Need to stop the rotation & make the position fixed. Skip to 2:53 to see what I mean
Old 10-03-21, 03:01 PM
DyingAndDying
RespectIsEverything
Quoted: 27 Post(s)
Liked 3 Times in 3 Posts
How do I stop it from rotating, it does it while im riding, it's impossible to ride the bike.
Search up "Knock Hello annoying bike" on YouTube, skip to 2:53 on the video
Last edited by cb400bill; 10-03-21 at 03:20 PM. Reason: Gave instructions to the video. YouTube search bar
DyingAndDying is offline
Old 10-03-21, 03:07 PM
kahn
Quoted: 383 Post(s)
Liked 690 Times in 396 Posts
Do you mean to link to a video?
kahn is offline
Old 10-03-21, 03:08 PM
DyingAndDying
RespectIsEverything
Quoted: 27 Post(s)
Yes. I gave instructions to find the video on YouTube in the original post. They won't let me add the url
Last edited by DyingAndDying; 10-03-21 at 03:10 PM. Reason: Had to add a couple of words
Old 10-03-21, 03:14 PM
kahn
Quoted: 383 Post(s)
Is this the video:
If so, hopefully someone will know what to tighten.
kahn is offline
Old 10-03-21, 03:20 PM
DyingAndDying
RespectIsEverything
Quoted: 27 Post(s)
Is this the video:
Yes
Old 10-03-21, 03:35 PM
Inusuit
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times in 278 Posts
Your video isn't very helpful. Have you tried using an allen wrench to tighten the bolt head in the top of the handlebar stem? I'm unfamiliar with your brand of bicycle but that's what holds the handlebars correctly aligned with the front wheel on my bikes.
Inusuit is offline
Old 10-03-21, 03:48 PM
DyingAndDying
RespectIsEverything
Quoted: 27 Post(s)
I'll try it
Old 10-03-21, 04:03 PM
Barry2
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,194 Times in 687 Posts
What you have there looks like a quill stem.
You'd have to loosen and pull it out to be sure.
BUT please do stop turning the handlebars while holding the wheel straight. Once was enough.
Barry2 is offline
Old 10-03-21, 06:39 PM
DyingAndDying
RespectIsEverything
Quoted: 27 Post(s)
I think it is a quill stem, I searched up how to tighten it and it says to just tighten the screw used to check if it's a quill stem. I heard things about that screw shouldn't be tightened as there are ball bearings or something that could be crushed if too much force is applied. I'll show the video to a cyclery near me but I'm just angry I know I could probably fix it but don't want to break it and have to look for parts. I believe it is a quill stem. I'm just annoyed. Why did they assemble my bike like this.
Old 10-03-21, 06:52 PM
Inusuit
Quoted: 213 Post(s)
Three of my bikes have quill stems. The one that I ride the most often needs that bolt tightened to prevent the "rotation" you are talking about. I assume the vibration of riding gravel roads loosens it. I check it before every ride and tighten it if necessary. You will not damage anything by tightening that Allen bolt with as much force as you can muster on an Allen wrench. Just be sure the wheel is correctly aligned with the frame when you tighten it. Where did you purchase the bike and how long have you had it? Did you buy it from a bike shop or a big box store? It should never have left the store with the stem loose like that. Have you ridden it at all?
I suspect if you show your video to a cyclery they will tell you what you have read here. Just tighten the dang bolt.
Inusuit is offline
Old 10-03-21, 06:54 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
From the video, it looks like a quill stem, so just tighten the bolt. There are no bearings in there.
Rolla is offline
Likes For Rolla:
Old 10-03-21, 07:01 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Jesus people, it's a threaded headset w/ a quill stem. Do exactly what Rolla posted. Most likely a 6mm allen. Or watch the Park video that Barry 2 posted.
cxwrench is offline
Likes For cxwrench:
Old 10-03-21, 07:22 PM
kahn
Quoted: 383 Post(s)
Although, the wedge does not really expand but its displacement (as it moves upward) forces it again the head tube, right?
kahn is offline
Likes For kahn:
Old 10-03-21, 07:28 PM
Rolla
Guest
Yes, Dr. Pedant.
Rolla is offline
Likes For Rolla:
Old 10-04-21, 01:12 AM
Maelochs
Maelochs's Avatar
Quoted: 7648 Post(s)
Liked 3,464 Times in 1,830 Posts
First off, get a few pictures of quill stems and threadless stems. You will see immediately that you have a quill stem.
Probably want to do more research than "I heard somewhere" because people like to talk about stuff but don't like to bother learning anything. There are bearings in the headset, but there is also a lock nut and a headset nut .... to mess with the headset you'd have to loosen the lock nut and then adjust the headset nut, which has nothing to do with the allen bolt you need to tighten.
Pretty sure people have recommended (and even posted) videos which show you what to do .... and for the tl;dr crowd, @Rolla basically made it a meme.
Just do it.
If the local bike shops needs to see a video to figure out what's up, Don't Go There.
Is it a new bike? Is it a bike from a big department store where bikes are in the Toy department and are treated like toys---i.e. rushed onto the shelf as quickly as possible? Did you check over the bike when you took delivery?
Yes, if that is a new bike and someone sold it in that shape, that was very bad. Buy an allen wrench for $2 and fix it in about 30 seconds and go ride and enjoy.
In fact, I Never go out the door without a small set of allen wrenches and a couple screwdriver and a chain tool ...... spend $20-$30 on some tools because you will need them .... and if you bought a cheap bike you might need them a lot.
If you like riding, and plan to make riding part of your life, Definitely get some tools. The tools you need are simple and not very expensive and will last you the rest of your life.
But, yes .... $2 wrench, ten seconds of twisting, ride safe.
Maelochs is offline
Old 10-04-21, 03:23 AM
nomadmax
Quoted: 1104 Post(s)
Liked 1,824 Times in 878 Posts
Hook, line, sinker and the bobber for desert.
nomadmax is offline
Likes For nomadmax:
Old 10-04-21, 05:41 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2738 Post(s)
Liked 3,380 Times in 2,045 Posts
[QUOTE=kahn;22255736]Although, the wedge does not really expand but its displacement (as it moves upward) forces it again the head tube, right?[/QUOTE
depends.
dedhed is online now
Likes For dedhed:
