Risks if riveting old steel frame?
Risks of riveting old steel frame?
Are there any risks to putting rivets into my old steel frame Schwinn for a bottle holder/air pump?
Quoted: 6186 Post(s)
Liked 4,803 Times
Not really. But someone somewhere probably has mucked it up trying to do it.
You talking rivnuts or are you just going to pop rivet them on?
Likes For Crankycrank:
Liked 4,803 Times
If you are going to paint the bike, then I'd just get some stainless bottle boss's and braze them on. You can buy them for cheap online.... https://framebuildersupply.com/collections/braze-ons
But if you don't have any skill at brazing or silver soldering then a rivnut will be good as it lets you use a bolt and you can easily swap bottle cages if the break or suddenly you don't like your bottle cage anymore.
Though a rivnut or a pop rivet will sometimes get loose in the thin walls that bike tubes have. So they aren't fool proof, but they are easy to install and don't mess up your paint like a brazing torch will.
https://bikepacking.com/gear/rivnut-bottle-cage-mounts/
https://www.parktool.com/blog/repair...ottle-fittings
Liked 4,803 Times
However I do think the last part deserves some consideration. That's a pretty niffty thing. Would have been nice if you linked place to purchase it.
On one bike, I even just used stainless worm clamps with a strip of inner tube underneath them to hold on the bottle cage. No one ever gave me grief or ribbed me about it.
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Define "old steel schwinn"
A 531 paramount, done properly OK
A electroforged Varsity no problem.
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
Quick Google search:
https://www.decathlon.com/products/u...roduct-feature
I have no experience with them
Friendship is Magic
Bikes: old ones
Quoted: 26400 Post(s)
Liked 10,373 Times
Likes For 3alarmer:
SE Wis
Liked 3,390 Times
Overbuilt frames, no problem.
FWIW I've used these in the past.
https://cambriabike.com/products/min...RoCjSIQAvD_BwE
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
The tubes on a varsity are probably thick enough to be drilled and tapped for a 5mm or #10 screw.
A #10-24 would be good as it has a deeper thread.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
Quoted: 1088 Post(s)
Liked 1,022 Times
Something like a varsity wouldn't notice a couple of small holes, just take your time and make the holes as smoothly as possible.
