Simplex retrofriction problem
Old 07-09-22, 07:51 PM
kroozer
vintage motor
kroozer's Avatar
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 111 Post(s)
Liked 55 Times in 43 Posts
The steel clamp-on band for my Simplex retrofriction shifters broke the last time I removed them from a frame. That kind of sucked, but I figured I would just mount the levers on a spare Simplex Criterium band, or else mount them directly to a frame with brazed-on studs. Well, it turns out that the diameter of the mounting holes of the shifters is too small for either option. What were they thinking? I thought these things were compatible with standard shifter mounts because I have seen photos of them on all kinds of bikes. I'm thinking it's not going to be easy to find another mounting band with small diameter studs, but I'm also hesitant to drill them out to standard diameter. Any ideas?
kroozer is offline
Old 07-09-22, 08:05 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1254 Post(s)
Liked 775 Times in 547 Posts
The levers that were mounted on band clamps at the factory were different, as you have found.
Perhaps some other band clamp might be made to be compatible, or maybe they would fit on older Shimano frame studs?
Last recourse, might be useful for parts, for where a clamp-on retrofriction shifter got bent/broken, or failed internally(.?)
dddd is offline
Old 07-10-22, 03:32 AM
oneclick
Quoted: 763 Post(s)
Liked 808 Times in 496 Posts
Actually, the lever is one of the few parts that does interchange between versions.
As do the springs - which are a part that might break, so yes keep. Keep EVERYTHING. (That's one of the rules, always keep all the parts.)
Depending on where the band is broken it might be an easy braze or silver-solder fix. Pic?
oneclick is offline
Old 07-10-22, 04:40 AM
smontanaro
Bikes: many
Quoted: 1121 Post(s)
Liked 824 Times in 452 Posts
kroozer Can't help with your dilemma, but I can sympathize. I have one that broke on installation. I think it was (nearly) new. I eventually found a clamp somewhere (eBay probably), so I was able to actually use the levers.
It seems these bands weren't very high quality parts. I wonder if they were also produced either in two versions (metric and English) *or* in one version which split the difference.
Contact me to help Doug Fattic's colleagues in Ukraine
smontanaro is offline
Old 07-10-22, 06:04 AM
ehcoplex
Bikes: '38 Schwinn New World, '72 Peugeot PX-10, ‘7? Valgan, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ’97 Cannondale T900, '98 Peugeot Appalaches, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Herc
Quoted: 351 Post(s)
Liked 580 Times in 296 Posts
There is a thread here somewhere that does a deep dive on the parts differences with Retrofrictions, as well as some suggested solutions (IIRC involving drilling/reaming/tapping......).
You could try Wayne Bingham (veloclassique@gmail.com) for a band- he had what I needed to resuscitate 2 pairs of Retrofrictions I got on eBay that were missing all kinds of internal bits....
ehcoplex is offline
Old 07-10-22, 01:37 PM
kroozer
vintage motor
kroozer's Avatar
Quoted: 111 Post(s)
Thanks for the ideas, I'll try to get a hold of Wayne. I tossed out the broken clamp, although now I'm going to comb through the wastebasket to see if it's still here.
kroozer is offline
Old 07-11-22, 09:05 AM
santa fe 2926
Bikes: Roberts SLX, Mercian 531, Torpado SLX, Peugeot PSV-10, Charlie Roberts full touring
Quoted: 51 Post(s)
Liked 37 Times in 27 Posts
Try surfing picclick.fr, eBay France, for some replacements. Several years ago, Wayne Bingham, Velo Classique, rebuilt several pair of frame mounted with new springs. Good luck.
santa fe 2926 is offline
Old 07-11-22, 09:36 AM
smontanaro
Bikes: many
Regarding compatibility, are the Simplex Retrofriction bosses different than plain old vanilla Simplex bosses? I see plenty of "colliers manettes Simplex" on ebay.fr, most single lever for some reason, but also not for much dough (sans livraison).
Old 07-11-22, 10:46 AM
kroozer
vintage motor
kroozer's Avatar
Quoted: 111 Post(s)
I tried the levers on another Simplex clamp-on band (I believe Criterium) and they were not compatible, so this idiosyncrasy does not appear to extend to the rest of the brand.
kroozer is offline
Old 07-12-22, 12:59 PM
mtbikerjohn
mtbikerjohn's Avatar
Bikes: a few..
Quoted: 53 Post(s)
Liked 69 Times in 43 Posts
Have you seen this?
https://www.bikeforums.net/classic-v...aze-clamp.html
mtbikerjohn is online now
