For the love of English 3 speeds...
Been thinking about mud flaps lately. Went with a friend to Lowe’s and while in the plumbing section ran across these 6”X6” rubber squares. A dollar or two, 1.5mm or 3mm thick. Thought I would experiment.
made a pattern and cut on out. Looks like it would be a good item to use to keep the rain and mud off our machines. I plan on having an old headbadge riveted to some for my projects.
Let you know how it goes!
Likes For 3speedslow:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,445 Times
Likes For thumpism:
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 428 Times
Likes For gster:
Liked 2,445 Times
Likes For thumpism:
Same colour as the 70’s Sprite 27’s, just a lot brighter! How could the cars miss that?
Finished the 79 “Roadster”.
Started out as this
Nice ride around and a great fit
Like the black Sella Italia saddle and Carradice bag on it
Still some adjusting to take care of
Started out as this
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Got in a good test ride today and I have to say it has potential. Usual things like brake, saddle and shift cable adjustments to make. I will say that the original Chen XXXX tires ruin the ride feel. Skinny and hard make for a jarring trip. The hub is shifting sluggish due to the grease diet it seemed to be on. Quite a few aluminium parts were put in use for the build.
If it stays I will replace the rims and handle bars with alloy as well. All the fender and chainguard bolts were replaced with SS ones and lock nuts for rattle free rides. The rear stays were also bent back into their proper shape. The coffin reflected was switched for a SA Lucas unit. Tin shiftplate took the place of the missing one. It was fun to work on!
I had a newpaper route at the time and they required the bike to bright yellow, most kids just took a spray can to what ever bike they had. I went looking for a cheap bike, and found the yellow Raleigh Sports. It even had two huge saddle baskets and a double stacked newsboy size front basket set up. The guy who had it before me had moved from the city and had been using it to deliver packages and groceries with for two years. I think I gave $20 for it back then.
The guy had two super heavy duty tires, both with thorn resistant tubes and he had glued in leather strips inside the tires as well. He had both wheels respoked with 12ga spokes too. I used it for at least two years, mostly as my winter bike. I parked it when one of the rear seat stays cracked near the dropout It didn't fail completely but I had been noticing rust bleeding down the yellower paint from what looked like a scratch in the tube, then one day that scratch had a piece of cloth stuck in it, it had apparently been opening up while stopping with all the weight on the bike, and had pinched a piece of the outer casing of a bungee cord I had tied to it there that held the pepers forward in the rear baskets as I rode.
I brazed the crack up but never trusted it after that with all the weight of delivering papers. I delivered about 250 papers,and on coupon days, the thin paper swelled to 1' thick pile of ads and coupons meaning the bike was loaded to the max.
The only failure the bike ever had was the cracked frame, and somewhere along the line, I changed out the saddle when the old one split in the middle. .
On snowy days that bike would be covered in inches of ice and snow after a several hour delivery route in the snow or freezing rain.
Likes For 2fat2fly:
Had some time today so rode the new Raleigh through the large housing area I live in. Having shifting issues with 3rd gear fine, 2nd disconnecting and 1st feeling like 2nd. Grease will have to be flushed.
Neighborhood is Northwoods and Tweed is my favorite street!
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 356 Post(s)
Liked 260 Times
If you can get a pulley for the shift cable and mount it on the seat tube, the cable will be more free (better shifting). It will also not require as much adjustment if you move the wheel to compensate for the chain wearing.
ambulatory senior
Quoted: 1949 Post(s)
Liked 3,605 Times
Looks beautiful. I too hate grease in an aw hub. I flush with wd40 usually.
Thanks for suggestive thoughts! I agree with it on shifting benefits!
Next part will be the holes drilled into the front guard then marked, flap punched. Mounting will use rivets as well. The red 79 “Roadster” will be the wearer.
Liked 428 Times
I quite like this one.
Likes For gster:
gster
Thanks! I am liking the very upright riding position of this machine.
Today it goes on the stand while I flush the rear hub and put the flap on the front mud guard.
ambulatory senior
Liked 3,605 Times
https://www.facebook.com/marketplace...ok_story_share
Raleigh Sprite with dynamo hub. 5 speed derailleur but I thought you guys might like it. $50!
Quoted: 559 Post(s)
Liked 1,023 Times
Bikes: a few
Quoted: 90 Post(s)
Liked 366 Times
What is involved with this maintenance task? Do you take the hub apart?
NICE BIKE btw!!
Thanks!
Thanks for the compliment!
RustyJames
Thanks! When I get some matching paint for the frame scrapes I will paint the rivets on the fenders.
The PO, previous owner used a grease gun to lube the rear hub which is a no-no. To flush the hub you can take the wheel off the bike , remove the rod then through the cap squirt an appropriate fluid which will remove the sludge. Afterwards you put back the oil which the hub needs.
It saves surprises later down the road and isn't that hard to do. I've found quite a few broken pawl springs, stuck pawls, and bad bearing surfaces just doing a simple tear down and reassemble.
At 40+ years old, it certainly can't hurt anything.
Liked 428 Times
