Installing cantilever brakes
Quoted: 5 Post(s)
So i have recently aquired a really cheap bike, the only downside being that the only way of braking is by paddling backwards and even then it sometimes takes upwards of a full rotation for it to work meaning it does not allow for a quick stop if needed.
However i do still have a pair of cantilever brakes lying around. The problem with this is that the bike in question just has straight forks and therefore has no easy way of connecting the brakes to the frame. Is it still possible to install the brakes by directly drilling them straight into the frontfork or does this simply mean i shouldnt install them to this particular bike?
And are there any other brake types i can install on a frame without any mounts for them?
Likes For HelpSingularity:
Quoted: 581 Post(s)
Liked 921 Times
You should not put the cantilever brakes on this bike - cantilever brakes require mounts built into the fork. It is possible to
It may be possible to mount a caliper brake on the front - is there a hole in the fork above the front wheel? If so, you can probably get a brake caliper and mount that and a lever on the handlebars.
Here's an example:
Supercycle Short Alloy Bike Brake Caliper w/Brake Pads, 35-mm, 51-mm | Canadian Tire
You need to measure the distance from the mounting hole in the fork to the braking surface of the rim and find brake calipers with 'reach' that will work with this dimension. The ones I linked have reach between 31mm and 51mm.
The only other snag I can think of is that the rim must have a flat sidewall that can be used as a braking surface.
Here's an example:
Likes For ClydeClydeson:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Likes For maddog34:
Quoted: 5 Post(s)
Quoted: 5 Post(s)
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Is there a bike co-op near you? They'll show you how to rebuild the coaster brake so it works properly.
Likes For andrewclaus:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Agree that doing a proper job of installing cantilevers on a bike not designed to use cantilevers would not be cost-effective. Why not simply install a caliper rim brake or two? The only contraindication would be if your rims lack a proper brake track.
N.B. if you only use one caliper, put it on the front.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,468 Times
I do not understand why a bike lock requires one to drill holes in a bike frame. Extra holes in the frame adversely affect its structural integrity.
Likes For SoSmellyAir:
Quoted: 1438 Post(s)
Liked 1,092 Times
https://www.sheldonbrown.com/coaster....html#reaction
Liked 739 Times
I wonder whether the reaction arm for your coaster brake has come loose from its strap. If so, attaching it may restore braking function.
MilanS... take the bike to a Co-Op, throw your pride in the trash can, and beg for help before you get hurt because the stupid Coaster brake doesn't work... signed: Ayco Opowner.
PS... i've been known give away decent bikes when people tore down a few bikes for me, or sorted out parts for a day....... wink, wink.
And no, my shop is nowhere near a commuter train line.
Quoted: 4204 Post(s)
Liked 3,862 Times
If the reaction arm was not attached to the stay it can rotate with braking action and seriously affect the bearing adjustment. The arm is connected to the LH bearing cone. The unwanted arm rotation will loosen the bearing adjustment and thus the crank will need to be rotated backwards further than if the bearing adjustment was good.
AndrewRStewart
AndrewRStewart
Liked 3,862 Times
So, all fork crowns with a brake bolt hole are doomed? I have to say that I can't remember ever seeing a fork failure due to a brake caliper mounting hole. (I have seen a number of other reasons why a fork goes bad though). Andy
AndrewRStewart
AndrewRStewart
Liked 1,468 Times
OP mentioned "the lock [OP] had to drill holes for", and my comment about "extra holes" obviously refer to the holes OP drilled for the lock, or at most holes which were not intended by the manufacturer. Hopefully I can venture that most, if not all, brake bolt holes in fork crowns were intended or at least accounted for by the manufacturer. But the OP's bike is doomed if he keeps drilling holes while asking for confirmation on BF.
Liked 3,862 Times
Huh? When did I mention a fork crown or brake bolt holes therein?
But to the holes for a lock- many thousands of bikes (likely most in Europe) have had a rear wheel "horseshoe" lock that bolts to the seat stays. That we don't hear of those frames failing due to these and the numbers that have had these locks for how many decades I will venture that these lock mounting holes are OK. I am not a fan of these locks for high security use, one can just carry the bike away and work on the lock later. Andy
AndrewRStewart
AndrewRStewart
Liked 1,468 Times
How about drilling some extra holes for weight reduction?
