cassette rattling
cassette rattling
Old 09-26-14, 02:24 PM
hubcyclist
Quoted: 463 Post(s)
Liked 609 Times in 323 Posts
cassette rattling
I had a cassette swapped last week, went from 12-23 8 speed (Shimano) to 11-28 8 speed (SRAM). I was out for a ride today and heard a rattling sound coming from the cassette, and in inspecting it it seems as if it's a bit loose. The lockring is definitely tight enough, and it appears to have all the spacers. The one thing I'm reading that could potentially be is a spacer between the 28 and the dork disk, although my old shimano cassette doesn't have one. Any other troubleshooting ideas while I wait to talk to my local repair guy.
hubcyclist is offline
Old 09-26-14, 03:05 PM
FBinNY
Quoted: 5256 Post(s)
Liked 1,561 Times in 894 Posts
The lockring is analogous the the top cap on a threadless headset. Just as the steerer has to be short of the spacers so the top cap doesn't bottom the freehub has to be recessed into the outermost sprocket for the same reason.
Or to put it another way, you need the outer sprocket to overhang the front of the freehub by 1-2mm (no more) so the lockring is pressing on the cassette and not the freehub body. L
Loosen and remove the lockring, check for overhang, and add a spacer behind the cassette if necessary, then tighten to spec.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 09-26-14, 09:03 PM
AAZ
AAZ's Avatar
When that happened to me, the cause was an incorrect sized spacer - a nine-speed spacer was in a eight-speed cassette set.
AAZ is offline
Old 09-26-14, 09:26 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 744 Post(s)
Liked 520 Times in 303 Posts
When that's happened to me, I usually find that the final, smallest cog has rotated so the splines don't match up. The one big spline on the cog is sitting on top of the cassette body, preventing it from being fully tightened.
Jeff Wills
Jeff Wills is offline
moondog321
Bicycle Mechanics
12
01-11-22 07:53 PM
BROOKLINEBIKER
Bicycle Mechanics
4
02-26-14 06:19 PM
AshbyRich
Bicycle Mechanics
10
02-04-13 02:59 AM
micah356
Bicycle Mechanics
4
10-09-10 07:20 PM
