cadence meter for $12
Senior Mumbler
Bikes: Ridgeback Voyage (for touring and commuting), unknown beach cruiser (for smiling)
I came across this article, on building a cadence meter for $12, via lifehacker and thought it might be interesting to people here, we often seem to talk about cadence.
https://www.instructables.com/id/Very...-Your-Bike-12/
Triathlon in my future???
Bikes: Junk, that is why I am here. :-)
You can get cadence on many cyclometers very cheap anymore. I think I paid less than $35.00 for my cyclometer with cadence and it is a Cat Eye Astrale 8.
2007 Jamis Ventura Comp
2006 Jamis Explorer 2.0
2000 Specialized Hardrock (bought used)
Swim, Bike, Run and sounds like fun
Destroyer of Wheels
Great idea, thanks!
The Almighty Clyde FAQ || Northeast Index
eTrex Vista References || Road Reference
It's the year of the enema!
Healthy and active
Bikes: mid-60's Dunelt 10-speed, Specialized Allez Sport Tripple, Trek 7.2 FX
I want to try this. My bike is a triple. The granny gear is steel, but it is small. The magnets could attach to the gear, not just to the bolts. Still, I would want to make magnet holders out of sheet metal for each magnet and run the bolts through the holder for a more secure attachment. Even then, I am not sure I can get the pickup close enough to the BB to "read" the magnets passing.
But, I had another thought I want to try first. I got a package of five button magnets at Radio Shack. One of them fits into the slight recess for the inner end of the left pedal at the crank. I would set the cyclometer for a wheel size of 1,666 mm rather than 3333 mm (1/5th of 16,666 mm) and multiply the display reading by 10 for my cadence. It seems like it should work and I would have a better magnet mount, as well as more room to mount the pickup coil.
Healthy and active
I have now tried the $12 cadence meter. I used one magnet stuck to the end of my left pedal where it fits into a nice little recess and will not easily come off. It is a round button magnet that came in a pack from Radio Shack. I programmed the cyclometer to a wheel size of 1667 and to read in Km/Hr. I ignore the decimal point in the display for a direct reading of my cadence. I made a bracket from heavy wire to bolt to the water bottle screws on the seat tube and to hold the pickup. This involved a little welding, but I have a welder.
As an accuracy check of the cadence meter I memorized my speed, cadence, and gear during part of today's ride. I used the following formula to see if the results equaled what I got from the meter: cadence = 336 x miles per hour/gear in inches. (336 is a constant.) The meter is accurate.
I had always thought my cadence was hopelessly stuck in the 60's and 70's, but discovered I actually hit 90 rpm for a while and was frequently riding in the 80's. I will use my new cadence meter to monitor my shifting from now on and will attempt to stay in the 80's.
It works very well.
It works very well.
Destroyer of Wheels
I love the fact you had to weld to get it to work - man after my own heart!
Healthy and active
I think a little careful experimentation with some paper to develop a pattern I could use to cut a mounting bracket out of galvinized sheet metal would have worked, but I try to weld whenever I can find an excuse.
I went on a 28 mile group ride yesterday and used the cadence meter to hold my cadence around 85. Whenever it dropped below 80 I shifted down. As soon as I shifted my cadence jumped to almost 90. People riding around me were starting to breathe heavily at the start of a slight upgrade. Not only did I not break a sweat, but I was passing people again and again. I did come home and take a hard nap afterward, though.
