Gravel Route Please
Gravel Route Please
No time lurker, First time poster, so apologies if I知 doing this wrong.
I would love it if someone would share a Rochester to Mankato, MN gravel route. I知 not a bad web forager, however I have not yet been able to find a route file, or even a map, which would be cool enough. It would be awesome to benefit from the wisdom and experience of others, and not have to delve into creating my own route.
Here's a thing: https://gravelmap.com/#8.62/44.1321/-92.8694
Quoted: 3427 Post(s)
Liked 1,441 Times
A lot of the farm roads in Southern Minnesota are gravel roads. If you do not identify a route from other sources, perhaps look at the county road maps from the DOT and put together your own route? You would probably have a mix of gravel and paved. Such roads often are poorly marked, you would likely need a route loaded into a GPS to avoid going off route.
I misplaced my Minnesota state cycling map so I can't look at it, does that provide any help?
Randomhead
Liked 3,664 Times
The ride with gps route planner shows which roads are gravel, if that information is available.
This route might work for you? See https://ridewithgps.com/routes/38731076
