Will any Shimano shifters fit this downtube mount?
I have a Nishiki Prestige I've been fixing up. It's nearly done, but after taking it on some test rides, the one thing I'm not in love with is the shifting/shifters. I generally prefer index over friction, and the Suntour aero shifters on there wouldn't be my first choice if I kept it friction. I'd love to get some Shimano indexed downtube shifters on there. Thing is, I don't know what other shifters, if any, are compatible with the mount on the frame.
Do any of the Shimano aero shifters fit this mount (pic attached), and if so, can I swap in indexed levers on the bosses of said Shimano aero shifters?
And while you're at it—any opinions on what bar tape would look good?
Thanks!
Thanks!
Death fork? Naaaah!!
What does the mount look like without the shifters? Indexed DT shifters might bolt right on.
Top
Top
Likes For BTinNYC:
Bikes: Bicycles? Yup.
Quoted: 476 Post(s)
Liked 1,520 Times
Edit The inside of Shimano SL-400 8s
For this shifter set, the connector piece below would have be filed to fit.
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Shimano made a similar aero shifter, but they used a proprietary 4.5mm boss mounting screw and I don't believe any of them were indexing. I don't believe any of the Suntour aero shifters were indexed either.
Shimano did, however, make an aero mount adapter for use with their subsequent downtube SIS shifters.
https://velobase.com/ViewComponent.a...4c72b&Enum=104
There is one listed on eBay, which might be a slightly different version (or possibly an incorrectly described body from an actual Shimano aero shifter, with the shifters removed). https://www.ebay.com/itm/31381584481...gAAOSwl6dh0PXt.
There's also a Gipiemme aero adapter, that Boulder Bicycle has a supply of, which could possibly be modified to use with Shimano downtube shifters. Found more! Aero Adapter mount for Gipiemme Cronos shifters (and possibly others) NOS - read
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
That is generally called a "B" mount. Shimano made a converter for standard DT shifters for them but they might be hard to find now. I have one but it is in use. I can take a photo if you need.
Edit: Vintage beat me to it, with links no less.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Thanks for the replies! I saw that same listing on ebay, but I too thought it might just be the body of an aero shifter not an adapter specifically for this purpose. If that works too, great, then I'd probably buy a different cheaper one with the shifters attached. But if the adapter is the only thing that works, I'd guess need that. I contacted the seller to ask, but have not yet heard back. @Cynikal, since you have one, could you confirm that the one in the ebay listing is the correct part? I've attached photos from the listing below.
Another post related to these adapters: https://www.bikeforums.net/22346036-post7318.html
Yep, that looks like what I need. Sounds like he didn't have an easy time finding it.
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
If the mounting bolts are 5mm, I’d be tempted to take a few measurements and drill and tap a bole for a grub screw on the uphill side of the flat, similar to what a standard Shimano mounting boss (the part that covers a braze on) looks like. Might need some thin washers to get the spacing right, but bet it would work fine. Larger problem will be getting the left shifter to ‘wind up’ if using Light Action ones.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Yeah, that purported adapter looks different from the one on Velobase. It also looks suspiciously like the body from some Shimano aero shifters. This Golden Arrow one for instance.
I do have those washers (borrowed from some barcons in fact). I tried unsuccessfully using them with the Shimano shifters on the Suntour bosses.
Likes For drewfio:
Update: I figured it out.
I bought some Shimano SL-L422 friction shifters off eBay. Looking at the photos I thought they might fit. They came today, and they do fit. Success! I unscrewed them from the adapter/mount they are attached to to have a look, and they are compatible with indexed Shimano levers. No washers needed.
I actually like the feel of these much more than the original Suntour shifters. What I really like is that they spring in the opposite direction the derailleur pulls the cable, such that the tension is cancelled out, and the same pressure is required to push it forward and backward. This is how the left/front friction shifter works on my Dura Ace down tube shifters, which I always thought were super smooth.
Here is another set of the L422 available on eBay if anyone is looking: https://www.ebay.com/itm/15424435762...sAAOSwyPhf16Ml
After a little polishing, mounted on my bike:
Likes For drewfio:
