How to remove shellacked bar tape?
Bikes: 1991 Tomassini Prestige 1973 Raliegh Supercourse, 1975 Panasonic Sport Deluxe, 1983 Fuji S-12, 1975 Motobecane Mirage, 1983 Motobecane Super Mirage 1999 Trek 930 1989 Trek 930 ,
Ok never encountered this one before (just lucky)
This bar tape on this aluminum bar set form the 1981 is cloth tape with shellac, or who knows what Fuji used. Peeling this stuff off by hand will take days.
Quick solutions? Battery acid? These are Nitto bars , worth saving.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Rubbing alcohol will soften the shellac.
Bikes: Fuji Monterey, Schwinn Traveler, Fuji Special Road Racer, Gitane Interclub, Sun EZ-1, Schwinn Frontier, Puch Cavalier, Vista Cavalier, Armstrong, Raleigh Sports, Schwinn Stingray
You want to be careful with the type of alcohol you use when softening a brush that has had shellac hardened on it, or softening a shellaced surface that you want to keep nice. Alcohol with too much water in it will make the shellac haze up. If you are not trying to save the surface, it is not so important what type of alcohol you use.
perpetually frazzled
Bikes: 1977 Bridgestone Kabuki Super Speed; 1979 Raleigh Professional; 1983 Raleigh Rapide mixte; 1974 Peugeot UO-8; 1993 Univega Activa Trail; 1972 Raleigh Sports; 1967 Phillips; 1981 Schwinn World Tourist; 1976 Schwinn LeTour mixte; 1964 Western Flyer
Quoted: 5 Post(s)
Liked 6 Times
Why will it take days?
There are two ways - either take a razor and go from center to end, then start peeling, or start at the finish end and just unroll. I've done it a number of times either way, and it takes all of 5 minutes. Max.
Likes For mickey85:
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
This was my experience as well. Unless someone got sloppy putting it on, this should do it - and possibly a bit of alcohol on a green scrub pad to clean up the residue under the tape if the shellac was super-saturated.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
I agree with the cut-and-peel advice, alcohol will leave you with a sticky and nasty mess that you still have to cut and peel. Save the alcohol for cleaning up the mostly-bare aluminum.
I believe you are over thinking this one. I always run a razor blade along the underside of the bars.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Quoted: 443 Post(s)
Liked 27 Times
Cloth tape with shellac should peel right off and leave nothing behind. I stripped some bars last night. I didn't cut the tape, I unwound it. It may have taken all of three minutes. Stop overthinking and just do it.
Quoted: 95 Post(s)
I had old gummed up tape on some bars, but it wasn't complete, so I just went over it with a wire wheel on the bench grinder. All glue and residue gone in 5 minutes.
You practically have to stand on the bars to get the tape off, and then it tears off in 1 CM bits and pieces, enough to make you insane. This could be a time consumer. I may just freak out and whittle it off with a hunting knife, but I don't enjoy making accidental cuts in aluminum bars.
Fred-ish
I tried the usual razor blade method, unravelling with needle nose plyers etc. This is bar tape from the Fuji factory from 1981. It is incredibly stuck on. Serious attic baked-on mummification. The brake hoods were completely melted, like dripping/gooey.
On second thought, make sure it's shellac by wetting a bit with alcohol. If it doesn't start to dissolve it may be lacquer.
Señor Member
Liked 1,090 Times
Try spraying a light mist of denatured alcohol on a section, give it 3-4 minutes, and see if that improves the removal. Gradually work up the quantity and the time it sits until you find a technique that works well.
One thing you will want to avoid is having any shellac dripping onto any other bike parts (frame, rim, brake calipers, etc.). It's a real pain to remove. (Don't ask me how I know this.)
Ok, I'll try that. I'm thinking paint remover would probably be the stuff. I am just leery about accidentally gouging aluminum bars, a slit becomes a crack... If these were crappy aluminum bars or steel, I'd probably be ripping away with a serrated edge kitchen knife...
Bikes: 85 Schwinn Cimarron, Soma San Marcos, Yuba Mundo e-cargo bike, ratty old hard tail 29er and I stare at my wife's 87 Sequoia that she does not ride
Quoted: 11 Post(s)
I know its an old thread, but best one I can find. Any tips on removing shellacked tape from a frame? Bad decision. I know. But need help with removing it without destroying the powder coat underneath. Thanks!
Borax solution will dissolve shellac, nearly as well as alcohol. Works best with warm or hot water, but even cold it will still dissolve shellac over time. Maybe soak some rags and wrap around the tape for a soak? Might take a few hours or more.
As always with this sort of thing, test the finish first to make sure that the borax solution doesn't eat the powder coat.
A commercial paint stripper might soften up the shellac, enough to make removal easier. Scrape with a plastic blade of some sort (putty knife) if you're worried about the finish on the bars.
