Litespeed: Tuscany, Blue Ridge, or Teramo?
Hello, have been through a 2 hour fitting and advisory session for a road bike by a great local bike shop. I am buying my first real road bike so I wanted to do this right.
I am 6'3" with a 36" inseam 225 lbs.
My application will be mainly fitness but I can see myself doing centuries in an around Atlanta GA every other weekend - especially in the winter.
I want to make sure I pay once and have settled on Litespeed. I know there are many other great models out there but I have narrowed it down to that manufacturer.
I am assuming cost of equipment being pretty much equal, all non frame parts add to each frame price equally. For instance the Teramo is $3K and the Tuscany $4k but from what I've seen the Tuscany has more $$ in parts. The bike shop says they can build what ever I want so I'm thinking I can choose my equipment budget levels and the difference comes down to the frame cost. This is partly why I'm going with this manufacturer - to try to make this a bit less complex.
So, if the above assumptions are true, I was wondering that the differences in the Tuscany, Teramo, and Blue Ridge frames with their standard packages would be for me?
Any help would be appreciated - wanted to try to decide this weekend.
Thanks
Bob Smith
Atlanta GA.
Thanks
Bob Smith
Atlanta GA.
Rides again
Bikes: Giant OCR T, Trek SC
Will you be riding mostly solo or group rides? If solo, take a good look at the Saber. The blue Ridge is more relaxed and designed for hauling much. Because it's more relaxed, it will probably offer a slight speed decrease. If you just want to pay once, consider a Blade. It's about 1k more, but it is custom built for you.
Remember it's better to get ultergra package and better frame than lower frame and dura ace. Sometimes you can save a little by getting none Litespeed components. For example, see www.nytro for a listing of common substitutions for budget reasons.
Personally, I think the Tuscany is the best all-round frame I have ever been on. It feels solid, rides light, and will do just about anything, I also think it might be the best Litespeed for somebody 200+ pounds. It's not super sexy, and I think the 06 graphics package is hideous compared to the older style (ie ViperZ beauty), but it's the best high end do everything Ti bike in my experience.
Judging by what you're saying, though, I think I'd stick to the 3AL/2.5V Ti, and not 6/4 as that tends to be overly stiff.
Here's a link to a review I tend to agree with, and you should also check out Coloradocyclist.com as they have a smokin deal on the Firenze right now.
https://www.bikesportmichigan.com/rev...uscany03.shtml
Bikes: '03 Litespeed Blue Ridge; '15 Litespeed T5; '17 Jamis Renegade Exploit; '17 Salsa Fargo 27.5+
I have a Litespeed Blue Ridge. I bought it to get a bike to do it all and it can do it all, just nothing great. You can use it for a road bike but you need to put 23cc tires on it and reverse the stem for a more agressive ride. You can use it for cyclocross, just put agressive tires on it. Currently I have it set up for commuting and light touring with fenders, rear rack and Conti Top Touring tires. You can't do that with a Tuscany. It is a bike I will use for a long time.
However, I can't quickly change the bike up so I now have a Lemond Alpe D'Huez for faster road rides. Also, I'm building up a fat tire touring bike because the Blue Ridge is a bit bumpy on back roads.
I look at every Tuscany on ebay and drool. Some day after I get divorced I'll get me a Tuscany, or perhaps I'll get it and that will cause the divorce. The Blue Ridge almost caused the divorce last time.
The Blue Ridge will perform will for your weight. If you plan on long rides, the Blue Ridge will get you there in comfort, just put a Brooks B17 on it. The Open Pro wheels are very strong. I'm 15lbs heavier that you are and haven't had any problems. If the Tuscany comes with low spoke count wheels, you may run into a problem.
Mark
'98 Lemond Alpe D'Huez - go fast days
'03 Litespeed Blue Ridge - go long days
'01 GF Tassajara - up and down days
Mark
Part Time Super Hero
Bikes: Litespeed Teramo (2005), Cannondale CAAD4 (2000), Trek Fuel 100 (MTB)
I have an XL Teramo from '05 and love it (except for the crap FSA crank that will not shut up). I was looking at the tuscany vs. termamo and settled with the teramo for two reasons:
1. It was cheaper and I was in dire need of a new couch. Going with the teramo meant I got the couch for free!!
2. Some have reported the tuscany gets "noodley" in the larger frame sizes
I am not a fan of the '06 decals--a little too flashy, but the bike should be solid. Any reason why you are not looking at the Firenze? It is the same frame as the teramo and you save a few $'s.
Mark; Thanks for the report on the Blueridge. I have have considered getting one of those for a while now. Dreaming that some day I can back to doing some loaded touring.
I have put a few miles on a Classsic & Firenze. Personally, I like the way the Classic rides. Reminds me of bikes of bygone years.
I agree with you on lusting for a Tuscany. Viper Z's photos have elevated that bike to an entirely new level. Perhaps, one day I will be able to put a few miles on a Tuscany.
Former grouch, now happy
The bike shop ought to interview you, learn your riding style and plans for using the bike, and make a recommendation.
Based on what you've written, you're a recreational rider; not a tourist and not a racer. The shop should steer you away from a racing bike, so the Teramo is out.
The Tuscany has essentially the same geometry (same angles, top tube and chainstay in a 61). I'd forget that one as well.
That leaves the Blue Ridge, which is more or less an "all-rounder." It's by no means a real touring bike.
That would be my choice. And I'm pretty close to your size, and I use my bike about the same way you describe.
PS. You may want to think seriously about a custom frame. A 61/59 may not really fit you. Ask the shop.
Spectrum Ti Super | Landshark Roadshark | Serotta Colorado | Gunnar Crosshairs | Trek 9800 | Santana fillet brazed tandem | K2 Easy Roller | Dawes (BD) Bullseye 1x1
Location: Latitude 42○13'44" Longitude 71○41'42" Elevation 223 ft.
Bikes: 2006 Merlin CR Works w/DA 10
I am a little over 6'2" and about 190 lbs .. 46 yrs old ... ride about 150 miles a week. Similar to you, it sounds like. I have a 2003 Tuscany and it's an incredible bike - I'd definately buy the same bike again if I were buying today. Comfortable on rides of all duration, including the 136 mile ride I did in June.
With that said, I don't have much knowledge about those other bikes.
Baby it's cold outside...
Bikes: Trek 5000, Rocky Mountain Wedge, GT Karakoram K2, Litespeed Tuscany
Thanks Jburnsdo & Bob S!
To the OP, it has been stated that the Tuscany is the best all around road bike frame that Litespeed makes, however it may depend on how you plan to ride. The Blue Ridge is a Cross bike, so maybe more versatile if you plan to ride off road.
Either or, it would seem you have narrowed it down to a few good choices.
BTW, I'm 200lbs and find my 2003 Tuscany stiff enough for me.
THANKS everyone for your advice - still a hard decision - will proabably go to the LBS tomorrow and decide. I am a bit concerned about the smaller Firenze/Teramo size compared to the Tuscany or Blue Ridge for my height.
Thanks again, Bob
Thanks again, Bob
Tuscany, but the wheels?
I've been very happy with my '05 61cm Tuscany. I think you can't go wrong with any of your picks. Take a good hard look at the wheels they offer with it. Mine came with the Real Designs Ultrafly. Nice looking, light wheelset but they have a lot of lateral flex. Any out of saddle effort results in the wheel rubbing the brakes, and, no it is not the frame flexing. At your weight this might be a concern.
Good luck
Good luck
Bikes: Bianchi, Colnago
I am basically the same size as you, and I just took delivery of my 61cm '06 Tuscany. It's a beautiful bike, the images on the website are hideous compared to seeing the actual frame in person. Litespeed really needs a better photographer. The edges are much smoother, and the lines much cleaner than the website portrays.
That being said, the Tuscany has been discontinued, and is no longer available. Litespeed is no longer building traditional framesets, only compact frames. The replacement for the Tuscany is the Sienna. For an extra $500, you can have an '06 Tuscany built, but it becomes a custom frame.
