Cycling glasses with some modern helmets: over straps or under straps?
Old 06-21-21, 03:36 PM
  #51
shrimp123
Quoted: 30 Post(s)
Liked 20 Times in 12 Posts
looking into me.....
inside on the left and outside on the right when going uphills
both outside when on flats
outside on the left and inside on the right when downhills
both inside when it rains
shrimp123 is offline
Old 06-21-21, 06:40 PM
  #52
JackieYan
JackieYan's Avatar
Bikes: Merida Big Seven
Quoted: 8 Post(s)
Liked 12 Times in 8 Posts
Under the straps. Otherwise, I need to remove my glasses in order to take off the helmet.
I agree with that, although it didn't stop my glasses coming off as I was flying though the air when I was hit by a car a few months ago.
JackieYan is offline
Old 06-21-21, 06:41 PM
  #53
50PlusCycling
50PlusCycling's Avatar
Quoted: 216 Post(s)
Liked 115 Times in 66 Posts
Depends on the glasses and the straps. Some work better over, some under, and some over one and under the other, or under one and over the other, etc.
50PlusCycling is offline
Old 06-21-21, 07:16 PM
  #54
dkatz1
Quoted: 98 Post(s)
Liked 65 Times in 49 Posts
I don't have cycling glasses. I have Rayban prescription bi-focals (though I've had a variety of kinds since I took up bike 22 years ago). They always go under the straps. NEVER once occured to me to different. Today I put them on and tried it, and was worried that they could fall off and so put them under just like always. I hve the same Prevail helment.
dkatz1 is offline
Likes For dkatz1:
  #55
dkatz1
Quoted: 98 Post(s)
Originally Posted by GlennR View Post
Over straps.... you have to look PRO.
I'm a professional amateur!
dkatz1 is offline
Old 06-21-21, 07:34 PM
  #56
GlennR
On Your Left
GlennR's Avatar
Quoted: 2770 Post(s)
Liked 2,053 Times in 1,027 Posts
So you're a FRED? (j/k)
GlennR is offline
Old 06-22-21, 01:14 PM
  #57
Dvdvija
Quoted: 5 Post(s)
Liked 3 Times in 3 Posts
Originally Posted by AndreyT View Post
Hello
I'm used to wearing my Oakley RadarPath glasses over the helmet straps, which is traditionally considered the right way to do it. That's how I used to wear them with my previous helmet - Specialized S3 (size M).
Now I got myself a Specialized Prevail II MIPS (size L, since M felt a bit too tight even at max setting) and I see that the front strap attachment points stand notably further away from the sides of my head with this helmet. For this reason the gaps between the front straps and my head on both sides are pretty wide (~1.5 cm). When I attempt to put my cycling glasses over the straps, I end up having to force the glasses' temples to squeeze the front straps towards my head. I can feel how the straps fight the glasses, especially when I put some tension into the strap by lowering my jaw.
Is this how it is supposed to be? Or am I supposed to wear my glasses under the straps with this helmet?
I like to wear glasses under straps. Strap help keep glasses in place.
Dvdvija is offline
Old 06-22-21, 01:21 PM
  #58
BlazingPedals
BlazingPedals's Avatar
Quoted: 1258 Post(s)
Liked 388 Times in 254 Posts
Originally Posted by ridelikeaturtle View Post
Straps over glasses can cause an annoying whistle / wind noise...
YMMV
I've never had THAT problem, even at some of the stupid speeds I see. Maybe I just need to go a little faster!
BlazingPedals is offline
Old 06-23-21, 08:18 AM
  #59
NoWhammies
NoWhammies's Avatar
Quoted: 668 Post(s)
Liked 303 Times in 199 Posts
Over the strap because GCN told me it was cool.
NoWhammies is offline
Likes For NoWhammies:
Old 06-23-21, 04:00 PM
  #60
noisebeam
Arizona Dessert
noisebeam's Avatar
Quoted: 4975 Post(s)
Liked 1,642 Times in 979 Posts
I'd estimate that those who wear prescription glasses like me tend to wear them under helmet more. No sense in taking off ones glasses and fumble with them just to put on or take off helmet.
noisebeam is offline
Old 07-16-21, 01:31 PM
  #61
AndreyT
AndreyT's Avatar
Quoted: 149 Post(s)
Liked 32 Times in 14 Posts
What exactly do you mean by "prescription glasses"? Regular glasses or cycling-specific glasses with prescription lenses in them?
Regular glasses should be worn under straps, no question about it, simply because the temples of such glasses are thin and straight. They not designed to be worn over anything.
Cyclic-specific frames are a different story entirely. Cyclic-specific temples are beefy and curved. The whole purpose of the curvature is to facilitate wearing over the straps.
AndreyT is offline
Old 07-16-21, 02:32 PM
  #62
70sSanO
70sSanO's Avatar
Quoted: 1036 Post(s)
Liked 842 Times in 561 Posts
There are a couple of aspects to this thread. The “I think if you are in a crash…” aspect which could be interpreted as “I’ve never really been in an accident where I hit my head so I’m just guessing.”
The other is the “anything other than the ideal securing of your helmet” aspect.
Like others, I’ve been riding for decades and have worn a helmet for decades. For me it needs to be secure enough not to flop around but not so tight that it is not comfortable. There is no way I can cinch the helmet so tight that ear pieces for glasses will not fit under the straps and still ride in it.
I have typically worn glasses under the straps, but I just tried the helmet on and put the glasses over the straps… meh. This is a 2019 helmet, but I have not crashed with it on.
Over the years I have had a few crashes where I hit my head while wearing glasses under the straps. Thankfully in all those instances the helmet protected my head, and more importantly I didn’t injure my neck or back.
That isn’t to say that one way is better than another as I think it really doesn’t matter.
John
70sSanO is offline
Likes For 70sSanO:
Old 07-16-21, 02:40 PM
  #63
pdlamb
Quoted: 1573 Post(s)
Liked 782 Times in 483 Posts
Well done, sir. Starting the thread with an open ended question ("over or under?") eventually followed up with "This is the RIGHT way to do it" -- and I fell for it!
pdlamb is offline
Likes For pdlamb:
Old 07-16-21, 02:55 PM
  #64
Iride01
Hits [ENTER] b4 thinking
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 3001 Post(s)
Liked 1,594 Times in 1,162 Posts
Helmet manufacturers probably need to specify what brands and model glasses may be worn with their helmets. Then they can write one of those multi-language documents with pictograms to show the approved way to wear them.
Iride01 is offline
Old 07-16-21, 06:01 PM
  #65
Just Mark
Just Mark's Avatar
Bikes: 2017 Specialized Roubaix Comp, 2019 Cannondale Synopse 105 SE, 2015 Cannondale Quick 5, 2019 Specialized Fatboy
Quoted: 37 Post(s)
Liked 48 Times in 25 Posts
Wow. This puts my thinking on this in a whole new perspective.
Just Mark is offline
Old 07-16-21, 06:20 PM
  #66
noisebeam
Arizona Dessert
noisebeam's Avatar
Mine are standard prescription glasses as I need to use base curve of less than 4 - that is no wrap or curvature in lens.
I certainly would not like to have to take off glasses to remove helmet - that just puts them at risk for damage.
Old 07-16-21, 06:47 PM
  #67
AndreyT
AndreyT's Avatar
Quoted: 149 Post(s)
That's false. I started this thread with a question about peculiarities of a specific cycling helmet. This is a thread about Specialized Prevail II MIPS.
The general flamewar about "over or under" is of no interest to me. The fact that a mere passing mention of "over or under" tends to misdirect and drown the original topic is not something I can control.
AndreyT is offline
Old 07-16-21, 07:43 PM
  #68
shelbyfv
shelbyfv's Avatar
Quoted: 2437 Post(s)
Liked 2,483 Times in 1,343 Posts
I'm guessing the title of the thread may have led to some confusion as to your interest. Also your comments in the revival post #61.
shelbyfv is offline
Old 07-17-21, 09:21 AM
  #69
Branko D
Quoted: 102 Post(s)
Liked 107 Times in 68 Posts
Prescription glasses or sunglasses, I always wear them under the straps (which is how they are designed, anyway). It certainly doesn't prevent the helmet being as tight as is comfortable to ride with.
Crashed hard enough to break the back of the helmet once, the glasses went off my head nevertheless, but remained serviceable.
Branko D is offline
Old 07-17-21, 11:12 AM
  #70
OldTryGuy
Quoted: 894 Post(s)
Liked 435 Times in 293 Posts
I employ the AC/DC method. Using a utility knife I make a vertical slit (a match flame seals the cut edges) at the location that is revealed with glasses over straps. Helmet gets put on and strap clicked in, then arms of glasses are passed through the cut with arm over leading edge first thus an over/under solution.
Seriously, straps ALWAYS OVER ARMS. Helps to keep glasses on when abruptly transitioning from a vertical to horizontal orientation.
OldTryGuy is offline
Likes For OldTryGuy:
Old 07-17-21, 04:32 PM
  #71
jayp410
Quoted: 12 Post(s)
Liked 8 Times in 5 Posts
This makes sense. As someone without regular glasses, I wear cycling glasses outside, mainly to make it easier to remove and reinstall them with one hand to wipe sweat off my brow while riding. It's a little more fiddly to do if the arms are under the straps.
jayp410 is offline
Old 07-17-21, 05:35 PM
  #72
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2637 Post(s)
Liked 1,300 Times in 813 Posts
Not to mention, if you forget that your glasses are over your straps when you remove your helmet, your expensive prescription glasses go flying off to land in the gravel or poison ivy, or just somewhere that you can't see without your glasses.
JohnDThompson is offline
Old 07-17-21, 09:12 PM
  #73
Reynolds
Passista
Reynolds's Avatar
Quoted: 727 Post(s)
Liked 397 Times in 224 Posts
Over straps for me, no question. Now I have a bigger problem: my helmet has a mesh inside that prevents inserting the glasses' temple pieces in the vent holes (glasses upside down of course) to look as an Euro Pro. Should I replace my helmet?
Reynolds is offline
Old 07-17-21, 09:59 PM
  #74
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 5594 Post(s)
Liked 2,794 Times in 1,622 Posts
I think POC Ventral Air Spin is the only helmet I have owned or tried that allows glasses to be stored right side up. All others, from a couple entry level to a good dozen high level, required glasses to be flipped for storage.
...and thats not including the few giro helmetsnivd owned or tried which didn't have a design for glasses storage. Those were super lame.
mstateglfr is offline
Old 07-18-21, 12:24 AM
  #75
canklecat
canklecat's Avatar
Quoted: 4185 Post(s)
Liked 2,090 Times in 1,338 Posts
My aero helmet has miniscule ventlettes that are somewhat effective. Even if I detach the plastic cover that snaps into the vents, there isn't room for glasses. The helmet includes an effective shaded visor that holds securely with magnets, with the visor either down over the face or up over the helmet.
Usually I'll carry a pair of clear safety bifocal glasses with that helmet and stuff the glasses into a jersey pocket, or hang it off the back of my jersey collar. I'm farsighted so I don't need glasses to ride, but they are helpful for checking my phone or bike computer.
canklecat is offline
Likes For canklecat:
