Continental bike tires
Old 06-24-21, 08:28 AM
nrsmd
Quoted: 25 Post(s)
I am planning on buying the Continental 5000 bike tires at Amazon: https://www.amazon.com/Continental-U...8-4&th=1&psc=1
I am confused as to the additional choices of 48 mm, 80 mm, and 60 mm. What do these refer to.
Thank you in advance
nrsmd is offline
Old 06-24-21, 08:31 AM
ClydeClydeson
Quoted: 243 Post(s)
Liked 337 Times in 218 Posts
THe link is to a tire+ inner tube set. The 48/60 etc. number is the length of the valve stem. If you have shallow rims you can use a short valve stem, if you have deeper aero wheels you should get a longer valve stem.
ClydeClydeson is offline
Likes For ClydeClydeson:
Old 06-24-21, 08:41 AM
nrsmd
Quoted: 25 Post(s)
Thank you for your quick response.
If all 3 will work, does it make any difference performance-wise which one to choose?
nrsmd is offline
Old 06-24-21, 08:43 AM
OkFine
Bikes: Cannondale F5, Bianchi Sempre Veloce eTap, Poseidon X
Quoted: 29 Post(s)
Liked 7 Times in 3 Posts
I can't imagine valve stem length having any appreciable impact on performance, but make note, the stem needs at least be long enough to clear your rim depth.
OkFine is offline
Old 06-24-21, 09:05 AM
ksryder
Bikes: yes
Quoted: 1230 Post(s)
Liked 579 Times in 300 Posts
No, but that won't stop this thread from reaching 10 pages of arguments about the various aero gains from shorter vs. longer valve stems.
I'm kidding but no, valve stem length won't make a difference.
ksryder is offline
Likes For ksryder:
Old 06-24-21, 10:20 AM
ClydeClydeson
Quoted: 243 Post(s)
If you have a shallow rim, it might be beneficial to use a shorter valve stem because a longer valve stem may put more force on its base when pumping, and this is a common spot for failures of tubes. In terms of performance I am sure there is zero difference, as long as your valve stem is long enough to easily connect to your pump.
Old 06-24-21, 10:49 AM
msu2001la
msu2001la's Avatar
Quoted: 569 Post(s)
Liked 456 Times in 283 Posts
It is an indisputable fact that much like sock length, long valve stems look more pro.
msu2001la is offline
Likes For msu2001la:
Old 06-24-21, 10:53 AM
Barry2
LRP=HR
Bikes: 79 Holdsworth Special, 93 C-dale MT3000 Tandem, 96 C-dale F700CAD3, 2018 Cervelo R3, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 359 Post(s)
Liked 352 Times in 225 Posts
If all the choices are the same price, I want more stem for my money!
More IS better
Barry
Barry2 is offline
Likes For Barry2:
Old 06-24-21, 04:21 PM
Bimmer69
Bimmer69's Avatar
Quoted: 18 Post(s)
Liked 20 Times in 13 Posts
challenge accepted.
long stems look stupid. And they weigh more. So keep it short.
but you don’t want them too short because then you can’t get some pump heads on the valve.
as for aerodynamics, just leave the cap off and you’ll be fine.
any discussion about the retaining nut, if the valve has the threads for it should be a separate 10 page thread.
Bimmer69 is offline
Likes For Bimmer69:
Old 06-24-21, 05:22 PM
tempocyclist
tempocyclist's Avatar
Quoted: 27 Post(s)
Liked 66 Times in 28 Posts
Long valve stems are totally un-aero and are the reason you're not winning the traffic light sprints...
Check out the INEOS marginal gain of hiding most of the exposed valve stem with a detachable deep section wheel cut-out thingo-ma-jig.
Photo from - https://cyclingtips.com/2021/05/fili...tom-paint-job/
But in all seriousness, as long as you have enough valve stem protruding above the rim so you can attach your pump / C02 inflator you will be fine. Make sure your spare tube does too!
tempocyclist is offline
Old 06-24-21, 06:00 PM
ksryder
Bikes: yes
Originally Posted by Bimmer69 View Post
challenge accepted.
but you dont want them too short because then you cant get some pump heads on the valve.
as for aerodynamics, just leave the cap off and youll be fine.
Unfortunately that thread got closed the last time I tried to bump it.
ksryder is offline
Old 06-25-21, 12:19 AM
Welshboy
PBP Ancien (2007)
Welshboy's Avatar
Bikes: B-Twin Triban100 (for commuting), Cannondale CAAD12, Cannondale CAAD12 Team CNCPT, CAADX, Verenti Technique
Quoted: 39 Post(s)
Liked 80 Times in 48 Posts
If you're using very tight wired-on clinchers then a long valve stem on a 'short' rim makes things a bit more fiddly when trying to get the inner tube out when you puncture.
Welshboy is offline
Old 06-25-21, 07:49 AM
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 530 Post(s)
Liked 172 Times in 122 Posts
It will if you buy a stem that's too short and can't inflate the tube. :-P
dmanthree is offline
Old 06-25-21, 08:13 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 5594 Post(s)
Liked 2,794 Times in 1,622 Posts
Its a pity that bike's frame was crumpled.
mstateglfr is offline
Old 06-25-21, 09:36 AM
pickysoul
pickysoul's Avatar
valve lenth.
pickysoul is offline
