Hitch rack with frame arm - bike securing tips?
Quoted: 1109 Post(s)
Liked 1,200 Times
I have a similar rack, but made by Yakima. But it has trays and the arm bears down on the top tube like the Swagman OP uses. Frankly, I have never liked that design because of the fussing I have needed to do to keep it from, at best, scratching or at worst, damaging the top tube. I couldn't get the kind that fixes onto the wheels instead of the top tube because at the time, we had bikes with fenders and I couldn't find one that worked with fenders. Since I now have several bikes in the family that really deserve better care, I might sell it and invest in a better one.
All that said, here's what I've learned:
I have put clear frame protecting tape on all my bikes where the arm contacts the top tube. I keep a roll of heavy duty duct tape on hand to put a piece on any other bikes I may have to transport.
I use a piece of pipe insulation, but that wears out fast because it's fairly soft. The padding doesn't negate the need for frame protection (tape) because grit/dust can get under the padding and still scratch the paint.
For bikes with a really angled top tube they make these things: https://www.skicountrysports.com/pro...-DEFAULT-l.jpg
There's a lot of versions, but they're all about the same. I think they're made for hanging carriers, but I've used them for my upright carrier and they keep the pressure off the top tube.
Finally, boy, I've used my rack - again similar to OP's - for many years on rough roads with many bikes, carbonfiber and metal. Other than finish scratching when I don't protect the frame properly, I have never seen any damage to the top tube. It seems strange that it would dent steel unless it's really, really (really, really!) excessively ratcheted downward.
Maybe ratchet it down less and substitute more bulky padding?
Maybe inspect the contact points of the carrier to make sure the original padding is not eroded exposing metal which is then contacting the top tube? I recently noticed that the original hard rubber padding on the upright arms has worn away and one of them has bare metal showing.
Likes For Camilo:
Liked 1,200 Times
don;t be that 'cold-set' guy - snug is fine, especially if you have decent tire pressure...
Your thread has warned to to NOT be that 'Cold-set' guy.... LOL!
Ride On
Yuri
Ride On
Yuri
Likes For Camilo:
