Rim cracks
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 187 Post(s)
Liked 106 Times
Rim cracks
I built wheels for our tandem using Ryde Andra 35 rims, 36 Saprim butted spokes, and Saprim polyax nipples. Sadly….After 7000 miles, much of which was heavily loaded, 4 of the spoke holes in the rear wheel have developed 5 mm long hairline cracks in the rim (not easy to see or photograph). The spokes are not next to each other, but in very different parts. The wheel remains perfectly true with average tension of 105 kgf (both sides, Rohloff) with 15% variation.
The cracks are very fine and I wonder if these are just superficial cracks in the anodized surface coating, is that possible? If not superficial, I am surprised since the rims are stout. Should I have used nipple washers? I suppose it is not worth the time to save the rim by adding nipple washers after the fact. Thanks for your comments in advance.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
SAPIM...no 'r'. The rims are most likely toast but your lack of photos doesn't help.
Likes For cxwrench:
I don't know if it's any help, but here's a shot of my wife's Bontrager rear rim cracked after five years of gentle riding. She was riding this w/o incident on the rear wheel until a shop spotted it and we replaced it with Mavic. There were maybe ten cracks, this was the worst of the bunch. From a single bike.
Likes For IPassGas:
a cracks a crack, no pic necessary, especially on a hardened anodized rim. plan for a replacement. not sure if washers would have helped or not. but usually, it is either overloading, or overtension. i never did really like the hardened anodizing either. personal experience i have seen alot of cracks in rims that did that, way more than a painted or polished rim.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Likes For canopus:
Quoted: 4153 Post(s)
Liked 3,751 Times
Al anodizing is harder and thus less flexible then the underlying Al rim. So it will generally crack before the base material does. But the qualifier is "before". In time the crack in the ano will be the stress riser for the base Al to start that crack at. Once a rim crack starts it's only time before that spoke hole won't support the nipple. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 187 Post(s)
Liked 106 Times
Quoted: 137 Post(s)
Liked 81 Times
Just how loaded is “heavily loaded?”
I’ll defer to folks who have experience with that rim and similar cracks. My $.02 is the cracks in the anodizing may not necessarily be a precurssor to failure of the rim.
Those are such heavy rims. Did the rim have to go through severe a re-truing some time in it’s early miles?
Quoted: 907 Post(s)
Liked 1,568 Times
Well if ya don't replace it you certainly should check it more than frequently. Really looks like an area of potential dangerous failure..
LR÷P=HR
Quoted: 842 Post(s)
Liked 1,148 Times
Quit goofing around.
just toss it.
will you really be comfortable riding it ever again!
Barry
just toss it.
Barry
Likes For Barry2:
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,559 Times
Quoted: 187 Post(s)
Liked 106 Times
If the rim should be replaced, I'm not sure what would be much better for this to not happen again. The rim is one of the strongest on the market, but apparently not sufficiently strong for two people and their camping gear, etc. And so my question regarding nipple washers. I should have used washers.
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times
Liked 3,751 Times
https://youtu.be/BanSukpRKKc
Actually IME spoke pull throughs are relatively non incident related/causing. Having seen dozens over the years and many (maybe most) were not even noticed by the rider till we pointed them out. Often during a annual servicing of their bike. And we do ask if there's any issues with the bike they know of that we need to focus on at the time of the service ticket write up. The usual early indications (other then the obvious visual) are a rim that won't stay true. Andy
AndrewRStewart
AndrewRStewart
Quoted: 6866 Post(s)
Liked 10,827 Times
Blamester
Back off the tension and keep an eye on it.
You have caught it early so it's not a problem for now.
You can judge its development over time.
I would say you have plenty of time to figure out something.
Likes For blamester:
Quoted: 187 Post(s)
Liked 106 Times
Thanks. Yes, figure something out. Backing off on tension seems prudent. I should have used washers, perhaps rebuilding and adding washer now would be good. I have 2mm thread on back side of nipples, so perhaps enough thread to add washers.
Liked 2,559 Times
If you're going to take the time to rebuild it, I'd probably get a fresh rim to try with the washers. (That is, if you can find one.)
I've built lots of wheels with used rims (most of unknown provenance), but I figure anything that already has a sign of cracking will set me up for disappointment sooner rather than later.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 741 Times
^^^ Ya, explain to your stoker you are at the weight limit for that rim... 180 kilos....that the rim has cracks in it but you rebuilt it and it should hold for awhile.
I'd get a new hub... more spokes than 36....new rim, new spokes.
I had an Open Pro hard anodized rim that developed cracks like yours. I rode for thousands of miles and eventually replaced it with an Open Sport rim that was a little heavier and stronger. No problems.
Quoted: 187 Post(s)
Liked 106 Times
Yes, perhaps, not trying to be argumentative. The rims are rated for (each) 130kg and tension 140kgf. Our total weight (w/bike and gear) is 210kg and tension is 105kgf, both well below max rim rating. It is a symmetric wheel so all 36 spokes are bearing the burden.
