Has anyone built a gravel bike using a Sturmey Archer S3X 3 speed hub?
Quoted: 439 Post(s)
Liked 999 Times
I'm interested in running a Sturmey Archer S3X 3 speed fixed hub wheel set, but from what I read I could run a freewheel as opposed to using it with a fixed cog. Has anyone tried this on a gravel bike configuration? Unfortunately the hub comes attached to 700 x 18mm rims. Could I safely run 700 x 35-38C tires on that rim width though? Any input or opinions would be welcomed. Thanks!
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
I have not tried any such thing. what's the OLD dimension on that hub? if it's 120mm, which could limit the frames/ bikes on which you can use it.
Likes For jonathanf2:
I replaced the rear wheel on my single speed bike with a wheel with that hub. Bike was 120mm rear spacing and it bolted right in. I run 32mm Compass tires (maximum I can fit in frame). My bike has rim brakes.
Tire/wheel charts appear that up to a 38mm will work on 18" rim if your frame will take it.
I like the hub. This bike is used mostly for urban city paths, I have ridden on hard packed dirt but not gravel.
Likes For colosteve:
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I had one when they first came out. Really really didn't like it, heavy, ratios were too close for the amount of internal friction. You can thread a bmx freewheel onto the body fine, although it just adds more weight. If you're hooked on the IGH idea, I'd just lace up an old Sturmey AW. If it's adjusted correctly, it'll run forever.
I think so, but it's converted into a bombproof low maintainence commuter with full mudguards and 700cx35 Vittoria Voyager Hypers. Can gravel it up by adding some knobblies, removing the mudguards and adding a larger sprocket (current 42t x 18t).
I went full gas on the conversion - 70mm drum brakes front and rear, compressionless brake housing, vintage Shimano RSX STIs (the double left shifter is able to shift the three speeds by using the trim for the imaginary big chainring). A triple shifter without trim would be better, but they're very hard to find. Next steps are some nice tubeless amber wall tyres with some gravel tread.
I tried embedding some photos, but I need to have 10 or more posts to do that, or to paste a link.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), Yess World Cup race BMX, Redline Proline Pro24 race BMX Cruiser
Quoted: 343 Post(s)
Liked 181 Times
Sort of, but not quite - I have an 88 Bianchi Strada running a 3sp Sturmey, but not the S3X. I run a downtube shifter, considered bar-end, but like the no cable housing thing. Running 32mm / 30mm tires on it now. I don't exactly do 'gravel', but I do ride on light trails and commute with it. Basically anything my kids can do on their Hotrock Street bikes.
The yellow thing kind of happened by accident - next tape job is likely yellow as well.
I like the Sturmey lever
Likes For Viich:
It's the little things
Bikes: Too many, yet not enough
Quoted: 278 Post(s)
Liked 325 Times
Just found this thread, but never post in this forum. Sorry for the late addition.
I have a bike with an S3X hub, and it's not a gravel type frame. I have done some easy gravel with, and varied off road riding with it. Gearing as shown is approx 70, 55, and 44 gear inches with the S3X ratios as they are. Have had great experience with the hub. It is heavy, but with the variety of gear inches it doesn't impact my average in speed, it actually helps. I like it a lot, but it has it's drawbacks.
With some wider tires/different frame and proper set up, if fixed off road is your thing, I think the hub can handle it as long as you are not using the hub/back pedaling for modulating speed.
Likes For Senrab62:
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x9,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 249 Post(s)
Liked 221 Times
Have a look at Dahon Speed pro and speed pro TT. They run a 3 speed hub using Tiagra 3 speed shifter and a 9 speed tiagra rear mech. It works well. I considered doing to same on one of my folders but I thought the in the event of puncture, it would be a little more fiddley to fix at the road side (disconnecting the hub pull chain, have the spanner to take the wheel of etc.).
