What happens if I don't change the oil in my IGH?
What happens if I don't change the oil in my Alfine 11 Internal Gear Hub? Do I risk damaging it or will it just not shift gear?
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
I think it will depend on how much you ride it. How much is it being used? If you aren't riding it much, then you can probably get away with extending past the factory-recommended oil change intervals. If you are really putting it through a lot of use, you may need to change the oil sooner rather than later. At any rate, and in any situation, its always better to err on the side of caution and just change the oil. One of our fine fellow forum members here has a great video on changing the oil.
Senior member
Quoted: 942 Post(s)
Liked 656 Times
https://www.youtube.com/watch?v=lFOMD2q5-o4
I made the above video, however many years ago that was, in response to all the discussion happening at the time around Shimano's recommendation to convert the Nexus and Alfine hubs to oil lubrication, using, of course, Shimano's own (high priced) specially formulated oil.
Lots of discussion was happening on alternatives, so being in a position to do so, I decided to run some long term tests.
I did place annotations of the videos that I was not endorsing ATF as an alternative, but unfortunately, those annotations were added after uploading to Youtube rather than during the video editing, and they have since disappeared.
Likes For Dan Burkhart:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Bikes: lots
Liked 2,932 Times
You have to lube single speed freewheels too. They're not 'internal' like an Internally geared hub though, totally different.
Likes For cxwrench:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
There is good material, including pictures, from Aaron's Bicycle Repair, a.k.a. Rat City Cycles here. They're located in Seattle and therefore know about rainy environments. Read up on it and click links to some of the other pages at their site. They have a lot of advice and technical info on Shimano Nexus and Alfine hubs.
Apparently, riding your IGH a lot in the rain is what drives a need for frequent service. If you ride in a dry environment, you should be okay going longer intervals without service.
I believe I've also read from Sheldon Brown that bringing an IGH inside from the cold is not such a good practice. When the hub gets cold outside and then comes in and quickly warms up, moisture can condense inside it. If there's a secure, dry place to leave it outside in the cold, that might be better for it in the long term.
2-Wheeled Fool
Liked 677 Times
Either that, or you'll see wear happen only in that gear position. Dan is the real expert here, so maybe he'll chime in again. Its pretty simple to change the oil. I would not hesitate to use ATF either. I'm a huge fan of ATF for several different bike-related tasks.
Quoted: 980 Post(s)
Liked 580 Times
I have an Alfine 11-speed hub with over 9,000 miles on it. I've changed the oil per factory instructions roughly ever 800-1,000 miles. The whole procedure takes about 30 minutes if you take your time. The wheel doesn't even have to come off the bike.
Every time I change the oil, I remove slightly less oil than I placed at the previous change. This means that the hub loses oil very slowly over time. Over a distance of 1,000 miles the oil loss doesn't amount to much; at most a few milliliters. But eventually, there won't be enough oil to protect the internals from wear. There are *vastly* more moving parts inside a hub like this than there are inside a single-speed hub, or a hub with a cassette. Dan had made a really nice video
EDIT: I've been using Royal Purple MaxGear 75w-140 instead of the "official" Shimano oil because its viscosity and other properties resemble the Shimano oil (except for color: the Shimano oil is green). I'm sure ATF would work well, but it's a lot thinner and I would not be surprised if it leaked out a little more.
2-Wheeled Fool
Liked 677 Times
Quoted: 980 Post(s)
Liked 580 Times
If you've ever disassembled any IGH, you'd soon come to realize that there may be less than a couple cubic centimeters-worth of air inside after the oil has been added, and even less than that inside a classic Sturmey-Archer 3-speed hub. Think about it for a second - that air has to be laden with moisture in order for it to make any condensation, and there is so little air, I doubt it would make much difference.
Likes For sweeks:
Quoted: 1062 Post(s)
Liked 665 Times
Whether single or multi speed, a freewheel contains moving parts, including bearings and the ratchet mechanism which is usually pawls and springs. Any time you have moving metal parts, they need to be lubricated. How often they need to be re-lubricated depends on a lot of things, including how well sealed they are, and sources of contamination ranging from dust to road salt. It's pretty rare to re-lube a freewheel, partly because the moving parts are only moving when you're coasting. And the time honored lubrication technique is to let some light oil drip through the hub from one side to the other. I've done that on an old freewheel on a friend's "campus bike" that she gave to my daughter.
In an IGH, any number of the internal parts, and possibly all of them depending on the design, are in motion all the time. They are usually lubricated by being bathed in light oil that collects in a sump in the hubshell. Some newer hubs have used light grease instead, don't know the pro's and con's. Early hubs like the Sturmey Archers were not sealed, and so a certain amount of oil constantly leaked out past the bearings, which is why those hubs are always coated by a patina of black greasy dust and the chrome underneath pristine. I've found that some of that oil also ends up on my chain. The oil has to be replaced, but also, changing it periodically is a chance to wash away metal particles and other filth that have collected over time.
Whatever oil drips out would certainly "lube" the belt on a belt drive bike, and so hopefully the rubber is compatible with oil. (This is typical for any rubber used for automotive purposes). But it would be worth keeping an eye on, to make sure the belt isn't getting filthy.
Liked 665 Times
An additional note, one of my 3-speed hubs is a Sturmey AW that was formerly on my mom's bike. Its oil cap had fallen off, and the hub had been ridden dry for some unknown time period, probably years. All I had to do was scrub the small amount of powdered rust off the internal parts, re-assemble, and have been riding that hub without issue for several years. Those English engineers knew how to design things that could be made with relatively imprecise tolerances but extreme reliability.
Likes For Gresp15C:
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
You would take off the seals and add fresh grease or something like Phil's Tenacious Oil in the bearings of the freewheel. If you are running a belt you don't need to lube it though you can use silicon spray however you would lube a chain. If you are running fixed you would just need hub maintenance or replacement of bearings as needed and same stuff with chain or belt.
Basically anytime you have metal on metal contact you want something keeping it lubricated or protected in some way from rust and corrosion and to keep everything moving properly if needed (as in the case of your hub). It is always better to err on the side of a little extra maintenance then none at all. Alfine hubs are not the most expensive thing in the world but I wouldn't want to have to replace it because I didn't change oil once and while. Just like you need food to survive a thing with moving parts needs lubrication.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,203 Times
I’m not going to say much about changing oil in an IGH other than to say that lubricants in a bicycle application will probably last until the sun goes cold because the stresses put on them are so small. You need to change oil in internal combustion engines because the lubricant is subjected to extreme conditions. Bicycles don’t experience that.
This, however, chaps my hide. It’s just straight up wrong. If you want to test it, put a cup of hot tea next to a glass of iced tea and see which one causes condensation. You might have some condensation if you are taking a warm bike into the cold but even that is a stretch. Warm air from a heated house doesn’t have much water in it during the winter...cold air can’t carry much water and heating it doesn’t add water to it. Taking a warm bike out into the cold does lower the amount of water that the air can carry but that just brings it back down to the level of the water in the cold air. No condensation should occur.
Even if it could possibly happen, the amount of moisture is tiny and the volume of air it could condense from is also tiny. At 20°C (78°F), fully saturated air has 0.0017g of water in every cubic meter. That almost 2 milligrams of water in a 1 m cube. There are a million mL in a cubic meter. There are about 100 mL in a IGH hub. If the hub shell were completely empty, that a grand total of 2 one millionth of a gram. It’s not even a “drop” of water. It’s barely a “hint” of water.*
To put it another way, to get to a gram of water, you’d have to take the bike in and out of the house 500,000 times.
*I usually give the US equivalents for this kind of discussion but we have no easily used way of measuring that small a volume. A US teaspoon has almost 5 mL in it or 2.5 million times the volume.
Stuart Black
Stuart Black
Likes For cyccommute:
Palmer
Quoted: 1659 Post(s)
Liked 1,807 Times
Hours of reading on the Alfine 11 in actual service:
https://forum.cyclinguk.org/viewtopic.php?f=5&t=64432
Liked 665 Times
Oddly enough, if there were metal particles in the oil, it would be black. As for changing the oil, at least on the old SA hubs, it's not so much a matter of changing it, but of replacing what leaks out.
Bikes: lots
Liked 2,932 Times
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
An oil change on the 11 speed Alfine is a drain and fill procedure. Removal of the internals is not necessary.
Did you do your penance for stealing the wife’s juice and tea pitcher?
