Weird Headset lockring w/ 3 notches
#51
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
I've worked on thousands of headsets with this kind of lockring. Vise-Grips came in real handy.
#53
Quoted: 128 Post(s)
Liked 12 Times
I've got the same style headset on an early-80's Miyata (currently my commuting bike, see my sig) and was unable to get the lockring off with my small lockring tool. (Because my lockring tool doesn't have a long handle so I can't generate much leverage.) Incidentally, this sort of headset is the only instance where I've ever wanted a lockring tool that's smaller interface than for a bottom bracket lockring.
The headset feels smooth enough, so I'm leaving it for now. And I've got other JIS headsets in boxes in case this one gets eaten up and eventually needs replacing.
"c" is not a unit that measures tire width
#54
Great tips here. I found success by applying WD-40, using a square drive screwdriver held at a right angle to the nut, then tapping the side of the screwdriver blade with a rubber mallet.
#55
Quoted: 5680 Post(s)
Liked 2,386 Times
The easiest way to loosen this is by setting a dull screwdriver blade into the notch and tapping it loose. The beauty of this system is that the lockring doesn't have to be set super tight, and it should come off pretty easily.
FB
Chain-L site
FB
Chain-L site
#56
Had an identical headset on my Miyata Street Runner and used a ball peen and drift. A few careful raps in each cut out and it was finger loose.
#57
Constant tinkerer
It's just a threaded lockring, hit it with the old hammer and screwdriver approach and it should come loose easily enough. I doubt it's on there very tight.
EDIT*** darn these zombie threads... Usually I catch it but I missed it this time.
#58
Retro Grouch
Bikes: Yes
No, the radius of curvature for a BB lockting tool is too large, and the hook will lift out of the slot.
#59
Old fart
Quoted: 3556 Post(s)
Liked 3,332 Times
#61
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,559 Times
Actually there is a much easier way because there is a tool that is made for exactly this application, but on another item.https://www.walmart.com/ip/13447599?a...5=pla&veh=sem; the threaded notched ring for the headset is 35mm; this spanner is designed to R&R a 35mm threaded and notched lockring. And you can buy it at Walmart for $10.00. Who knew?
#62
Old fart
Liked 3,332 Times
#63
Mechanic/Tourist
Wow, sorry I missed all the entertainment on this thread! As with many things mechanical a little inspection and logic should make apparent both disassembly and adjjustment, but we all miss the "obvious" sometimes.
I just use one of my two adjustable lockring spanners similar to the one below, but much older.
Likes For cny-bikeman:
#64
Bikes: ritcheys{2** rm blizzard Geo elrick drop frame and acollection of parts bikes in waiting
Eldi made a adjustable lock-ring tool , also Hozan . The serrated washer has the ability to lock the headset when lock-ring is tightened , A good rugged old school design .
#65
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times
I just used this tool on a $9.00 Free Spirit F12!It has just this setup! I have all kinds of drifts and punches, brass and other wise. Could not work on my old bikes of all values with out this tool! Well. I could! I'm glad that I have this tool!
#66
rebmeM roineS
Quoted: 653 Post(s)
Liked 345 Times
Once again I was sucked into reading the first page or so of a Zombie Thread. But, in this case, not time wasted.
Looks as if folks are still encountering Zombie Headsets.
#67
Liked 2,559 Times
Rats, my Wal-Mart said they don't stock the Barska AR15 wrench. But I spotted this Tapco one online, and might even like it better for $5 more:
#68
Retro Grouch
Bikes: Yes
If you really want the Baraska wrench Amazon has them https://www.amazon.com/BARSKA-AR-15-S...ds=Barska+AR15
#69
Liked 2,559 Times
It will work, but not as well. The wrench is for the stock (as in rear portion of a rifle) lock ring that has 4 notches, not 3 like the headset lock ring. Per your picture, the right hook of the spanner will fit in one notch but the ring will not fit up into the opening, so the left hook digs into the outside edge of the ring; it will tighten or loosen the 3 notch ring, but it won't be pretty.
#71
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
#72
New headset with regular 32mm wrench flats, will be a better plan in the long run.
then how you take it apart, matters less.
#73
Quoted: 2025 Post(s)
Liked 1,095 Times
This thread has more lives than a cat. This is its second resurrection.
#74
Haven't repacked the bearings yet. What I want to know is, can these headsets be made to work reasonably well?
#75
Quoted: 286 Post(s)
Liked 100 Times
useful thread for me. I've got this on an old Nishiki mixte. I bought it in pieces as a project bike, and the headset was really grainy. I got it loose by making my own tool based on a tip I got here. https://m.instructables.com/id/DIY-Lockring-Pliers/
