Handlebar bag support
#52
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,829 Times
#53
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,865 Times
I can fit three 20 ounce water bottles in this bag, with room left over for the standard tire change stuff. When the bottles are on the bike where they belong, this will hold a long sleeved jersey or an uncompressed jacket. Plus, when you have space you always find more things that you want to carry along.
My Bikes
My Bikes
Likes For Andy_K:
#54
It would not surprise me if you were serious. If I had confidence in sourcing and selecting the correct tubing -- strong enough to hold, soft enough to form -- and the right bender, it might be fun.
I seem to recall something about filling tubing with sand before bending it, to prevent collapse?
#55
Quoted: 3804 Post(s)
Liked 6,643 Times
I believe @nlerner has one that will double as a dwelling for a small family. The bag from my first post is a bit of a compromise.
Dave Cain at Waxwing does wonderful work. And it's paired with a @gugie decaleur making it rock solid no matter the load.
For much of my road biking that calls for more than a small seat bag, I use a relatively small bag from Outer Shell:
It's super versatile, easily going from bike to bike without the need for any attachment hardware.
#56
Bikes: Yes
Liked 3,865 Times
True, but I see the bag in your picture blocks using the center of the bars as a hand position. The support in post #8 (but not the one in post #1) places the bag far enough from the bar. I tend to ride up top a lot. I seem to recall the product in post #8 used to be commercially available, but I presume no longer?
My Bikes
My Bikes
#57
Bikes: Yes
Liked 3,865 Times
They lose me at rule #47. I'm happy to drink tripels, but I need to ride triples as well.
My Bikes
My Bikes
#58
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
gugie Have any tips and tricks to share?
It ain't rocket science folks. Grab some tubing, bend it up. Maybe you'll make a mistake, but the raw material's not expensive.
Likes For gugie:
#59
Bikes: Yes
Liked 3,865 Times
Having just reviewed the rules, they actually lose me at rule #1 (Obey the rules), but I think I can claim to solidly obey as many as 29 of the 95 rules most of the time.
My Bikes
My Bikes
#60
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 977 Post(s)
Liked 626 Times
Oh, I'm serious. I've already posted what you need to do this earlier. I"ve sourced the tubing I used for you. Sand? you might do that for larger diameter tubing, not for 1/4". As noted earlier, the tubing bender will ensure you don't collapse the tubing. If you want to see it done I'm sure there are plenty of youtube videos. It ain't rocket science folks. Grab some tubing, bend it up. Maybe you'll make a mistake, but the raw material's not expensive.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
#61
Quoted: 767 Post(s)
Liked 1,898 Times
As far as sand goes, I've never heard of that. Back in my metal forming/factory work days I ran a big tubing bender for producing cart handles out of 1" 16 and 18 ga. mild and stainless tubing. We used mandrels similar to this one:
Stainless of that size can be a real PIA to form, as the spring back is less predictable and it tends to wrinkle. At the smaller diameter and with a good bender, you should have little worry. And the cost is relatively low.
#62
Liked 6,643 Times
Another DYI-ish approach that doesn’t involve tube bending is the “Pec Deck” from Ronny Romance:
https://bikepacking.com/news/pec-dec-saddlebag-support/
His video is pretty insufferable, but with those Nitto stays and the right bag, it should be easy to rig something up.
#63
Quoted: 809 Post(s)
Liked 1,018 Times
@gugie thanks for the part number. This is the same tubing that I used for shifter cable guides. Bike Forums - Cable Guides That makes it pretty versatile. Custom racks, handle bar supports and shifter cable guides, all stuff I will be working on at some point.
#64
"Rack" below constructed with a couple rack struts, a wooden dowel, and some sloppy speedy-stitching on an old Zimbale saddlebag.
#66
Quoted: 977 Post(s)
Liked 626 Times
Over 50 years cycling, I have never had a handlebar bag. Even my one week-long cycle camping trip in 1974, everything went into rear panniers -- climb into the foothills of the Appalachians, all weight on the back made for interesting handling of the bike.
That said, the support is a single length of rod/tubing, so I need to come up with something like a think rubber cylinder to get from rod diameter to handlebar diameter to attach the bag. I'll keep thinking...
#67
Liked 5,790 Times
I still want to try this, long-term. But I found a way out, for my use. Saw a Cannondale bag on eBay, with a "stem hanger" bar that holds the bag away from the bar but no real underneath support, for $60. I offered $30 and he keeps the bag, I just wanted the support; the seller accepted. For the shorter day trips I take, a smaller bag will be just fine, I am contemplating a small one from Velo Orange. The stem hanger has forward-projecting arms, I could rig a strap underneath if I needed support. What I really like compared to other bag supports is no hardware bolted to the bike so I can move the bag from bike to bike quickly.
Two things were ingrained into my brain at an early age.
1. Handlebar bags are extremely handy on longer rides. It's like having a glove box on a bike.
2. Riding down the Pacific Coast in 1977 on a week long tour, having the load in the back made for a lot of "tail wagging the dog."
handlebar bag, good - all that weight in the back, bad (1977)
2016, eight out of ten bikes in this picture are front loaded
#68
Quoted: 977 Post(s)
Liked 626 Times
99-44/100% sure you are right considering the light loads I anticipate; but it allows getting the bag away from the bars to allow the on-the-tops hand position, and for some reason I am fixated on that.
#69
Liked 5,790 Times
You're not alone, that's a very good reason for doing this! I started making my own decaleurs for this very reason (bigger bag, needs a front rack). The commercial solutions available did not meet my need, so I made my own. Most of the handlebar bag supports that resemble Andy's haven't been made for awhile, the randonneur crowd has been driving the front rack + decaleur solution. Smaller bags and the fact that many of us have multiple bikes makes a slip on handlebar bag support an excellent option.
#70
Liked 6,643 Times
In terms of handlebar bags that can go bike to bike without a decaleur or rack, I bought this Ortlieb bag last summer. I like Ortlieb because the do waterproof bags really, really well, and the size of this bag seemed useful to me. I haven't actually used it yet, but it should hopefully see some touring use this coming spring and summer.
Likes For nlerner:
#71
Quoted: 2588 Post(s)
Liked 4,823 Times
You weren't kidding; after 43 seconds I had to bail. Plus, that dude's only 21? He looks like he's in his 40s
DD
DD
#72
Quoted: 977 Post(s)
Liked 626 Times
#73
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
#74
Liked 6,643 Times
I have this one, too, as Doc saw on our Virginia tour this past summer:
#75
Quoted: 472 Post(s)
Liked 1,028 Times
Also, the ease of swapping that hanger from bike to bike to bike depends a lot on how the brake cables are routed on each and how long they are. My bikes have non aero cables, all routed over the bars but some front cables route to DS, some to NDS. The height of the hoops and whether or not they cross and where and if you have computer cables, etc, can make installing the hanger easy or tricky or very tricky. I’ve got to just leaving the hanger on one bike and having a separate bag for each bike that needs one. But then, I seem to be carrying more stuff since, eh, shall we say, the last two years.
