Vintage pedal service?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
I have the pedal apart but was wondering if there is a special tool to
Turn the cup to tighten? I don't think a socket will fit but I was able
to loosen it with just a screwdriver it wqasn't on very tight. The pedal
had a nout with a slotted washer and then the cup
Quoted: 6178 Post(s)
Liked 4,796 Times
Are you thinking all pedals are designed like the others and that each is serviced exactly the same way?
How 'bout a pic or a model number?
Likes For Iride01:
I just rebuilt a pair of vintage SR pedals for the first time a couple of weeks ago. I found it easiest to just hold the side of the cone with a slotted screwdriver and adjust tightness by turning the spindle until you're ready to lock it down with the retaining nut.
Likes For Davewn:
Quoted: 957 Post(s)
Liked 1,619 Times
Thinking on a Leotard pedal Park made an old tool like the CCW-2 but smaller. I use a thin walled 7/16th socket from an old ChiCom DXed socket set...
Quoted: 677 Post(s)
Liked 459 Times
Quoted: 18354 Post(s)
Liked 4,502 Times
Shimano makes some pedal cone wrench sets:
Shimano TL PD300 Pedal Cone Adjusting Tool Set
7mm locknut, 10mm cone OR
10mm locknut, 13mm cone
TL-PD63 Shimano Pedal Cone Adjusting Tool
8mm locknut, 11mm cone
Shimano TL-PD33 PD-M324 Flat Pedal Bearing Cone Adjust Tools Set
10mm locknut,13mm cone
Whew, I didn't think they were that expensive!!!
Quoted: 4195 Post(s)
Liked 3,837 Times
My go tools are a flat bladed screw driver jammed along the side of the cone and a socket or wrench on the lock nut. I have a few model specific pedal bearing tools (including the Shimano one mentioned) and they work well, for their specific pedals. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
SE Wis
Quoted: 2742 Post(s)
Liked 3,389 Times
this
this
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I've done this a handful of times because many other hobbyists would rather toss them than rebuild.
My approach is just like other adjustable bearings. I'll find a socket that works for the cone, and screw the core down finger tight, then back off enough to leave a small amount of play. Next, slide the slotted washer onto the keyway and start tightening the lock nut. If the pedal spins freely and there's no play with the lock nut tightened, the job is done. If the bearing is too tight or still has play, adjust the cone looser or tighter, and repeat.
The key to this (a pun!) is the keyed washer. Without one, you'll want the flat screwdriver to try to keep the cone from tightening along with the lock nut.
The dropped
Liked 1,014 Times
I wanted to add that pedals use an absurd amount of balls in the bearings. You'll usually need 44 1/8" balls to rebuild a set (11 per bearing, 2 bearings per pedal). IIRC, the set of Lyotard Berthet pedals I rebuilt used 5/32" instead.
Notes will help. Try to track how many balls came out when you open each side, because it might not be the same. Measure the balls to be sure you have the right size to replace what you take out (some shimano pedals use the smaller 3/32" balls).
The dropped
Liked 1,014 Times
Quoted: 980 Post(s)
Liked 580 Times
I find that if, after tightening the lock nut, the bearing is too tight, backing out the cone with the larger of the two sockets will generally give the correct play. The anti-rotation washer only helps so much to prevent the lock nut from changing the cone's position.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
No, there's a lock nut that holds it in place. Just use a socket wrench on it. In your other hand, use a pedal wrench on the inside flat to hold the axle still.
Just like your vintage bb's, vintage pedals (that are serviceable) are pretty much serviced all in the same way. Though you may need to use a different socket (typically 10-12mm) on the lock nut between sets.
The dropped
Liked 1,014 Times
I use a socket to set bearing preload with my fingers. Then I use a socket on a ratchet to tighten the locknut. I'll echo your tip to use an open end wrench on the flats to keep the spindle from moving. I'm usually using the vise, myself.
Quoted: 677 Post(s)
Liked 459 Times
