Combining different wheels front and rear
RS81 tubeless front and Ultegra WH-6800 tubeless rear. What do you guys think about it? Would there be any problem other than aesthetics?
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
Isn't the aesthetics a big enough problem to stop this abomination from happening?
Also, the different hubs would spin at different rates causing harmonic imbalance and tire wear differentials. If your bike is crabon it will certainly asplode at speed.
Super Moderator
Quoted: 1173 Post(s)
Liked 924 Times
Bad idea !!
The "better" wheel will be resentful of being paired with a "worse" wheel, and thus not give optimum performance.
The "worse" wheel will feel inadequate, and try too hard to compensate, and wear out prematurely.
Quoted: 2952 Post(s)
Liked 3,106 Times
Bikes: 02 Cervelo P2K, 07 Cervelo P2SL, 07 Cervelo Soloist, 09 Cervelo RS, 96 Quintana Roo Kilo, 80 Chicago Schwinn Letour, 12 Motobecane Nemesis, 97 Kona AA, 97 Cannondale f700
Quoted: 11 Post(s)
Liked 35 Times
I do it fairly often, mostly because my power meter is on a Hed Belgum wheel set, not my racing wheels. This is what my I rode for my last triathlon:
Señor Blues
I'm running 2 entirely different wheels front and back. I'd prefer to use, and will eventually have a matched set of wheels. That said, my current setup seems to be causing no adverse issues.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
OMG, I couldn't sleep if I did that!
Hell, I couldn't sleep if you did that...
Today, I believe my jurisdiction ends here...
Should Be More Popular
Quoted: 22513 Post(s)
Liked 8,843 Times
Sorry i forgot to mention that those 2 wheels has exact same hub(RS81 hubs are Ultegra). So only difference is rim material and (maybe) spokes.
Ultegra rim has a weird color and i agree with comments above about aesthetics. I don't know why Shimano choosen that kind of color instead of just normal grey like RS81. Meh. OTOH i'm still considering this combo.
I will look around till Schwalbe relase Pro One tubeless tyres.
This is a neat looking Cervelo. Only the frame tho.
Super Moderator
Liked 924 Times
Liked 3,106 Times
No, but I did have a seized nipple. It'll eventually fail, but in the meantime, it's on my son's bike. A 75lbs, he isn't putting too much stress on it. This picture is 3 or 4 years old and I raced and trained on them for a couple of years before that. I bet those Ksyriums probably have 50K miles on them by now.
You all could probably guess that I flatted, got back to the wheel pit, and took my free lap.
