Suntour V GT Luxe Install
Count Orlok Member
All right, be patient with me--I'm normally in the English 3 speed thread. These derailleurs are new territory to me.
I found a Suntour V GT Luxe long cage derailleur at the bike recyclers and bought it for $5. I took it apart and cleaned and greased it. It seems to be a very nice derailleur: SunTour V GT Luxe derailleur (1500)
I want to replace the Suntour AR on my Raleigh Wyoming with this one. Everything I've read says I need to break the chain or remove the tension pulley to change a derailleur, but from looking at them, one doesn't need to do that with a Suntour. It looks pretty simple, honestly. Or am I missing something? The tension pulley can be removed easily, and the cage for it does pivot.
You don't need to break the chain if you can remove the pulley wheel. But, a nice feature of many suntour RD's possibly including yours, is that one of the cage plates is 'split'. the chain then be removed and installed (to/from the RD if not necessarily the front derailleur too) without breaking the chain or removing a pulley wheel.
Quoted: 741 Post(s)
Liked 818 Times
I love my VGT Luxe, and have two of them on Raleigh Super Courses. Before I realized that the split cage was a "feature" it annoyed me that the chain would pop out of the cage on wheel changes. With a new bike build, my first, there was a lot of trial and error, wheels on and wheels off, and I never got used to keeping track of the chain when I removed the wheel. In operation, moving down the road, they work great and allow the use of a 6 speed 34t Megarange freewheel.
VGT Luxe on my '73 Super Course.
VGT Luxe on my '78 Super Course
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times
You can remove the chain (or even the derailleur) without breaking the chain or removing pulley wheel on those. You aren't missing anything. Great design. Suntour Cyclone and a few others are the same.
Count Orlok Member
Thanks everyone.
Nice Super Courses
Yes, got a Mega Range 6 speed 34T freewheel as well. Slowly turning it into a touring bike.
Nice Super Courses
my tourer is currently being rebuilt, and I use a vx-GT.
Quoted: 741 Post(s)
Liked 818 Times
Another tip: give them as long a chain as you can, maybe even to the point of letting the small-small combo rub a little if necessary. These suntour derailleur are wonderful and the only thing that could let you down ‘spontaneously’ is the main pivot spring: they are old pieces of steel and can snap if made to bend too far. So I always give them a lot of chain, enough to make even big-big not a huuuge stretch, and bear that little spring in mind when shifting. With normal good gear technique you can keep it safe.
When I built the gold Super Course above, I was surprised that it took the whole KMC 8 speed chain. Usually I need to remove a couple of links. I did on the green one above, but it is a triple with 32t granny up front, a 40 middle, and a 50t big ring. Both have 34t Megarange freewheels and KMC 8 speed chains. The gold one has a normal 52/42 double. Both seem to ride and shift great, though the triple sometimes gets hung between chain rings, usually due to pilot error.
Quoted: 796 Post(s)
Liked 522 Times
It is a nice SunTour feature but for future chain purchases I highly recommend a quick-link chain like the SRAM 8 speed chains -which work fine on 5-8 speed bikes, or KMC. I have developed a deep and unreasonable hatred for pin connector chains. (looking at you Shimano). Have fun with the touring bike @gna
