Shimano bar end shifters rebuildable ?
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 248 Times
I have a Shimano Dura Ace 9 speed bar end shifter on my touring bike that skips over 4th gear when using it in index mode.
Had it quite a while so it is not surprising. Can they be rebuilt or do I have to buy new ones ?
Quoted: 5703 Post(s)
Liked 2,432 Times
It's an odd mode of failure. Before doing anything else, I'd cross my fingers and flush it with something like WD-40 and hope for the best.
Otherwise, I don't think it'll be serviceable.
FB
Chain-L site
FB
Chain-L site
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
you could try cleaning and greasing the mechanisms... use the correct shimano light grease... the pawls get blocked from entering the ratchet ring or get stuck from dirt/old grease chunks.
a good cleaning/regrease is the solution more times than not.
this holds true for most shifter failures on older bikes.
https://norvil.net/pedal/service/shim...ti/rebuild.php
Not lost wanderer.
Quoted: 885 Post(s)
Liked 979 Times
Probably with a set of parts from a DT shifter. I will check in my shop tomorrow.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
aka: Dr. Cannondale
Quoted: 2151 Post(s)
Liked 3,380 Times
They do eventually wear out but skipping just one shift is unusual. Agree that a thorough cleaning is the first step.
The shifting pod from a 9 speed downtube shifter will work just fine.
Super Modest
Quoted: 10894 Post(s)
Liked 4,559 Times
9 speed Shimano bar ends are notorious for cracking in the bezel which causes shifting problems as the internal parts begin to slip past each other instead of engaging. It starts off subtly like the derailleur needs adjustment but worsens quickly. Look for a crack in the plastic bezel. Never heard of anyone being able to rebuild one.
Keep the chain tight!
Likes For Trsnrtr:
Quoted: 1324 Post(s)
Liked 927 Times
Are you positive that it's the shifter and not a worn 4th gear cog?
Cheers
Cheers
Quoted: 2578 Post(s)
Liked 1,901 Times
Good point, and just about the best case you can hope for.
Those plastic parts will make an interesting sight when you open up a badly worn bar end shifter. One look inside and I was sourcing a new shifter.
It might be possible to rebuild the shifter, if you could find parts. AFAIK Shimano doesn't make them or sell them separately. If you're so inclined, you might buy a new shifter, measure everything very precisely, and save the resulting design to "additively manufacture" new parts as needed a few years down the road.
