​​​​Since my previous post, I've had one more blowoff and one more death. This brings me up to eight and three, respectively. I figure I'll go back to hooked rims after I die seven times - that'll give me one more plus a bailout.
WhyFi is offline
Old 06-09-22, 05:15 PM
GhostRider62
Guys,
With steel beads.
I've had a tubeless bicycle tire blow off at below the rated pressure.
Old 06-09-22, 05:23 PM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1096 Post(s)
Liked 559 Times in 446 Posts
I've been using the new zipp 303s hookless rims for over 1000 miles with no problems. The 23mm internal width allows a lower tire pressure than my 19mm hooked rims. My Pirelli p zero tires were easy to get onto the rim and seated with a very old Silca pump. No problems so far. I've had mine up to 57mph.
DaveSSS is offline
Old 06-09-22, 05:31 PM
tomato coupe
You didn't specify it was no benefit to the end user, just "ZERO benefits." Hookless is a benefit to the manufacturer.
Okay.
