Raising stem?
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 124 Post(s)
Liked 51 Times
Raising stem?
How easy is it to raise the stem a bit? I have some shoulder issues and have been thinking about raising mine to start before I possibly look at different handlebars. My bike is a 2014 Fuji Traverse:
https://archive.fujibikes.com/2014/Fuji/traverse-132
Thanks for any input.
Quoted: 4204 Post(s)
Liked 3,862 Times
First a thank you for including a link in your post. Makes our job much quicker in helping you.
The bike shows to use a threadless stem. A stem that slides over the top end of the fork's steerer tube. The top cap with it's central bolt is used to pull the stem down and achieve the headset bearing adjustment/preload. The two pinch bolts on the stem's back side will then be tightened to clamp the stem in this position.
The stem needs to fit over the steerer far enough to both provide the pressure against the spacers, and thus the bearings, AND have the top pinch bolt fully overlapping the steerer's end. If your stem is already at the top of the steerer, all the spacers are below the stem, then it is as far up as it is safe and designed to be. This is what the linked to image is BTW.
If this is the same as your bike then the stem and/or the bars will be needed to replaced with ones that have the hand grips higher. A stem with a steeper angle or a bar with a taller curve (often called "riser bars") both do this. There are steerer extenders available too but like a stem with an adjustable hinged angle the added joints can make for less secure assembles. Also a bar with a greater swept back grip area can reduce the reach forwards but does so at a change to the angle that the hands grab the grips with. Do know that the control cables/housings might need to be made longer if the higher/further from the ft brake and/or frame housing stops end up too far from the levers/controls. Also the headset will need to be readjusted if the stem or an extender is installed.
Not usually thought about till after the first longer ride is that the seat and one's bottom will interface somewhat differently as the upper body is more upright. Often a wider seat is found to be wanted. Also as the upper body angles less WRT the legs the muscle use changes. The angle between the torso and the leg lessens the more the body becomes upright. For some this "fit" change is no big deal. The more athletic the rider is the more they generally notice this and are bothered by it. The solution is to move the seat rearwards (which then increases the reach to the bars). Andy
AndrewRStewart
AndrewRStewart
Quoted: 124 Post(s)
Liked 51 Times
Wow, thanks Andy!
That is some excellent info. It sounds like I need to bring it up with my shop with the understanding of all the points you posted. I'm taking my bike in for some changes/upgrades and I'll see if they can do it. I never thought about possibly needing longer cables. Should I just be eyeballing new bars instead over raising the stem? Also, did you link an image? I don't see it if you did.
Thanks again!
Edit: What if I get a stem with a steeper angle like a 30 degree over my 12 degree?
Thanks again!
Quoted: 6193 Post(s)
Liked 4,809 Times
If there aren't several spacers on top of your stem, then unlikely you can raise the current stem. You'll have to get a stem with more angle or high rise bars. Though if your stem was put on with a negative angle, you can just flip it over and get more height.
As said above, the more upright you sit, the more wider the saddle you might need. Or at least you might need sit further back on the current saddle. And that might cause you to get in a struggle with reach and sliding forward on the saddle. What we call our sit bones aren't just a bony point we sit on. They are more like rails that are close together at the front and widen toward the back. Curved too sort of like rocking chair runners.
Reach issues might be part of your shoulder problem. Sitting up might fix them, but also getting just reach corrected properly for your current position might help. Stem length, saddle setback or even no setback.
Shoulder issues might also be your bar width. But I did just say might. Too wide a bar puts your arms further out and braces your body to be more rigid. That sometimes means your shoulders and arms are taking the brunt of the swaying forces put on you by cycling. A narrower bar might let your body share some of that force.
You might can test that out by going for a ride and keep your hands inside the grips.
Likes For Iride01:
Quoted: 124 Post(s)
Liked 51 Times
Thank you Iride!
I think my bars are a good width and they already have a 30mm rise. Instead of molesting my current stem and trying to raise it, maybe I should just look for a 30 degree stem angle and move my seat forward as much as I can? Hoping my Brooks C17 can handle my butt with any changes. If not, I'll change that later.
Quoted: 514 Post(s)
Liked 448 Times
Before going out an purchasing riser handlebars and stem, try sliding your saddle back a centimeter or so. This moves your center of gravity away from the arms and shoulders and toward your hips and feet, which is where nature intended it.
Likes For oldbobcat:
Quoted: 124 Post(s)
Liked 51 Times
Thanks again for the excellent advice everyone.
I'll try tinkering with the seat a bit and talk to my shop about some options too.
Likes For MrWasabi:
Quoted: 1062 Post(s)
Liked 665 Times
I installed a threadless stem extender on my bike when I was dealing with a temporary "age related" injury. It was easy to install and did the job. Not to discount the other advice given here. When I got over my injury, I put my bike back to the way it was. The extender sits in the bin waiting for next time.
Likes For Gresp15C:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
IMO, your way too straight HB is THE problem, as shown in that pic. This gives you NO back/ torso adjustment. Very stiff and uncomfortable.
So get a bar with both up sweep and rear sweep, like 30 to 40 degrees. Mine have more, about 70d, but also the necessary longer TT. I never have a sore back now, including my 8,100 miles on 2 tours with heavyweight.
So with this, likely need your seat moved back as already said.
My back is normally bent down about 30d. Only real way to have a straight back is riding with no or one hand. I used to do that some on the highways.
Likes For GamblerGORD53:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I'd start with a high angle stem. 35 or 40 degrees, 110mm. The upwards angle also shortens the reach. Less than $30.
Likes For tyrion:
Quoted: 124 Post(s)
Liked 51 Times
How are the adjustable stems I see out there? I'm hoping I can get the bars in a good position without having to replace my cables. I'll start with playing around with my seat but it looks like a new stem (or extender) and possibly handlebars are the answer. I have been doing the one handed riding at times to give my shoulder a break. What are some good bars with more upsweep/backsweep?
I had the same issue with my Giant Escape 2, so I ended up installing an extended (and slightly adjustable) stem. It made all the difference to me.
Likes For rut3556:
Quoted: 124 Post(s)
Liked 51 Times
How about a shorter steeper type stem like this in 60mm/30 degree?
https://us.ritcheylogic.com/us_en/bi...-axis-30d-stem
Liked 2,011 Times
Likes For tyrion:
Quoted: 124 Post(s)
Liked 51 Times
Yeah, I think I'm going to end up with some extra parts. I think I'm going to skip any extenders or adjustable stems. Right now I'm looking at these bars (SQlabs 302):
https://sqlab-usa.com/products/302-s...ar-version-2-0
Or these (SQlabs 30X, 12 or 16 degree backsweep/45mm rise):
https://sqlab-usa.com/collections/ha...-mtb-handlebar
And this stem (SQlabs 802/70mm):
https://sqlab-usa.com/collections/st...31792993599559
I haven't pulled the trigger yet but with adjusting my seat a bit, it seems going with a new stem and bars are my best route. I'm just hoping my cable/brake lines will be OK.
Edit: The 70mm stem I linked is out of stock but they do have an 80mm. Wondering if that 10mm will matter? On a side note, I have a Quad Lock phone mount and the 80 might be better for that although my shoulder pain is more important over my phone mount obviously.
Liked 321 Times
I don't see enough difference with that bar to justify it. I suppose the 31.6 might limit choices.
Mine are old 1" steel.
Quoted: 124 Post(s)
Liked 51 Times
One of the reasons I have shoulder pain is from my younger motocross days. I plan on doing some more light off pavement/hardpack trail riding with my bike and I don't think I would like bars with much more backsweep than the 302 Sports I have linked and they're pushing it IMO. My current bars have a 9 degree backsweep and the 302 Sports are at 16 degree. They do have a 302 Comfort with 35 degrees backsweep but again I don't think I'd like that much backsweep for any offroading.
Liked 3,862 Times
I have learned a lot about fit in the last ten years working in a shop that has a really good fitter. 11 years ago I would not have thought this was a lacking in my approach to bike set up (and my hobby frame building). Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 124 Post(s)
Liked 51 Times
When I get (and can find the proper size) a new bike I'll definitely be getting fitted and I don't mind laying out the dough for someone who know's what they're doing. The whole moving the seat back didn't make sense to me but I understand now how it may help. As for fitting on the stem, since I'm going with a steeper angle (30-35 degree), should I be looking at a longer or at least the same length stem and not shorter as won't a longer stem actually raise my arms more relative to how much further out I'd be going?
Quoted: 124 Post(s)
Liked 51 Times
I went ahead and picked up the SQlabs 802 35 degree stem for a good deal to try that. I got the 100mm version:
https://sqlab-usa.com/collections/st...tem-3-18-clamp
I'm assuming a longer stem at that angle will raise the bars higher but only minimally further forward? Is this correct? I'll be adjusting the seat too and looking at some other riser bars with some more backsweep if my stem/seat adjustment doesn't help a bit.
Thanks again for the excellent advice. This is a great forum.
