Snap ring pliers as master link pliers
Bikes: Trek Marlin
Quoted: 13 Post(s)
Personally I hate to purchase single function tools, so I was wondering if the the Channellock 926 would be able to open a master link/quicklink. Can I use a pair of snap ring pliers as a masterlink plier?
Quoted: 836 Post(s)
Liked 1,058 Times
Yes, most will work, including the Channellock but some of the cheaper ones made of swiss cheese may bend the tips. Try yours and see. You could also cut up an old allen wrench of the correct size to use for tips for chain removal rather than risk feckering up the nice Channellock tips.
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
I ground/filed a couple grooves in a pair of mig pliers I found in the road
https://www.airgas.com/product/Weldi...2cd&fo_s=cstmc
Likes For dedhed:
Quoted: 2026 Post(s)
Liked 1,095 Times
I did the same thing with a pair of cheap needle nose pliers I found on the road while riding. I filed the noses thin enough to fit into the links and filed a pair of matching grooves across the noses. So far they have worked perfectly at no cost.
Likes For HillRider:
I have to say, I thought masterlink pliers were a silly single use tool taking up space. But after getting a proper pair I find they're quite invaluable. So much better than any tool hack I've used earlier.
It's not the opening that's the handy part. It's the closing. Most masterlinks tend to be far more tricky to close than open.
Likes For elcruxio:
SE Wis
Liked 3,386 Times
Quoted: 504 Post(s)
Liked 637 Times
For those who grind their own tools, I have to wonder if the cost of the grinder is ever paid back compared to actually purchasing the special tools. There aren't that many special bicycle tools you can make with a grinder. Maybe it's just sour grapes because I don't own a grinder.
Quoted: 955 Post(s)
Liked 1,619 Times
I use a simple wire type tool for my Quick Links. If the link is really stuck then it is most likely damaged so I go to my Chain Breaker for removal. Also note that even though not necessary I recently stopped reusing my Quick Links when I had one come apart in my hands after removal.
https://www.bikeforums.net/22778564-post14.html
Liked 1,095 Times
Likes For blacknbluebikes:
Quoted: 2337 Post(s)
Liked 2,809 Times
the other cool thing for putting chains together is a simple bit of long u shaped wire to hold the change together when installing the link
Likes For squirtdad:
Liked 1,095 Times
Yep, another zero cost tool. I cut a 6" long piece of a wire coat hanger (remember those?), bent it into a shallow U-shape and bent a hook at each end. Insert the end hooks through the chain ends leaving enough slack to overlap the two end links, insert the master link and snap it together. The tool takes the rear derailleur's tension off the chain while you are joining it.
SE Wis
Liked 3,386 Times
SE Wis
Liked 3,386 Times
Likes For dedhed:
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1244 Post(s)
Liked 1,272 Times
...and yet it has never even occurred to me that one could use masterlink pliers to close the link! Nor that one would even need a tool to do so. I just slip the two halves together by hand, very gently backpedal so that the masterlink is on top between cassette and chainring, and then give a good solid stomp down to the forward pedal. Boom, locked link.
Likes For Bob Ross:
elcraft
I have had a grinder for years, bought used from a yard sale for $25. So, not a big expense and used for numerous other jobs over the time I've had it. I certainly wouldn't buy one just to make one relatively cheap tool. BTW, I saw it while riding my bike past the yard sale on my way home one day.
Quoted: 567 Post(s)
Liked 562 Times
Probably sounds silly but building up a frame (not simple maintenance) is a zen like experience for me where I relax and love the rhythm of the tasks until I have to take the bike off the stand and press the pedal to set the quick link or use one of a drawer full of snap ring pliers, heavy and light with 90 degree heads on them which I used for years. Then I got these and all is well: https://www.amazon.com/dp/B07D6NV4TL/?tag=dwym-20
Likes For easyupbug:
Quoted: 370 Post(s)
Liked 527 Times
Hard to believe that people with the bucks to buy a bike won't pop $8 for a proper tool. I bought two on fleabay, gave one to my brother and didn't have to miss a single meal.
YMMV of course
YMMV of course
Quoted: 2597 Post(s)
Liked 1,923 Times
Equally hard to believe we used quick links for a couple decades before we learned we needed a special tool to disconnect them. How ever did we unhook the links before??
Oh, yeah, cocked a normal pair of pliers sideways and squeezed.
SE Wis
Liked 3,386 Times
Quoted: 6934 Post(s)
Liked 10,940 Times
Liked 1,095 Times
Many of the early master links like Craig's and most Connex came apart with moderate hand pressure and didn't need tools of any kind. That's not true anymore.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
Curious. I have a set to open the quick link, but never use them to close it. As dedhed says, you just put pressure on the pedal and they snap right into place.
Often I'm already fabricating something and the grinder is a fast way to prep an edge, deburr something, etc. Vs. using a file it saves me loads of time = money. The ability to modify a tool is just a bonus.
