shimano 105 7 speed (vintage groupset)
hello all, i own a peugeot with 105 7 speed vintage groupset and I want to change a chain. On it its already shimano hg, (shimano, HG, narrow), thats whats written on it... Im looking for recommendations since i bought wrong one apparently (i bought cn-hg53)
thank you all
thank you all
Edumacator
Quoted: 2384 Post(s)
Liked 2,930 Times
As more cassettes were added, it necessitated narrowing the spacing, and therefore the chain. I think up until 8 speed, they are pretty compatibile.
KMC offers awesome chains for cheaper prices. https://www.kmcchain.us/7-Speed-Under-Chains_c_84.html is 7 speed.
I am pretty sure you can use an 8 speed chain. https://www.kmcchain.us/8-Speed-Chains_c_28.html
The chain you got is narrower and designed for 9, maybe 10 speed cassettes/drive train.
Quoted: 4719 Post(s)
Liked 3,034 Times
Welcome to the forums. You have purchased a 9 speed chain but it should work properly with your 7 speed sprockets. There was very little different in the thickness of the spocket itself itself between 7 and 9 speeds, with 9 speed sprockets being only 0.07mm thinner. The one caveat in all this is the amount of wear on the sprockets. If some of the sprockets are highly worn, the new chain may not mesh properly with them.
Likes For T-Mar:
Freewheel Medic
Quoted: 1447 Post(s)
Liked 2,177 Times
Do you know whether it is running a freewheel or a cassette? 7 speed Shimano 105 came in both versions, IIRC.
Bob
Bob
Quoted: 359 Post(s)
Liked 581 Times
I have a new chain (Shimano) for that, part of an NOS 1055 take-off.
I think I have a new KMC 7/8 speed in a box here, too.
I second those who think a 9-sp will work, and only would add to keep the lettering facing outward.
I'm not sure that makes a difference, but it does when you get up in the 9/10/11 range on Shimano stuff w/Shimano chains.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
An HG53 will probably be fine in practice. It's a 9spd chain, which is only marginally narrower than a 7/8spd.
I always use Shimano CN HG 71 with my 7 speed 1055, it's a better quality than CN HG 40. I think that 9 speed chain might get wedged in between chainrings being narrower, better get correct one.
