80mm 45 degree stem
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
They are ugly, and also heavy, but an adjustable stem would do what the o.p. wants. I do concur, however, with any opinion that suggests that there really is more than one way to skin this particular cat. The laser focus on an 80mm/45deg is hindering any thinking outside the box.
Pennylane Splitter
Bikes: Yes
Quoted: 1797 Post(s)
Liked 1,439 Times
I've got two bicycles with these on them. I originally bought one to find a good fit on both the bikes, but its fabricated substantially enough that I just left it on as the full-time stem and bought another for the other bike.
I'm so confused on the 80mm/45 degree stem. I'm looking at the ergotec website. They have a 70mm/45 and even a 55mm/45. Why doesn't anyone make an 80/45? Is there something about that combo that makes it impossible to manufacture?
Quoted: 6193 Post(s)
Liked 4,808 Times
If it's not just a shortage of inventory, then probably its a lack of demand.
Likes For Iride01:
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
Why get so hung up on the numbers? If you need 10 mm, change your handlebars. I run the Ergotec Moon Cruiser 31.8 bars myself, with 50 mm of rise, but there are a bunch of bars on that same website with varying degrees of back sweep and rise, they're nice and safe with good German quality and they're cheap. I had a High Charisma 110 mm stem from that website that I used with a Jones bar, and I could have dropped the ends of that bar by 30 mm to make it an 80 mm stem in effect, had I been after an 80 mm stem myself. If you can't find an 80 mm stem, use a 90 mm stem and take 10 mm off your steerer tube, or twist your bars downwards by 10 mm, maybe try not to get hung up on a single measurement and work with what is easily available.
Liked 4,808 Times
Don't know what type bike you have, but riser bars might add the height you need with a different stem. 30mm of rise is typical for riser type drop bars on a road bike. With a 25° rise and 60 mm long stem, that would put your hands in the same position as the stem with 45° rise and 80 mm length.
The 70mm and 45 rise stem you mentioned is only 7 mm lower and closer. Just a tad over 1/4" difference than the holy grail you are seeking.
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
Are you using drop bars or a flat bar/alternate bar?
So I put a 90mm adjustable stem and maxed it out at 60 degrees. It was really nice to have no pain for once. Problem is it's a cheapo from Amazon that weighs 350g.
Does anyone know of a manufacturer of a high end, light weight adjustable stem with that kind of range? I'm willing to fork over some dough since it seems like what I need.
A different riding position with a new bike requires time to adapt. Professional bike fitters account for it.
It might be prudent to give it a month or two dealing with some discomfort before changing anything. There's a very good chance that discomfort will go away completely within that period.
If I don't ride my bike for one month (doing indoor trainer work for instance, unable to ride outside), I get sore neck and shoulders the first time I go back riding. It will go away completely after a week or two of daily riding.
Likes For qwaalodge:
Quoted: 233 Post(s)
Liked 165 Times
Check Analog: Stems (analogcycles.com) The guy is obsessed with long frames and high, short stems with drop bars; he is NOT a fan of low trail bikes. In fact, he has issued a fatwah (Debunking Low Trail (analogcycles.com)) against low trail bikes; rumor says Jan Heine cried when he read it. Dude's not short on opinions: True Facts (analogcycles.com) He also doesn't like cheap, mass-produced high rise stems much either. Needs to be taken with a grain of salt.
Likes For PDKL45:
Thanks everyone. If anyone sees a fixed stem that's 90mm and 60 degrees in your shopping excursions online please remember me and link it here.
I can't stand the weight and feel of the adjustable stem. The best compromise I am finding is a 80mm 45 degree stem, and I might have to run unsafe washers to get the stack higher. Short torso sucks!
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I think someone mentioned this but some companies make bars with a rise. I have a Specialized carbon one but they make alloy too (Hover). Redshift Sports does too, I think. That will give you additional height anyway...20mm-25mm.
You're going to struggle to find an 80 mm stem at 45 degrees.
Why not just go for one of the Ergotec 90 mm stems? A few of these would work just fine.
Products - Ergotec
Products - Ergotec
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
That’s one of the wildest collections of stems I’ve ever seen.
I can’t help but think there’s a significant bike fit problem here. I’ve never seen an outlier part installed on a bike that wasn’t some kind of work around for an improper fit. I don’t know the details, but this one seems odd.
Of course, 80mm at 40 deg is getting the bars really close to the steering axis. That may or may not be a problem not knowing what the bar setup is. But sometime you gotta do what you gotta do.
Likes For Kapusta:
Quoted: 1561 Post(s)
Liked 1,734 Times
https://www.ebay.com/itm/393046995459
Likes For icemilkcoffee:
Advanced Slacker
Liked 2,537 Times
From reading your posts here, I think you may already be familiar with using a stem calculator.
Have you looked into other stem rise/length combos along with changes in spacers (more or fewer) that would five you the same change you are looking for?
Quoted: 233 Post(s)
Liked 165 Times
Look on eBay, there used to be cheap ones from the UK. Also check the German online retailers like Bike24 etc. Just Google it and see what comes up in the results, from online sellers, as you can often find the best deals doing that, rather than searching specific sites.
On the plus side, I got this bike dialed in near perfectly. I had to go with a 90mm, 65 degree stem, and 40mm of spacers. There is zero fit problem or any other nonsense. I simply have the legs of a 6"2 man and the torso of a 5"7 man! Now that I'm comfortable, I can bike hundreds of miles...and fast. I bet I could blow away a lot of the dorky snobs.
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
It helped us figure out that my wife needs a 100mm 6° stem. All of our assumptions about needing short reach and high rise were incorrect.
FWIW, she is 5'7" with long legs and short torso, and is on a 52 frame (Sage Barlow).
I have the 90mm Ritchie one. It is high quality, but by no means lightweight. The cheapo ones are dangerous.
p.s. Why are they dangerous?
Liked 3,434 Times
Many years ago I got a cheap one on Amazon, and it loosened and slipped while my kid was riding fast down a hill. Fortunately he managed to keep control and stop the bike.
The Ritchie one cannot slip. You have to take the whole thing apart to change the angle, which is inconvenient, but far safer. I recommend one like that if you or anyone should require an adjustable stem.
A lot of bike fitting winds up being counter-intuitive, as you have probably discovered. We just assumed we would need a lot of stack and an extreme stem. She wound up being more comfortable with 30mm of spacers and a totally conventional stem.
Likes For Polaris OBark:
I have a cheap one, so I'll have to make sure to check the bolts on it more often. Thanks for the head's up. If a name brand makes one with the angle I need I'd gladly pay up. But they're about 10 degrees short last I looked. The only one that was 65 degrees was a cheapo no-name brand. I love that stem, though. It's allowed me to rack up thousands of miles in the past few months when before that I was on the cusp of giving up this bike.
Hi, I had been searching around some Euro sites for that Ergotec. Many are sold out in the length I was looking for. It's the postage that kills. Did you know they made a 130mm too? Ergotec doesn't have much presence stateside and none here in Canada. Been checking Oivey, nothing much there. Was considering BikeInn but I wanted to get the bike rideable this year before the snow flies.
climber has-been
Quoted: 3427 Post(s)
Liked 3,563 Times
I just ordered something from them on Friday, my first order with them. Today is Sunday, and apparently the parcel has been "created". So far, a speedy response.
