Stripping paint from an aluminum frame using a heat gun
Hi! I have an aluminum frame which I want to strip the paint off of. I won't be repainting the bike, so I want to preserve the bare aluminum finish and not use any abrasives.
I was wondering if it's a good idea to use a heat gun to strip the paint off. If I use the heat gun on its hottest setting, would it damage the frame? The frame is aluminum. Should I grab a can of paint stripper instead?
I've already tried using the heat gun on its lowest setting to strip some of the paint off. It softens the paint just enough so that you scrape it off with a plastic razor blade, but this doesn't always work on all sections of the frame. I may have to crank the heat up
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 189 Times
Use paint stripper. Also - use abrasives to polish, finish it off with automotive wheel polish.
Likes For Viich:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
If it's a welded frame, I wouldn't worry about the heat. An adhesive-bonded frame could be a concern.
Bikes: nothing to brag about
Quoted: 130 Post(s)
Liked 206 Times
Sounds like a bad idea to me. Manufacturers heat the frames to reduce the stress of uneven heating in assembly, and the temps they use aren't as high as your gun, so the gun is going to undo what they did, building in stresses that don't belong there that you can't remove:
https://www.pinkbike.com/news/To-the...um-Frames.html
Quoted: 523 Post(s)
Liked 228 Times
It's far safer for the frame for you to use a chemical stripper. It will not affect metal, just the paint. You can clean it off with a soft cloth. Some types can be rinsed off with water but others might require a final cleaning with paint thinner. Best to do it out-of-doors and wearing protective gloves. Read and follow the instructions on the can and you will be fine.
Quoted: 1188 Post(s)
Liked 1,154 Times
Aircraft grade paint stripper, it's made to strip aluminium....
Likes For Trevtassie:
Hack
Quoted: 347 Post(s)
Liked 189 Times
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
I would say after the paint is off an aluminum frame, don't do abrasives - if you don't want it polished, just bare, then follow the advice on this Black Mountain Cycles page here as recommended by Charlie Cunningham:
https://blackmtncycles.com/care-for-...luminum-frame/
It works, as even if you don't have any corrosion to worry about, it will prevent it. The Fluid Film smells like a sheep, but it's worth it!
Yeah, I know, mismatched wheels...
Likes For Jeco:
Many thanks for the advice, everyone!
I already stripped the paint off using some generic paint stripper. Compared to using the heat gun, it was a messier job but it worked well and faster too.
I actually bought the heat gun for the sole purpose of stripping the paint. Now, I have to find a use of this hahaha. Remind me not to impulse buy tools
Hack
Quoted: 347 Post(s)
Liked 189 Times
Do we get to see pictures?
Quoted: 4227 Post(s)
Liked 2,488 Times
Heat guns are not designed to be used to strip paint, you're using a wrong tool for the job...Use a chemical stripper or have some shop sand blast it for you.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1236 Post(s)
Liked 319 Times
5 years ago I was trying to clean up my mum's old frying pans. I put a bunch of laundry detergent in the sink and really hot water.
The paint disappeared on the alu pans. LOL. Didn't do a thing for the baked grease.
Later I painted some DIY CF stuff, then changed my mind. Did the same method with soap. Took longer, but it worked out.
Long before that, I had some old cedar fence posts to de-paint. I used a heat gun just fine. There are made for that, actually. Won't work with metal probably.
I have used them to heat up the garage some in the winter too. LOL. And heated up the windshield a few times on super cold mornings.
Liked 1,154 Times
