Looking to Buy a Torque Wrench - Harbor Freight
I do a lot of minor work on my bikes, and I since I now have one with carbon, I think it's time for me to buy a torque wrench. I'm wondering if the ones at Harbor Freight are sufficient for my needs:
https://www.harborfreight.com/cpi/cta...Itemnumber=239
https://www.harborfreight.com/cpi/cta...Itemnumber=807
Any comments on these, or any other torque wrenches?
Bikes: Lynskey 210R, Cannondale CAAD2 MTB
If you only get one, you should get more use from a 1/4" model like this one:
https://www.harborfreight.com/cpi/cta...temnumber=2696
You may get some use from the 3/8" one for bottom brackets, but I can't imagine you ever using the 1/2" one on a bike.
Ted
Ted
Bikes: Schwinn Paramount P15, Fisher Montare, Proteus, Rivendell Quickbeam
Quoted: 12 Post(s)
I've got the Harbor Freight one and it works fine. The only thing I would caution you on using the clicker style ones is practice on low torque first until you are comfortable with what it feels like when it clicks.
Also don't let the torque wrench override common sense. If you are like me and have overtightened things in the past (not necessarily on a bike) to the point where the nut stripped or the bolt broke and it feels like you are about to do this on a bike, then stop and evaluate if your torque wrench is working properly or you really need it up to that torque.
I bought a $20 click, torque wrench from Harbor Freight, and couldn't get it to work. I took it back and ending up buying a Park Tools TW-2 Torque Wrench. It is a beam type torque wrench with greater simplicity and reliability than a click wrench imho. It also comes with a couple of lists for suggested torques for bicycle fasteners.
https://www.parktool.com/products/det...13&item=TW%2D2
I second the suggestion of getting a visual-indicator beam torque wrench for bike work. If the Park 3/8" drive one is too expensive, the Craftsman one should do fine in its place: https://www.sears.com/shc/s/p_10153_1...0P?vName=Tools
I've gotten a lot of stuff from Harbor Freight, but I don't think I'd trust their click torque wrenches to stay in spec (or maybe even to start in spec!). For torquing car lug nuts to +/- 25%, their 1/2" clicker on sale for $10 is so cheap you have to buy a couple, but precision work requires better.
Quoted: 1109 Post(s)
Liked 1,200 Times
First, for carbon parts, you're looking at inch pounds, and low ones at that. Remember 1 foot-pound = 12 inch-pounds. So you actually need the smallest range inch-pound wrench you can find. I bought a similar quality 0-240 inch pound click type and it really wasn't useful for what I need. It is not accurate in the very low range needed for stems, and isn't strong enough for a cassette installation. It worked OK for a seat post. These are the only DIY stuff I do that requires accurate torque.
After ruining an aluminum stem (luckily a cheap one, no big deal), I tested it carefully with a digital scale at a measured distance. It was pretty accurate in the middle of the range, but not at all in the lowest range, which is what they always say - and that is why the stem was ruined. I was waiting for the click and the actual torque was something like 2X the setting at the low end of the scale. If you're going to buy a click type torque wrench, get one that has a low enough range so the torques you're lookign for are somewhere in the middle.
I ended up buying the 1/4 inch (smallest) torque wrench from park tools (actually bought it from Performance) and it works much, much better for low torque things. I will probably buy the same wrench in the larger size as well and just be done with it. I can also use it for torqued aluminum parts on my little outboards.
Bikes: Fuji S-12s, Trek Navigator 200, Dahon Vitesse D7, Raleigh Sprite Touring ('70's)
I do a lot of automotive work, so have several torque wrenches - 1/2" click and a beam type, and a 3/8" beam. Buy quality... Craftsman, S-K, etc. I do have some 'throwaway' tools from Harbor Freight, but a torque wrench would not be my tool of choice.
The nice thing about beam type wrenches is that you would have to severely abuse one to push it out of calibration. Click wrenches are easily damaged, as the internal mechanism is based on compression of a coil spring. Springs that are left in compression sag with time, giving reduced readings. It is very important to dial in the value you want, use the wrench, then twist the handle back to zero when you are done. Leave it compressed on a high value for a week, and it may read a few ft-lbs low from now on.
The upside of a click wrench is consistancy of the reading (even if it is a bit off...). Unless you have a dead nuts perpendicular view of the scale and can hold the torque long enough to ensure an accurate reading, beam units can be tricky and yield different values in different hands.
No scale ever reads accurately at the very extreme ends. If most of your work involves low inch-lb values, don't buy a unit graduated in foot-lbs, as you will be lost somewhere between hash marks in the most inaccurate end of the wrenches range.
Hope this helps!
Hope this helps!
Your mom
I've ordered many tools from Harbor Freight with mixed success. Can't be beat for cordless drivers though - disposable at $20 for a 14.4V driver. You can drop it off a ladder and not worry about having to replace it. Actually, the one I dropped off the ladder is still going, albeit with a duct tape wrap.
As far as torque wrenches, I would be reluctant to use a Harbor Freight one. I've never used a torque wrench though.
J E R S E Y S B E S T
A torque wrench is probably one of the last things you should buy from Harbor Freight.
I think some of their tools are great, but I wouldn't trust their torque wrenches.
Healthy and active
Bikes: mid-60's Dunelt 10-speed, Specialized Allez Sport Tripple, Trek 7.2 FX
I have posted this close to a dozen times, but torque wrench discussions pop up like dandelions.
I made my own torque wrench for inch pounds. The basic components are a ten inch steel bar and a dial indicator fisherman's scale. Check the calibration on the scale with a known weight and adjust the length of the bar accordingly. Make a fitting on one end of the bar to hold hex key wrenches. Total investment in cash was about $5 US.
Get bicycle torque specs. with a downloadable PDF chart at www.parktool.com.
Bikes: '70 Leopard (Swiss), '70 Raleigh Super Course, '74 Raleigh Super Course II, '73 Raleigh Grand Prix, Schwinn Montague folder, C-dale M-300, C-dale M-400, C-dale R-900, C-dale CAAD-3
Harbor Freight makes great disposable tools. You know, the tools you might keep in your car's trunk and you won't be too upset if they get lost or stolen. Tools you only use once or twice.
Seriously, don't buy cheap tools. Like bread and whiskey, it doesn't have to be expensive to be good, but avoid the cheap.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Then expand your mind, grasshopper!
I use a 1/2" clicker for anything 30+ '#. So long as one is within the accuracy range (15+ on this one), the longer lever arm is great.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Elitist Troglodyte
(Be aware that some of the 3/8" are uni-directional. That's okay for most application, but bikes have some reverse threads.)
- Will Rogers
- Will Rogers
Haha, I didn't know that, but, if Nashbar's torque wrench is anything like some of their bags, I'll still pass.
use your best eye
Bikes: '75 Bertin, '93 Parkpre Team 925, '04 Kona King Kikapu, '05 Bianchi Vigorelli
Sorry, but IMHO Harbor Freight tools are junk, good only for limited and/or throw-away usage. Accuracy is not synonymous with HF.
Here's an excellent TW by S-K, 3/8" drive, 0-100 in. lbs., made in the USA, for $80: https://www.superiorpaneltechnology.c...p/skt74104.htm
I suggest 3/8" drive because 1/4" drive hex bits are difficult to find.
"I tell you, We are here on earth to fart around, and don't let anybody tell you any different." - Kurt Vonnegut jr.
Quoted: 12 Post(s)
For most people, a torque wrench is for very limited use. Furthermore, the accuracy of torque values on bikes is also thrown off based on whatever lubricant is chosen to put on the threads.
Healthy and active
Yes, but the torque specs are also given as a range (e.g. 40 - 55 in. lb.) rather than a precise target. Using a torque wrench, even if not completely accurate, still gets one closer to what is needed and avoids twisting off a bolt that may be hard to find at the hardware store when time is short.
Although I've purchased quite a few tools from HF, I don't know if I'd trust a click type wrench from Harbor Freight to be accurate.
My advice to you is to buy a quality beam type wrench -- Craftsman, SK, MAC, Snap-On. I always use a beam type wrench if the situation permits, although in some cases a click type is the only practical way to go -- like when I'm on my back underneath a Cadillac.
Bikes: Vision recumbent
I"ll just agree with everybody that has said, "buy quality"! There are some things that cheap tools would be ok on, but I cant imagine anything with the word carbon in it as one of them. You will get what you pay for when it comes to brand name tools. When in doubt, go ask a good LBS that works on carbon bikes as to what they use. I do stress the word GOOD also.
Elitist Troglodyte
Frankly, it's quite difficult to screw up a torque wrench. This isn't rocket science. If I was to worry about anything I'd worry about the quality of the plating on the 1/4". But I just don't care so long as it does it's job, which it is doing very well, thank you.
+1 on the availability of 1/4" hex bits; they're hard to come by. But so far that's not a big deal for me. You only need 1/4" bits for the fasteners that are out of range of the the 3/8" wrench: 4mm or smaller. The 4 & 5mm fasteners I've had to torque are mostly high-spec ones like seat post and bar clamps.
- Will Rogers
- Will Rogers
Healthy and active
Someone once suggested buying a set of 1/4" drive sockets in metric sizes. Buy an extra set of Allen or hex wrenches in metric. Saw the hex wrenches off and mount in the 1/4" drive sockets to make your own.
