Pedal Adapters - Part II
Old 10-20-21, 01:11 PM
ciclista_pazza
ciclista_pazza's Avatar
Bikes: 2018 Fuji Absolute, Yokota mountain bike (199?), 1979 Schwinn Le Tour Mixte
Quoted: 82 Post(s)
Liked 34 Times in 27 Posts
I recently created a thread asking about pedal adapters because at the time, my mechanic incorrectly told me that my '79 Schwinn Le Tour required 1/2" pedals. However, he was wrong and it turned out it needed 9/16" pedals, so I was able to use the pedals I wanted and adapters were not required.
However, I've found that with this vintage bike, for some reason it seems like my feet don't sit out as far (width-wise) as they do with my modern bike. This is not only uncomfortable, but I'm suddenly having knee pain where I hadn't had that previously. So now I'm thinking of actually getting pedal extenders so that the pedals sit out a little wider, as several members had mentioned that the extenders help the "Q-factor" and those with knee pain.
When I created that original thread, one forum member posted this comment:
The problem with pedal adapters, besides the increased "Q-factor" mentioned by others above, is that it creates a longer lever arm for the pedal, which can increase risk of crank failure at the pedal eye. This is particularly a problem if your pedaling style tends toward "mashing" rather than spinning. That said, my wife has been using pedal extenders on her bike for years, to increase the Q-factor, and has yet to see a problem. But she's not a "masher."
Do other members agree that this is a serious concern? I looked up crank failure and a Sheldon Brown article on that subject makes it sound pretty serious. On the other hand, I don't want to develop chronic knee pain. I'm not sure exactly what a "masher" is but I don't do anything weird pedaling - I pedal like a normal cyclist . Any suggestions on what I should do?
Here is the original thread for reference: https://www.bikeforums.net/general-c...-adapters.html
ciclista_pazza is offline
Old 10-20-21, 01:16 PM
spelger
spelger's Avatar
Bikes: yes, i have one
Quoted: 1115 Post(s)
Liked 1,160 Times in 676 Posts
i doubt that mashing would be a problem. but getting out of the saddle to put down a lot of power, that might be a problem.
spelger is offline
Likes For spelger:
Old 10-20-21, 01:33 PM
ciclista_pazza
Quoted: 82 Post(s)
Thanks. I find that I don't tend to stand up on the pedals of my Schwinn as much as I do with my hybrid bike, so maybe that won't be an issue.
Old 10-20-21, 02:03 PM
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 312 Post(s)
Liked 484 Times in 320 Posts
If you keep everything tight it would take so much more force than you could ever apply to create a problem. Mash away!
SpedFast is online now
Likes For SpedFast:
Old 10-20-21, 02:11 PM
macstuff
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 69 Post(s)
Liked 179 Times in 76 Posts
Take these things before I throw them out.
If they don't work for you, you throw them out or give them away.... deal?
They are only $20 new in the first place and I've sold the bike I used them on.
Easy-Peasy
macstuff is offline
Likes For macstuff:
Old 10-20-21, 03:42 PM
ciclista_pazza
Quoted: 82 Post(s)
I talked to my bike shop and they don't have any extenders in stock but they said they come in different sizes like 18, 23, 28 mm. I found one on Amazon that's 20 mm. I asked the bike shop guy and he was saying I'd probably need to get a fitting to confirm which size I'd need. Would you all recommend a specific length for the extenders? I have no clue and am guessing maybe 23 mm is a good start? Any suggestions about that? Thanks.
Edit - almost all options on Amazon are 20mm so is that what is typical for extender length?
Old 10-21-21, 01:44 PM
ciclista_pazza
Quoted: 82 Post(s)
Easy-Peasy
Thanks. I appreciate it. I sent you a private message to ask about this but haven't heard back so just let me know. Thanks again.
Old 10-21-21, 02:49 PM
philbob57
Quoted: 714 Post(s)
Liked 602 Times in 371 Posts
It's just physics. You'll simple exert more force on the junction of the pedal and the crank when you move your foot away from the crank. If the force is great enough, the crank will break. You have to find a compromise that works for you.
I use extenders because my knees are much more stable with them; with extenders, they move up and down with no discernible sideways deviation. Without extenders, my knees move in and out (WRT the top tube) as a I pedal. I've chosen to adapt my bike to my body rather than train my body to adapt to my bike.
Why are you considering extenders?
philbob57 is offline
Likes For philbob57:
Old 11-03-21, 05:05 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5216 Post(s)
Liked 3,555 Times in 2,325 Posts
FWIW - I climb out of the saddle w/ my extenders & easily weight 225lbs clothed & never broke an extender or crank. these are what I use during winter months when my clown feet are wearing winter boots
SUNLITE Pedal Extenders
FGT Motorsport Bicycle Pedal Extenders for 9/16 Inch Cranksets (21mm Spacers) Bike
rumrunn6 is offline
