Why is my better bike slower?
Old 06-23-21, 05:25 PM
Troul
:D
Troul's Avatar
Liked 961 Times in 700 Posts
What lube are you using? Wax? Motor oil? WDforty? Spit? Lard?
Tires can cause a change too.
-Oh Hey!
Troul is offline
Old 06-23-21, 06:04 PM
MattTheHat
MattTheHat's Avatar
Bikes: 2020 S-Works Creo SL, 2020 Specialized Roubaix Expert
Quoted: 628 Post(s)
Liked 2,406 Times in 842 Posts
Originally Posted by Barry2 View Post
LOL only 3%, I wish it was only 3%
I run a power meter on the bike... I'm NOT guessing !
For every Watt your body places into the bike as power, your body wastes 3.2 Watts as heat. We are not a very efficient engine.
This heat must be cooled or we overheat.
We are AIR cooled and once the ambient rises, the cooling effect drops.
The body will reduce the power output rather than overheat, and the time on the route goes up.
So, ambient temp very much controls your ability to output power and your speed.
This doesn't take into consideration dehydration, which just makes matters worse.
Barry
BTW I'm in California, last week it hit 107F / 41.7C
Body Temp = 98.6F / 37C.
Can you imagine the "cooling" effect of air that is 8F / 5C hotter than you are!
I run power meters too. Are you saying in hotter weather your segment time increases by 30 percent or are you saying your power drops by 30 percent?
It gets hot where I am too, but I try not to ride when it gets over 100F. When I do, my power doesn't drop by 30 percent. Even if it did, according to bikecalculator.com, my segment time on a 30 mile ride would increase in time by only about 18 percent.
That all being said, now I'm wondering what my power drop is when it gets around 100F. I need to break out VeloViewer. Over 30 miles, it would unquestionably drop at that temperature, because I really dislike the heat. My gut feel would be around 15 percent. That would drop my time by maybe 10 percent. And I'm a big guy who hates the heat.
MattTheHat is offline
Old 06-23-21, 06:08 PM
Barry2
LRP=HR
Bikes: 79 Holdsworth Special, 93 C-dale MT3000 Tandem, 96 C-dale F700CAD3, 2018 Cervelo R3, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 359 Post(s)
Liked 352 Times in 225 Posts
I'm old, big, and working to improve fitness.
Thanks for making me own up!
Barry
Barry2 is offline
Old 06-23-21, 06:17 PM
MattTheHat
MattTheHat's Avatar
Quoted: 628 Post(s)
Here's an interesting article about heat vs. speed https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2039810/ that I just found and read (part of).
A couple of examples are contained, the first is a 30 minute time trial in 73F and again at 90F. I assume this is in well conditioned athletes. The difference in this example was a reduction of 6.5% in power, which translated to 2.8% slower. This is an interesting subject that I never thought much about other than I just try not to ride when it gets really hot.
The article mentioned the possibility of why power is reduced could be because of mitochondrial leakage. I don't know what that means, but it sounds horrifying.
Likes For MattTheHat:
Old 06-23-21, 06:24 PM
Troul
:D
Troul's Avatar
90 dry vs 90 humid vs 90 no wind vs 90 windy vs 90 in the direct sunlight vs 90 in the dark. Only one of those will I feel like I'm down on performance.
-Oh Hey!
Troul is offline
Old 06-23-21, 07:05 PM
70sSanO
70sSanO's Avatar
Quoted: 1036 Post(s)
Liked 842 Times in 561 Posts
I agree that fit is a big part.
But the Trek might just have better geometry for that course. Weight is only one piece of it.
John
70sSanO is online now
Old 06-24-21, 04:39 AM
BikingViking793
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 2010 Raleigh Talus 3.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour
Quoted: 135 Post(s)
Liked 47 Times in 40 Posts
Do they both have the same length cranks?
check out the Frugal Average Bicyclist
Frugal Average Bicyclist The goal here is to help you keep cycling on a budget.
BikingViking793 is offline
Old 06-24-21, 05:41 AM
ZHVelo
Quoted: 381 Post(s)
Liked 154 Times in 111 Posts
Originally Posted by halehankock View Post
Good advice! I felt like when i have pushed for a PR with the Specialized a number of times, I actually worked harder those times, just 3-4 weeks ago than I did with the Trek and was much slower.
Also, I got my Specialized fitted to me in 2019 so I would hope I'm in the optimal position for handlebars, seat, pedals, etc. The trek has me in a slightly more upright position which i'd imagine isn't in my favor either.
Maybe it was fit for comfort, not aerodynamics.
ZHVelo is offline
Old 06-24-21, 06:05 AM
TiHabanero
Quoted: 1238 Post(s)
Liked 560 Times in 306 Posts
Interesting situation. More testing is required to determine if this experience was a one-off, or consistently true. About 10 years ago we fit a seasoned domestic pro using power meters and video. 4 weeks later he came back with real world results that were disappointing, and we changed the fit back to what he had been using for some years.
Point is that sometimes a fitting does not translate to efficiency in application. More riding is needed to determine what gives here.
TiHabanero is offline
Old 06-24-21, 06:13 AM
Paul Barnard
For The Fun of It
Bikes: Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 1526 Post(s)
Liked 812 Times in 413 Posts
Some years ago, before I got smart and started riding titanium, I switched from a Trek 1500 aluminum to Specialized Tarmac carbon. I had both bikes at the same time for a while. In quite a bit of apples to apples comparison riding I was faster on the Trek.
Paul Barnard is offline
Old 06-24-21, 07:51 AM
rosefarts
With a mighty wind
Quoted: 698 Post(s)
Liked 402 Times in 240 Posts
Tires are probably the difference.
Does one bike have a higher or lower spoke count than the other? Deeper profile rims? Bladed spokes? All of those can make up a tiny difference.
In the yo-yo world, sometimes people pull the seals off the bearing and clean them out. This is called running dry. This makes for a loud but extremely fast spinning and long spinning throw. Yes, it wears out quickly.
It could be something like that on the bikes. Old bearings, a little dry, on cup and cones VS new cartridge with tight seals. Ive seen it.
My last idea is how fun a bike is to ride. I had a Litespeed Vortex with every bell and whistle 2006 had to offer. Truly amazing bike. I quickly switched back to my plain old aluminum trusty bike. The fancy bike just didnt have that zing and I never raced well on it.
rosefarts is offline
Old 06-24-21, 08:34 AM
Flatforkcrown
Flatforkcrown's Avatar
Bikes: N+1
Quoted: 19 Post(s)
Liked 83 Times in 37 Posts
I just switched out the wheels and tires on my bike, from 36 hole box section clinchers or lightweight aero tubulars. Went from vittoria open corsa tires to veloflex robaix tubulars. Gearing is the same. Im consistently slower over the same routes. I am more comfortable tho.
Flatforkcrown is online now
Old 06-24-21, 09:39 AM
halehankock
Quoted: 13 Post(s)
I really appreciate all the feedback guys! A few more details about the ride. The lake loop segment itself is only 4 miles, so that's 37 seconds faster in only 4 miles., Elevation change of 66ft so it's pretty flat, with just about constantly small little ups and downs but nothing crazy.
2010 Trek 2.1 Alpha Specs vs. Specialized Roubaix Expert
Frameset
Frame
Alpha Black Aluminum (Specialized: Specialized SL4 FACT 10r carbon, FACT construction, tapered/shaped 1-1/8"" to size-specific lower headtube, compact race design, Zertz, internal cable routing, carbon OSBB)
Fork
Bontrager Race, carbon; SpeedTrap compatible (Specialized: Specialized Roubaix FACT carbon full monocoque, Zertz, size-specific)
Size
54
Wheels
Wheels
Bontrager SSR (43cm: alloy hubs w/650c Alex rims) (Specialized: Fulcrum S4)
Tyres
Continental Grand Prix 700x23c (Specialized: Continental Gatorskins 700x23c)
Drivetrain
Shifters
Shimano 105 STI, 10 speed (Specialized: Shimano Ultegra, 11-speed, 11-32)
Front derailleur
Shimano 105 (Specialized: Shimano Ultegra, braze-on, 11-speed)
Rear derailleur
Shimano 105 (Specialized: Shimano Ultegra, 11-speed, long-cage)
Crank
Shimano R-600 50/34 or R-553 50/39/30 (Specialized: FSA SL-K Light, carbon, BB30)
Cassette
Shimano 105 12-27, 10 speed (Specialized: Shimano Ultegra, 11-speed, 11-32)
Components
Seatpost
Bontrager Carbon (Specialized: S-Works CG-R, FACT carbon w/ Zertz, 27.2mm)
Handlebar
Bontrager SSR VR, 31.8mm (Specialized: Specialized Expert Shallow Bend, alloy, 123mm drop, 75mm reach)
Stem
Bontrager Race Lite, 7 degree, 31.8mm (Specialized: Specialized Expert Pro-Set, 3D forged aluminum, 4-position adjustable, 4-bolt, 31.8mm)
halehankock is offline
Old 06-24-21, 09:46 AM
WhyFi
WhyFi's Avatar
Quoted: 16835 Post(s)
Liked 5,544 Times in 2,875 Posts
Tyres
Dun dun DUNNN!
WhyFi is offline
Old 06-24-21, 10:06 AM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 2928 Post(s)
Liked 1,491 Times in 993 Posts
Dun dun DUNNN!
+1 You either run Gaterskins on both bikes or neither.
79pmooney is offline
Old 06-24-21, 10:21 AM
PeteHski
PeteHski's Avatar
Quoted: 501 Post(s)
Liked 464 Times in 311 Posts
Dun dun DUNNN!
We have a winner!
PeteHski is offline
Likes For PeteHski:
Old 06-24-21, 10:57 AM
caloso
caloso's Avatar
Quoted: 2671 Post(s)
Liked 2,266 Times in 1,067 Posts
That's the answer.
caloso is offline
Likes For caloso:
Old 06-24-21, 01:13 PM
halehankock
Quoted: 13 Post(s)
You're saying the grand prix's are that much quicker?!
Old 06-24-21, 02:05 PM
HTupolev
Quoted: 1757 Post(s)
Liked 905 Times in 443 Posts
Hahaha.
It depends on various particulars, but it wouldn't be unrealistic for them to save you on the order of half a mph or more.
HTupolev is offline
Likes For HTupolev:
Old 06-24-21, 02:32 PM
drlogik
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 513 Post(s)
Liked 175 Times in 112 Posts
I'm not sure I'd judge a bike by a single ride where you clocked 37 seconds faster. I would cycle that same route five times and average to see how you do.
On my 7 mile loop my times vary quite a bit but bounce around within about a 50 second spread. Some days I feel strong, other days not so much so.
A single 37 second ride improvement wouldn't be a good indicator for me; however, if my last five rides are 37 seconds faster than the previous average, then yes, something is different.
drlogik is offline
Likes For drlogik:
Old 06-24-21, 02:50 PM
halehankock
Quoted: 13 Post(s)
Well, I guess I'll be ordering some GP 5000s for my Specialized
Old 06-24-21, 03:25 PM
asgelle
Quoted: 838 Post(s)
Liked 297 Times in 187 Posts
It turns out the white horse was two inches taller than the black one https://startsat60.com/media/lifesty...ell-them-apart
asgelle is offline
Likes For asgelle:
Old 06-26-21, 07:21 AM
Mark Dominck
Bikes: Gino Liotto,Kuoto Kharma, Vitus 979, lemond,specialized Tarmac, Austro Daimler Pacifica
Quoted: 46 Post(s)
Liked 27 Times in 18 Posts
I have several bikes and they're each the fastest when the tire pressure is 120 psi, I run tubulars. Noticeably slower when it's 100 psi
Mark Dominck is offline
Likes For Mark Dominck:
Old 06-26-21, 07:47 AM
CAT7RDR
Quoted: 463 Post(s)
Liked 889 Times in 481 Posts
The slower bike obviously has parasitic gremlins.
CAT7RDR is offline
Likes For CAT7RDR:
Old 06-26-21, 10:09 AM
mattcalifornia
mattcalifornia's Avatar
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 87 Post(s)
Liked 91 Times in 54 Posts
According to this site: https://www.bicyclerollingresistance...prix-5000-2018, the GP 5000s will save you 9.3 watts at 18mph (assuming 120psi and a load weight of 94lbs) That's a meaningful difference. I'd definitely be interested to see what happens when you change tires.
mattcalifornia is offline
Likes For mattcalifornia:
