Non-drive side spoke tension (rear wheel, rim brake)
Quoted: 425 Post(s)
Liked 452 Times
I picked up a cheap spoke tension meter for entertainment. Tried it on a few wheels and despite concerns about calibration accuracy, for the most part the numbers seemed to be within the expected ranges.
For the NDS rear spokes, I understand that the best practice is to get the tension right on the DS, get the wheel round and true, and let the NDS spokes fall where they may. On most of my wheels, the DS tension values seem reasonable and so do the NDS tension values.
However, on one wheel in particular, the NDS tension seems so low that it's barely registering on the tool, and way below the expected range. This was on a factory built wheel with less than 500 miles (and it rides fine). The company is small but has a decent reputation from what I can tell on the internet. It's a 55mm carbon clincher rim on cx-ray spokes (steel bladed 1x2mm). Measurements were taken with tube and tire on the rim at 90psi.
Is it normal for the NDS spoke tension to be so low? Even if my cheap tool is way out of calibration, having the NDS spokes barely register (and some not register anything at all) doesn't seem right. But technically it still aligns with the "tension DS, keep wheel round and true, let NDS be whatever it may be" mantra.
Quoted: 5766 Post(s)
Liked 2,538 Times
First of all, understand that the ratio of right and left side tensions is determined by geometry. It's the same as the ratio of the center to flange distances and cannot change.
Secondly, folks are getting distracted by focusing on tension, which is at most a secondary concern. What's more important is spoke elongation, so thinner spokes can and do work better at lower tensions.
There are other considerations, so I can't advise because I lack the specific info needed. Except that I suspect that you also lack the knowledge and experience to make any kind of judgement call.
What you need to ask yourself is whether, newly armed with a tension meter, you are now smarter than the people who built this wheel.
So I suggest you follow rule #1, and don't fix what ain't broke.
Quoted: 18349 Post(s)
Liked 4,502 Times
How many spokes does the wheel have? Sometimes wheels with higher spoke count will have lower spoke tension.
As @FBinNY suggests, I wouldn't worry about it to much as long as you can feel some tension when squeezing a pair of spokes with the hand.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Would you care to divulge which "cheap tension meter" you bought?
Liked 2,538 Times
Here's a very easy way to get an indication of a tension meter using only a ruler.
Accurately measure the CTF distances of your hub. Next measure the zigzag offset in the rim.
Subtract half the zigzag offset from each CTF. Now compare the two results and calculate the resulting ratio.
This ratio MUST equal the ratio of the average tensions on both sides. If it doesn't it means that your tension meter is off. Of course nothing here assures true readings, it just flags a problem.
That said, the meter may still be fine for comparative readings.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 955 Post(s)
Liked 1,619 Times
Rats FB... Now ya got me. Been trying ta finger this one out but no go... Would Splane it better for me. I am very interested.
Liked 2,538 Times
Consider that the spoke tension's effect on the rim is a vector with a radial and axial component. Now consider that the total axial forces from both flanges must be equal to each other (add to zero).
Now, we can talk trig, calculating the spoke angles, finding the sines, and doing the math. However, it turns out that everything falls out and all that's left are the 2 CTF distances (net of the be rim offsets), which determine the angles.
It helps to draw a sketch, then start to work out the trig equations. At some point in the process the light will come on and you'll wonder why you didn't know that all along.
Likes For FBinNY:
Quoted: 955 Post(s)
Liked 1,619 Times
700c M13II 700c 622
Front: 32-34 Average = 33
Rear Drive Side: 32-33 Average = 31
Rear Nondrive Side: 28-30 Average = 29
Rm19 Weinmann 27-1/4 x 28c / 35c ETRTO 630X19
Front = 31
Rear Drive = 30
Rear Nondrive = 25
CR18 27-1/4 14ga SUNRIMS
Front = 31-32
Rear Drive = 31
Rear Nodrive = 27
Further note: I too had a wheel that had low tension on the NDS after truing. The DS registered normal. I just increased the tension of the NDS and re-trued. Surprisingly I was able to get the tension up on the NDS with very little change on the DS tension...
Quoted: 425 Post(s)
Liked 452 Times
Quoted: 425 Post(s)
Liked 452 Times
...Except that I suspect that you also lack the knowledge and experience to make any kind of judgement call.
Going by the relative CTF, though, this wheel is definitely off in that the NDS side is basically 0. I can accept that the tension meter is the problem, and not the wheel itself.
Related question: do people measure tension with the tires mounted and inflated, or without? I feel like that would affect the tension meter readings.
Quoted: 425 Post(s)
Liked 452 Times
I git ya... I too ordered one of those ChiCom tension meters and have been very satisfied with it. But it has taken some getting used to for sure. First of all I don't pay very much attention to the accuracy of the numbers on its dial. I went and measured the tensions on all my good wheel sets with the meter and then calculated the average tension registered on them. Front, DS and NDS. Luckily all my bikes are 700c and 27" running about the same width rim and 14ga spokes. So I got a ball park usable figure for my particular meter. Here is what I came up with, but remember that's for my little ChiCom device that is NOT CALIBRATED.
700c M13II 700c 622
Front = 31
Rear Drive = 30
Rear Nondrive = 25
Front = 31-32
Rear Drive = 31
Rear Nodrive = 27
700c M13II 700c 622
Front = 31
Rear Drive = 30
Rear Nondrive = 25
Front = 31-32
Rear Drive = 31
Rear Nodrive = 27
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
So your rim is not centered now. If you increased NDS tension the rim had to move that way...no way it couldn't have.
Likes For cxwrench:
Liked 2,538 Times
Hence, the reason I posted the question in the thread. Good info overall, and I agree with your points, but the ~0 tension meter reading is what I was most curious about. Like I said, the wheel rides fine, and I have no intention of messing with it. (Emphasis added)
As for the low tension, discounting meter error, it might still be right if the spokes are thin, or if you didn't properly factor the gauge when using the conversion chart.
As for when to measure tension (tires or not) you already know the answer. You just don't know that you know, so stop to think a moment. Assuming for the moment, that tires make a meaningful difference, then so would the air pressure. So, do you think that a builder would mount and inflate a tire to check tension before removing it to continue working. If so, how wide a tire, how much pressure, etc.? So, as I said, you know that answer already.
BTW- despite your intentions, you later said you increased NDS tension, so either the wheel was, or now is, not dished correctly.
It's said that poor mechanics blame their tools, but it's my experience that the poorest mechanics overly trust and rely on their tools.
FB
Chain-L site
FB
Chain-L site
Senior member
Quoted: 942 Post(s)
Liked 656 Times
700c M13II 700c 622
Front = 31
Rear Drive = 30
Rear Nondrive = 25
Front = 31-32
Rear Drive = 31
Rear Nodrive = 27
700c M13II 700c 622
Front = 31
Rear Drive = 30
Rear Nondrive = 25
Front = 31-32
Rear Drive = 31
Rear Nodrive = 27
Not really a problem when taking readings in the 100 kgf plus range so long as the readings are repeatable.
It is possible that the clones of the Park tool have an even stronger spring which would mean that at some threshold you would get a reading of zero even when there is some tension.
By comparison, my better tension meters only raise the tension by about 1% when taking a reading.
Quoted: 425 Post(s)
Liked 452 Times
I just re-checked this afternoon and the tension meter values of 2-3 actually translates to ~50 kgf for the spoke type, so not ~0. This was with the tires inflated so I'm guessing that translates to a slightly higher tension if measured without tires. The wheel rides fine so I'll leave it alone. Thanks for your insights.
Sock Puppet
Liked 863 Times
Looks similar if not identical to the picture posted by zandoval
Sock Puppet
Liked 863 Times
Quoted: 955 Post(s)
Liked 1,619 Times
Yes... They are the raw readings on a tool that is not calibrated. Its crude but it works for me.
Your post scared me so I just went out and rechecked. The wheel is aligned just right with my Dish less then 1mm difference between DS and NDS. At that time for my uncalibrated tool I was reading 24-25 on the NDS and 29-30 on the DS with the wheel trued. I took the NDS and gave it some tension evenly across all the spokes bringing it up to about 27. I then retrued on the DS and sure enough the DS came up to about 30-31. So really the difference between DS and NDS was about 2 increments on my mystery tension meter. The dish remained dead on.
I am not a wheel builder. But I have replaced spokes and refurbished bent rims. I think nothing of completely loosening up a laced wheel and then bringing it back to life. It a joy to see some people who have a real rythem for wheel truing. I just chug along and kinda play with it till its gets right. Who knows, some day I might even get a wheel truing stand...
Liked 2,538 Times
Question for someone with this meter.
Is the conversion chart specific for various gauges?
If so, are they charted by gauge, ie. 14g, or actual spoke diameter, ie. 2mm?
It's important because the spoke diameter factors into the reading, and a thinner spoke will read as lower tension.
FB
Chain-L site
FB
Chain-L site
Quoted: 425 Post(s)
Liked 452 Times
Sock Puppet
Liked 863 Times
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 294 Post(s)
Liked 666 Times
I've been using a Ztto TC-1 cheapo tension meter, as people have said there's no guarantee it's accurate.
One way round that is to calibrate it:
Another thing I do is to bounce the meter off the spokes a few times when I'm measuring tension in spoke - the
reading goes down the first couple of bounces. I put that down to friction in the meter.
Here's an earlier thread about calibration: https://www.bikeforums.net/bicycle-m...on-meters.html
I bolted some blocks onto a wooden post and stretched a spoke between them with a digital crane scale at one end.
Just wind up the tension and take a reading.
It turns out the curve for reading to KgF is exponential and you can do a best fit curve
Then I plug that formula into the spreadsheet I record spoke readings on.
One up side of doing this is you can adjust the meter for most sensitivity in the range you're interested in.Just wind up the tension and take a reading.
Quoted: 980 Post(s)
Liked 580 Times
I've built 6 wheels (not many, to be fair) using the Park TM-1 and they've remained true for thousands of miles. I've found this simple tool to give reproducible readings under my working conditions.
Bikes: lots
Liked 2,932 Times
Your post scared me so I just went out and rechecked. The wheel is aligned just right with my Dish less then 1mm difference between DS and NDS. At that time for my uncalibrated tool I was reading 24-25 on the NDS and 29-30 on the DS with the wheel trued. I took the NDS and gave it some tension evenly across all the spokes bringing it up to about 27. I then retrued on the DS and sure enough the DS came up to about 30-31. So really the difference between DS and NDS was about 2 increments on my mystery tension meter. The centering remained dead on.
Likes For cxwrench:
