Trailer Tires
Quoted: 357 Post(s)
Liked 136 Times
Trailer Tires
I need a new set of trailer tires for my Burley Nomad. The only problem is, there're hard to find. At 16+1.2 it's a bear to find. The LBS doesn't sell them any more. Few mail order places sell them so what should I do? Where do you get your tires from?
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,529 Times
Order you tires from one of the mail order places that you did find. How many mail order houses do you need before you can order a set of tires from one of them?
Is there a reason you can't use 1.25" 1.35" or 1.5" or 1.75" tires on the Burley trailer? Because there's an abundance of those. I would go for the Schwalbe Marathon Plus in 16x1.35 unless the extra 15 hundredths of an inch (about 2mm extra width on each side) is too much. I had some trouble with the original size tires rubbing the canopy on my Trek bike trailer, but they just needed a little fiddling and adjustment. If 1.35" is too wide, then I'd go with Schwalbe Kojacks in 1.25".
