Helix Update?
#2701
Quoted: 5 Post(s)
Hi Namor, I'm using an 11 speed e-thirteen 9-39 cassette (433% range). With a 42T chainring the chain interferes with the swing arm when running in 1st gear. With a 38T chainring the chain just skims past the swing arm in 1st but you'll still need to add some protection to avoid damage to the arm. The previous owner of my bike covered about 200 miles and I estimate I might have added another 300. Up to now I can see no durability issues whatsoever. In my opinion the durability of the frame and locking mechanisms will compete very well with those of Brompton and other premium folders. Good luck finding a used bike.
#2703
I like it enough to consider using it in place of the Cannondale Topstone gravel bike which have been using for the last 2 years to commute to work. It's not as stiff as the gravel bike of course, but I find it more comfortable on a cycle path which has been damaged by tree roots pushing up from below. The seat post flexes quite a lot and behaves in a similar way to the long travel Cane Creek Thudbusters which I have on my older folding bikes and it's this feature which provides the extra comfort. The steering has a similar level of twitchyness to my 20" wheel folders. That was a surprise, I expected it t be more stable due to the larger 24" wheels, but it just means I have to be a little bit careful when riding one handed just as I've learned to do on my 20" wheeled bikes. I'd like it better if it could accommodate a wider range of gears. I like to have a range of 500% on all my bikes. The standard Helix 10spd derailleur only has 328%. I've managed to squeeze a wider range cassette on which yields 433% but to make it work I've had to add a wear strip to the underside of the swing arm to stop the chain sawing through it when running in 1st gear. I like that there's no paint finish to get scratched or worn away. I also very much like that it doesn't have the "clown bike" appearance of my previous folders. I like that I can still fit it into the same travel case I've previously used although I do have to deflate the tyres to make it fit, which is a bit inconvenient. I don't like that the fold is less slick and takes longer than my Brompton style folders. This is mainly due to the fork and steering lock mechanisms being much slower to operate. The wheel to wheel connector can also be fiddly to engage which can be annoying at times.
#2705
Thanks! Much appreciated. I took a quick look... unlikely I can find a used one anywhere. I guess I'll have to keep looking. Cheers.
#2706
Does anyone have any comparison photos of a folded Helix against a Birdy or Brompton? I'm curious how the fold compares against these bikes or against other folders.
#2707
Likes For Jonesandrew:
#2708
Quoted: 800 Post(s)
Liked 247 Times
This picture is my Brompton compared to my Birdy Titanium, not to Helix !
I cannot recall if anybody had posted images of the Brompton side by side with the Helix when both are folded, but if it helps anybody, here are some images of the two together. NOTE: The seat of the Helix can go down MUCH further, and would be virtually at the same level as the Brompton when both bikes are in their folded configuration.
I left the seat up on the Helix because: 1) my removable bottle holder on the top tube is in the way; 2) the quick release back rack is in the "out of the way" position; and 3) I was too lazy to pop the seat down and then try to remember my ride height later! So, in the images, don't let the seat height trick you into thinking the Helix is fantastically larger than the Brompton: larger by a bit, yes; by that much? - no.
And yes, the garage door could use a new paint job....
Side by side
Superimposed (sort of!)
Width from the top (ignore the handle bag and rack attached to the Helix).
Side by side
#2709
Likes For Jipe:
#2711
Thanks for the quick responses and the photos. I already have a Birdy, this gives me a basis for comparison. I was considering the Pacific Reach which isn't a true folder but has some good qualities but the price has jumped considerably since Covid. I was going to see if I could pick one up traveling through Asia but am moving away from that idea. The Helix might be a possible goal but the price is right up there with the Reach. Except with it's location in Canada and some deliveries happening might be more available than a Reach which has no distributor in the US. I'll track it's development progress and if production picks up, and they clear their back log of initial backers, I might get one. Unless something better comes along in that time.
I looked at the new Tern BYD since I already have two other Terns but that price point at $3K was ridiculous.
#2712
Anyone have photos of fully folded Helix bikes in the trunk of a Tesla Model Y? Preferably more than one and without folding the back seats. I cannot stand my folded Tern bikes in the trunk of a model Y and have to lay them flat. The slope of the hatch doesn't provide much height even if the trunk overall is large.
#2713
Bikes: Bike Friday Tikit, 2005; Helix 2018ish
Sorry not to be able to respond to anyone -- it appears my posts are being deleted. not sure why.
#2714
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,595 Times
#2715
Thanks for letting me know, Cb400bill.
For the record, I was offering to show pictures of my bike, not to sell. Then somebody else offered to buy. Theirs was the post that should have been blocked.
(This was my first ever post on a public forum anywhere. Not exactly a warm welcome to bikeforums.)
#2716
Palmer
Quoted: 1668 Post(s)
Liked 1,820 Times
#2718
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
To start with, in this photo the Brompton's wheels are well larger, in my count as much as 45% . They call it smoke and mirrors.
#2719
Trolley mode?
Im thinking of getting a helix to replace my brompton, I do love the brompton but I just cannot get a good upright position without compromising the foof.
one thing I do like a lot about the brompton is trolly mode, where you can push the bike by the handlebars, kind of like a stroller.
I use this a lot when travelling with my bag attached to the front carrier block.
if you leave the handlebars up on the helix, is it useable as a stroller like this as well?
#2720
Until Helix releases its bike specific racks (which I understand the prototypes work quite well) if you want all out versatility, the Brompton is still king. What is it about the Brompton that you can't get comfortable on? I'm going to play dumb and ask what is "foof"?
#2721
Isn't the Helix restricted in how high a bar you can add to it, too? Long ago I did some comparison shopping and I'm pretty sure a Helix has a lower bar height than an H model Brompton.
#2722
I have both, and while I haven't tried the Helix in this way, I'm going to say... probably not. You could sort of push it around in that configuration, but it would be awkward and cumbersome. In fact, I'm not sure you can because the Helix actually rolls on its wheels, so you have to push it along from the saddle position since the wheels can only roll one way. The Brompton sits on the little trolly (EZ) wheels so in this mode, it's independent of the actual bike wheels.
If it’s not too much trouble, could you try to push it around like this and see if it works? If you could get it on video that would be great!
As for the brompton, I simply cannot get the handlebar high enough for my ideal position. And it’s a bit annoying that I have to actively avoid cobbles haha. I’m cycling in Asia now and if I’m caught off guard by a pothole it always gives me a whiplash every time with the small wheels haha.
#2723
Quoted: 800 Post(s)
Liked 247 Times
About the bad road riding, cobbles and potholes, I doubt that the Helix will be much better than the Brompton.
The wheels are bigger but not that much and like on the Brompton these have relatively narrow, high pressure tires (that's a major drawback of Helix: tire width is limited to 40mm, while most ETRTO507 tires are wider that that, the choice of tires for Helix is very limited).
The Helix has no suspension at all and seems to have a very stiff frame with a straight, thick single arm fork that must be very rigid.
From what you say, I think a Birdy with a comfort stem (the Birdy stem is adjustable in height) and a rear rack with easy wheels will do the job much better for you than Helix since it has an excellent suspension (especially the front one) and wide 50mm tires. The Birdy is excellent on cobbles and trails.
#2724
#2725
Quoted: 800 Post(s)
Liked 247 Times
The Birdy 3 folds smaller than its predecessors, closer to the Brompton and smaller than the Helix. Its frame accepts ETRTO406 wheels without folded size increase if you accept to limit the tire width to about 35mm (Pacific Cycles Birdy R11SP for example).
