Consensus on vintage binder bolts?
Quoted: 189 Post(s)
Liked 473 Times
Thanks all! Ok - looks like Sugino and a file or dremel. But, I do have a couple bikes that I feel need that Campagnolo stamp. Off to the WTB…
elcraft
Bicycle Bolts, offers “security” versions of binder bolts in several sizes. These need a special, included hex key to tighten.
See;
https://www.bicyclebolts.com/
See;
Quoted: 3464 Post(s)
Liked 2,829 Times
Liked 2,829 Times
Quoted: 3015 Post(s)
Liked 3,802 Times
Quoted: 3241 Post(s)
Liked 2,512 Times
This doesn't solve the specific needs of the OP. It is a "searching for binder bolt thread though, so the link will be useful down the road.
https://www.bikeforums.net/classic-v...se-frames.html
Quoted: 4233 Post(s)
Liked 2,948 Times
If you don't get the full kit, it's about the same as a vintage Campagnolo bolt on eBay. I almost went that route before deciding to try the cheap bolts and a dremel first. 6 weeks after I did that, I got hit by a car and my back hasn't let me on a bike since (the wrecked bike had an old school bolt, so I can't report on longevity.
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,896 Times
Last time I broke a Campy binder bolt, I was able to unscrew the broken part of the bolt from the 'nut' side, so I tried threading the 'bolt' part of a spare Sugino binder bolt I had, and danged if it didn't fit! So that's what I'm using on my Battaglin. All you have to do is find that part of the Campy binder bolt after it goes flying out the other side when the bold breaks!
Liked 2,948 Times
Bikes: 2020 bridge club, 2014 MARINONI sl, surly 1x1, 91 GT Tachyon
Quoted: 7 Post(s)
Liked 16 Times
Went through the campy bolt binder headache last year with my Marinoni. Check out the thread. https://www.bikeforums.net/classic-v...nder-bolt.html
Bikes: N+1
Quoted: 94 Post(s)
Liked 419 Times
https://store.marinonicycles.com/product/1180
Quoted: 836 Post(s)
Liked 1,061 Times
I'm with the Sugino and Dremel the nub off crowd. And turn around the bolt so that you're using the female end to tighten. Reason is that some bikes end up having a slightly bent clamp bolt from brazed on clamps that are slightly large for the seatpost. If you tighten the male end it flexes the bolt with each turn and weakens it.
Quoted: 4511 Post(s)
Liked 6,378 Times
Going to chime in to remind and encourage us to check the bolt itself for binding and galling, bottoming out from pinched ears/too small post.
I also always add a smidge of grease or anti-seize to the threads and also carefully use two allen keys when necessary.
Liked 11,896 Times
This was the problem I had with the binder on a Lotus I acquired. The binder bolt came to a hard stop in the process of tightening but the seatpost could still move. I took it out, measured it, and got the next smaller Sugino binder bolt. Problem solved.
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 432 Times
You can find them on the auction site (or your LBS) way cheaper than that. Unless you're hellbent to have a Campy one. Both the serrated and keyed ones are very common, the only concern is the length (and various ones are available) and type you want. I use something with Cro Moly engraved on it and it works just fine. But then again, I generally don't care much about paying crazy money just because something that has some brand slapped on it (whatever the brand). I'd be probably willing to bet that a 10 bucks one and "Campy" one are possibly coming from the same production line in some East Asian location. It's not a complicated, mechanical part where you could have a lot of difference when it comes to quality. Sure, there could be better or worse materials or finish, but in the end it's just a bolt.
Liked 11,896 Times
Likes For genejockey:
Bikes: 1985 Roberts SLX, Mercian 531, 1984 Torpado SLX,1981/82 Peugeot PSV-10, 1978 Charlie Roberts full touring, 1970 Charlie Roberts 531 road.
Quoted: 79 Post(s)
Liked 164 Times
needed a seat post bolt, so I ordered two from Richard Sachs. Unfortunately for me, they require reaming the ears with an eight millimeter drill bit.
I don’t have any machinists skill, nor do I make frames, no drill press, and I really don’t want to change the size of the hole. I wonder if Richard would take them back, as there weren’t any reaming instructions on the site descriptions.
Quoted: 1949 Post(s)
Liked 2,010 Times
Don't they come in a neat little box? And didn't Richard send a little artwork? And you must have a nicknack shelf some where! (Rat tail file).
Quoted: 79 Post(s)
Liked 164 Times
Little zip lock bags, with instructions, greasing, reaming, and good luck.
Liked 2,829 Times
Quoted: 964 Post(s)
Liked 1,451 Times
The Campy ones only break the "male" half. The solution is simple: get an east Asian replacement bolt and put it in your repair kit for when you break the Campy bolt. When you break the Campy bolt, you screw the "male" half of the east Asian replacement bolt into the "female" half of the Campy bolt, and then you have a reliable system. Make sure the threads match!!
I recently bought some unbranded French ones made of color anodized aluminum off Ebay as a gag gift for my friend, who has broken two Campy ones.
Liked 2,948 Times
Quoted: 964 Post(s)
Liked 1,451 Times
I must be lucky - the few times I've dealt with it, the fragment has just come right out, either by hand (smush your thumb against the broken surface and twist) or at worst with a small amount of prodding from a dental pick. I can see how deformation during the breakage could lead to it getting quite stuck.
Liked 2,948 Times
I do have 2 broken bolts saved that I don't think I've tried getting the bolt out, so I will give your trick a try. If it works, it'll be worth the couple bucks for a cheap asian male part. Assuming I didn't actually get around to throwing them away in my rare moods of actually throwing away broken stuff instead of saving it to fix "later".
Quoted: 964 Post(s)
Liked 1,451 Times
Looking at the Campy one I have (I guess I should sell it if I can really get $75!!) and an east Asian one, I can see why the Campy ones break. The Campy ones' threads are clearly machined - cut with a die - while the east Asian one I have is clearly rolled, meaning there are fewer stress risers and the grain of the metal is not cut through.
Likes For scarlson:
